Question about Kenmore 46462 Front Load Washer
Error F dL?
When pressing the normal wash button the washer at first won't lock the door. It acts like it wants to start but instead just gives a click click sound....then goes into error. It flashes F then dL on the screen. Today I tried to wash something and now the door is locked and and I haven't been able to get the washer to work. Suggestions?
  • 1,028 Answers
Remove the top cover of washer at rear is the main control bd try wiggling the wires on front side usuually the larger wires if it works bad connections on control no fix but to replace it ..HOWEVER try shimming the plugs in place to hold them in position where it will work...possible door lock itself but control more likely
Posted on Sep 07, 2008
My Kenmore front load washer will not fill--it sounds like it is draining instead. The last load washed did not spin correctly and the clothes were very wet when cycle completed.
Washer Not Filling:
  • Door Not Closed and Locked
    • Front load washers won't fill if the door is not closed and locked. Listen for the door locking when starting a cycle, then pull on the door to make sure the door is closed and locked.
  • Delayed Start Feature
    • Some washers have a delay prior to filling, where the electronic control is checking the dispenser function. This is Normal.
  • Flashing Lights or Error Code on Display
    • When there is a filling issue, the washer may shut off and display one of the following codes: LF, LE, nF, IE, FH, E10 or F20.
    • If the washer is displaying one of the above error codes, then do the hard reset procedure listed below.
If the appliance is not accepting input from the control panel, follow the steps below to reset the control:
  1. Unplug or turn the circuit breaker off for 30 seconds.
  2. Plug the power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
  3. Press the Pause / Cancel / Stop button twice to clear the display.
  4. Start a short cycle, to check operation of the appliance, by selecting a cycle and pressing and holding the start button until the appliance starts.
Oct 15, 2012 | Kenmore Washing Machines
Hi! We have Kenmore Elite he3t. We noticed water in the washer today after a complete cycle so we ran the rinse and drain command on it. I tried to begin a new load on a normal wash cycle and it will...
Hello and welcome to FixYa
DL f is a door lock error and is caused due to an issue with the door lock when it is unable to lock/unlock. Please check the door lock mechanism/door switch assembly and replace the part that has gone bad so that the issue is resolved. Please get back to me if you have any other questions.
Aug 30, 2011 | Kenmore Elite 45986 Front Load Washer
I have a Duet GHW9400PWO and it will not turn the water on. When I press the start button I am getting an error dL and then F and it just beeps.
Error DL sound like a door lock problem. The door latch lock assembly is all one part. If door doesn't lock a signal is sent to the main control telling it there is a problem. Thus the error code. Nothing will work till door locks. 3 screws hold the assembly in place, but you have to partially remove door boot to get the door latch out.
Feb 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Clicking and F dl error
Error code stands for door lock. May need a new door lock.
Oct 23, 2009 | Kenmore HE3T Washer
When pressing the start button a "DL" indicator flashes and then a "F" indicator remains, door does not lock and the washer will not start.
that is the code for door lock. ensure its not stuck or something in rubber boot stopping door from closing all the way and try to reset it.
maybe by unplugging it for a coupkle of minutes
May 24, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Whirlpool duet says Fdl washer wont turn on
F/dL ERROR IS FOR :-- Door Lock ErrorA Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Door Lock Mechanism broken or removed from the Door globul1a.gif Check Door Lock/Switch Assembly globul1a.gif Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU) globul1a.gif Door Lock/Switch Assembly Failure
May 06, 2009 | Whirlpool GHW9400SU Front Load Stacked...
F dL symbol on Whirlpool duet HT
It is saying there is a problem with your door Lock. when you close the door does it hold like it use too? try to open and close the door if it doesn't really close properly then you will just need a door latch. If the machine gives you an f11 code then its the main computer board that can also give your the door lock error. I would check the door first though.
Jan 09, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
My Kenmore elite HE3 washer was giving me the dl error code. Now after a wash, the door is still locked and I can't get my clothes out. I am not getting any results when I press any of the buttons. What...
remove bottom panel reach up toward lock area and pull down door should unlock..ckd door lock for problem also ckd small push button in lock area to make sure it's not broke or the latch part on door
Sep 16, 2008 | Washing Machines
Door lock
dl meand door lock. A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error. Potential Causes ? Door Lock Mechanism broken or removed from the Door ? Check Door Lock/Switch Assembly ? Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU) ? Door Lock/Switch Assembly Failure Replace failed component.
Sep 22, 2007 | Kenmore Elite 45986 Front Load Washer
Washer displays DL error
The FdL fault is a door lock error code. It sounds like you may have a bad door latch. Unplugging it and/or pushing the cancel button will not clear the fault as long as the fault condition exists. At best, you may have to replace the door latch. At worst, the CCU (main computer) could also be bad, causing the fault. The door latch can run about $50. The CCU is about $200. Double check all you wiring first before replacing any parts. I hope this will help you.
Mar 11, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 46462 Front Load Washer Logo
172 people viewed this question
Sal De
 Brian Main
Brian Main
