Question about Canon PIXMA iP1600 Printer
Refilling a cartridge
How do i refill the ink cartridge on a canon pixma ip 1600
You need to use a very thin needle (25 gauge medical needle works well) on a syringe. There is a tiny hole in the canon 40 cartridge under the label which you need to fill. To refill the color cartridge (canon 41) as you look at the cartridge, the hole at the top is magenta, the hole to the left is blue and the hole to the right is yellow, use a separate syringe and needle for each color. Every now and then you will need to use some cartridge cleaner to soften/clean the sponge in the cartridge. I use 0.5cc of cleaner then let sit overnight before adding ink. You need to be sure the label is replaced well or use good tape to keep the ink from escaping.
Posted on Sep 08, 2008
Canon pixma ip2772 cartridge cannot be recognized
Pleas help me.
I have a Canon Pixma ip 2772 Printer, I used Original Canon ink Cartridge and it after refill. now i using original canon black and color cartridge but now have a problem. ink cartridge not recognized i used original cartridge 4.. pls. help me immediate
Jul 20, 2012 | Canon PIXMA Office Equipment & Supplies
I refilled my black cartridge of Pixma iP 1600. I have done it 3 times before and it worked perfectly until yesterday. Now when I refilled it the 4th time, the yellow LED blinks 5 times and then the green...
The manual for the PIXMA iP1600 says the following concerning the 5 blinks:
The ink cartridges are not properly installed, or a non-supported ink cartridge is installed (the ink cartridge EEPROM data is abnormal). Install the ink cartridges properly. Or, confirm that the supported ink cartridges are installed.
If you haven't already I would take a look at the electrical contacts on the cartridge to make sure they are clean (free of dust and ink) and then reinstall them in the printer. If the printer gives the same error, it's time to buy a new cartridge. 3 refills from a cartridge is not bad at all.
Hope this helps,
Steve
Feb 10, 2011 | Canon PIXMA iP1600 Printer
* After refile ink yellow color does not print at all.(ip 2772) * How to setup CIS system for canon Pixma ip 2772. which contains PG810/CL811 cartridges ?
I refilled Canon cartridge CL-811. I filled all 3 colors. Magenta Cyan Yelloware flowing well,. Even if I wipe the cart on paper tissue, 3 colors are coming out (pink magenta and Yellow).but while printing yellow colour isnot printing,. Any idea how I can fix the problem?
Jan 20, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
I have refilled my main black ink cartridge on my canon pixma ip 3600, my printer won't acknowledge the refilled cartridge, is there anything I can do about this?
This is because the ink cartridges has a memory chip.It monitor ink levels.Press and hold the resume button for 5 seconds.This operation releases the function for detecting the remaining ink level of the above ink.The printer shows empty cartridges but it will printing.
Nov 03, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
We had just refilled the ink cartridge for canon ip1980
please reset manual first by pushing power button before plug in AC cord, then push resume button twice and release both, if still happen please reinstall driver
Mar 03, 2009 | Canon PIXMA iP1600 Printer
My printer says that it is out of ink on the color side
hi all,
The printer shows message No Ink means ink has run out. Even you refill the cartridge this message stay remain. Check here to find out more.
regards
Nov 19, 2008 | Canon PIXMA iP1600 Printer
How to refill canon pixma ip1600 ink colour? the hole is too small.
IF YOU HAVE BUY THE INKS THEN YOU GET NIDLE AND SIRING THEN YOU WILL USE THE TECHNIC DOCTOR USE TO SWAP THE LIQUID FROM THE CONTAINER AND INJECT IT IN THE BODY YOU WILL USE THE SAME TECHNICS GET THE INK IN TO THE SIRING AND PUT IT IN THE CARTRIDGE BUT MIND YOU LOOK AT THE HOLES VERY WELL RED HOLE WILL BE MARK RED, BLUE WILL BE MARK BLUE WHILE YELOW WILL BE MARK YELOW SO ALL YOU NEED TO DO IS FOR YOU TO PUT THE INK IN THE RIGHT HOLE IN SOME CARTRIDGE THE HOLES WILL GUIDE BY A OBJECT REMOVE CAREFULLY THEN AS YOU FINISH REFILLING EACH HOLE PUT THE OBJECT BACK.
Nov 13, 2008 | Canon PIXMA iP1600 Printer
Canon iP 1600
dear
you can refill your catridge, open the label .... make a whole with knife or something edge, and the red color in center position, the yellow in the right position , and the blue in the left position
don't refill too full, about a 30 cc inks
oke maybe it can help you
thks
cropp
Feb 19, 2008 | Canon PIXMA iP1600 Printer
Using refilled cartridges
Are these chipped cartridges/ If so you will need to get hold a cartrisge re setter Most ink suppliers/manufacturers do them.
Jun 02, 2007 | Canon PIXMA iP1600 Printer
Canon PIXMA iP1600 Printer Logo
108 people viewed this question
old marine
old marine
