Question about Canon Cameras
Canon Digital Elph 7.1 mp. Lens error. Does not resolve itself after turning off/on.
t00nz
  • 4738 Answers
SOURCE: Digital Camera
The following blog outlines some repair options for a lens error:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Dec 26, 2007
SOURCE: canon powershot sd30 digital elph
I have same problem. I turn on the camera you hear it trying to come on, shows display pic for like 3 seconds and then shuts down. If I could get the lens to retract I am sure the camera would work.
Posted on Jun 24, 2008
  • 125 Answers
SOURCE: Canon digital IXUS 60. Lens
I'm guessing that the lens is stuck. Either the cover refuses to open because something is wedged in or a mechanical malfunction. The camera won't work if the lens does not come out a bit. Take a look at the lens and examine why the cover doesn't open up. If it is a mechanical malfunction (meaning internal problem), might as well have it fixed. Be careful and keep your fingers off the lens. You may touch the cover but hands off the lens. Hope this helps.
Posted on Jul 18, 2008
SOURCE: lens error
yes, this happened to me, what you have to do is "snap" the lens back in place, if it is bent anyway. if it is not bent and it says lens error, does it the lens come in and out? if not then it is bent if so then there is a hardware error in the switch and you will have to send it to a profesionall. :) hope i could be some help :)
Posted on Jun 17, 2009
SOURCE: I dropped my CASIO EXILIM EX-S770 7.2 7 MP
just force it back in - it happened to me and i had to pull it pretty hard but figured that it was broken anyway so might as well give it a go - camera worked fine afterwards!
Posted on Jul 21, 2010
There is a shadow on lens
  • check the lens for any physical damage (cracks , dust etc. ) wipe the lens using a lens cloth .
Jul 20, 2014 | Canon Powershot Elph 100 Hs / Ixus 115...
I have a canon powershot sd750 and when i turn my camera on it says lens error, restart camera
Hi Shawn,
Check the link below and you will be able to fix the issue by doing the troubleshooting.
Click here - > Camera Troubleshooting
Regards,
Suhail
May 17, 2012 | Canon PowerShot SD700 IS Digital ELPH /...
Canon SD600 Elph
When the lens will not retract and camera is not functional (no picture on display, and does not shoot) , and you already tried replacing batteries with a new fresh set (ensure please) , and then restarting camera with no memory card inside, then camera is faulty.
Try an easy fix by pushing gently the lens (do not force them, just help them) while you turn off camera at same time. Try also switching the mode selector.
If still no luck , then the camera must be disassembled to fix the problem.
Possible reasons are :
  • Faulty lens mechanism or jammed lens (camera usually turns off by itself in this case)
  • Main board faulty.
  • Ribbon cable to main board broken or connector defective.
  • If there is no power at all it is the connector from batteries to main board, this is also a ribbon cable.
If the camera is less than one year old will be replaced by manufacturer.
If your warranty is expired you can get an estimate for repair from manufacturer, or from a third party like Advance Camera here :Advance Camera Repair you can book the repair online.
Jun 18, 2008 | Canon PowerShot A70 Digital Camera
I need HELP
Dear ashlyw:
A lens error due to impact damage most often requires service.
If you get an E18 message or a "lens error restart camera" message on your LCD screen and you restart the camera several times to no avail, you will almost certainly need to call Canon Tech Support at 1-800-828-4040 and have it sent in for service as there is little or nothing you can do to resolve the issue.
Hope this helps.
Sincerely,
HeavyDLB
Jun 02, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Cameras Logo
21 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
