-   dishwasher will run entire washing and drying cycle as normal, no odd noises or anything else out of the ordinary.
When I open the door to get the dishes the soap door is open and all the dish washing liquid is running down the inside of the door instead of being empty and used to wash the dishes.
Dishes are not washing well either.-   toler777
Sep 06, 2008
-   i have a whirlpool 850 dishwasher and it does not drain the water. i have to empty it with a cup. please help peter
-   Guest
Soap Dispenser Issue:
Make sure there isn't anything in front of the detergent drawer that would restrict that door from opening, then if that is not the problem.. try cleaning that drawer with white vinegar to remove any soap scum that might be causing it to stick.. and try using a liquid dishwashing detergent or about 3/4 of what you normally put in there as powdered.
Drain Issue:
I suggest you check the drain filter to make sure it is free of food by products that would limit the drain process. If that isn't clogged, then check your drain line for a kink in it. Make sure that the place it drains into is not the limiting factor ( such as a clogged garbage disposal) If you don't find anything obvious in terms of the filter , drain hose or your house drain then you mave have a faulty or clogged pump..
our model LD-12AW2 is showing error code IE. All water connections are o.k., and filters not...
(More)
our model LD-12AW2 is showing error code IE. All water connections are o.k., and filters not blocked. Can Anyone help with this problem please?
I switched the dishwasher on before I went shopping and came home to find F1 displayed on the...
(More)
I switched the dishwasher on before I went shopping and came home to find F1 displayed on the screen, and the dishwasher sounds like it is trying to empty. It has already finished it's wash cycle, but not begun drying. It is not responding to any buttons that I push on the keypad and the problem wont disappear even when I switch the machine off at the wall. What is wrong?
