Question about Kenwood KDC-MP828 CD Player
Kenwood kdc-mp 825
The panel on the kenwood will flip open when the car is on but then a few seconds later it will shut halfway and turn off. When you try to turn it on and it does the same thing all over again. It is actually the kdc-mp825 model but the website says that it does not recognize that product
  • 29 Answers
It's a Canadian Kenwood.
http://inform3.kenwoodusa.com/manuals/KDC-MPV8025.pdf
I had the 925 purchased from Ebay, but I sold the car with it.
it's probably the ribbon wire broken between the face and the unit. I know that on Ebay some they use to offer a repair for these type of units.
Posted on Sep 07, 2008
  • 3 Answers
Try this:
Hold down BUTTON [5], press the RESET button.
Posted on Dec 08, 2008
Got a Kenwood KDC-PSW9524. For some reason the
MINE DID A SIMILAR THING THE FACE PLATE IS MOTORIZED AND GOT STUCK CLOSED SO INSTEAD OF BREAKING IT I FOUND THE RESET BUTTON ON THE RADIO IN THE FRONT ON THE SIDE ITS A LITTLE TINY BLACK HOLE STICK SAFETY PIN OR SOMETHING IN IT.BUT BE CAREFUL IF YOU DONT KNOW YOUR RADIOS SECURITY CODE IF NOT SURE WHILE STILL ON GO INTO THE OPTIONS AND TURN THE CODE ACCESS OFF.!
Apr 12, 2009 | Kenwood KDC-PSW9524 CD Player
Display disappeared on kdc 8021
If you mean that the rotating cover has flipped back round covering up the control panel turn on the ignition and push the top left of the panel. this should make the cover flip back around and make the interface available.
Jan 12, 2009 | Kenwood KDC-8021 CD Player
Unit only has power for a few seconds
Yeah remove the unit from your car,
Go to car audio store and buy Kenwood receiver without the
fancy opening front.
Dec 17, 2008 | Kenwood eXcelon KDC-X879 CD Player
Kenwood KDC-MP922
there is a button under the back of the face in one corner, just press around the back of the face with the car on until you feel the button press in and it should open.
If not you may have a bad ribbon cable that is not too expensive to replace.
Sep 09, 2008 | Kenwood KDC-519 CD Player
KDC-X869 Face Flips Halfway, Unit Turns Off
I have worked on many of these radios and there is a lever that contacts switch to determine position of face this lever wears out and switch does not operate properly causing radio to lose its mind. This is usually the cause of this failure unless flip gears have been damged somehow. contact kstahl65@att.net for additional info
Jan 21, 2008 | Kenwood eXcelon KDC-X879 CD Player
Faceplate won't close
Alot, of the radios have a common problem with the connection from the radio's2.gif detachable face. What happens is corrosion builds up on the connectors between the pin and the connector itself. Sometimes you can clean it off with a small file. Also, some KENWOODS with the motorized face are known to have a problem with the ribbon cable connecting the face plate to the main board. The last time I repaired one I called KENWOOD2.gif and aquired the cable for about 65 dollars, what the problem is, is the cable is wrapped around a plastic white spindel with a high tension spring and places alot of pressure on the cable from the wear and tear of the face opening and it will cause strange problems such as: turning on and off, some buttons working while others don't, the display partially turning on and off, and the face to act peculiar and flip down halfway. In addition, sometimes the face open and close switches go bad, but I've never had to replace them yet. .
Dec 15, 2007 | Kenwood KDC -X815
Will power up,will hide, will open on igntion start
yup.. needs a new face plate ribbon cable.. just like mine :-(
Sep 24, 2007 | Kenwood KDC-716S CD Player
Kenwood KDC-MP825 car stereo problem
My wife experienced the same problem this month, December 2008, after owning the KDC-MP825 for 3.5 years (what's up with that?). It would power on briefly, the panel would move, then after 2 seconds it would shut down. After 15 seconds, it would power again, panel motors whir, then shut down. It would keep doing that while the key is in ignition.
This appeared to have solved the problem:
Hold down BUTTON [5], press the RESET button (you'll need a ballpen to press between the AUTO and SCRL button).
This was the procedure for getting the receiver out of demonstration mode. Maybe the cold weather here in New Jersey placed the unit into demo mode?
Aug 20, 2007 | Kenwood KDC-MPV8025 CD Player
Kenwood KDC 7024
Some flip face stereos use a tiny micro switch to tell the onboard computer when the face is down or up and sometimes it uses the same switch for both positions sensing. It could be this switch is not working properly (dirty contacts, broken, bad wire, mis-aligned, etc.) and that is causing the problem. Good luck.
Feb 12, 2007 | Kenwood KDC-7024 CD Player
Kenwood KDC-MP828 CD Player Logo
324 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
