Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Thermostat back light problem.
I'm having the same issue. Please let me know if you find out how to turn it off. Ours is like a beacon in the night. My husband has been placing a baseball cap over it until we can figure it out.
Thanks.
Kristi
Rowley1@cox.net
  • rowley1 Oct 19, 2008
    Thank you soooooooo much, Jay! What an easy fix!
  • 3 Answers
You need the installation manual which can be downloaded at
http://yourhome.honeywell.com/Consumer/Cultures/en-US/Products/Thermostats
go to setting 280 which sets the backlight options and select option 0 which turns on the backlight for 8 seconds when a button is pushed and then turns off.
This info is not in the owners manual, only the installation manual.
Posted on Oct 16, 2008
When do I know if fan oven has reached temp there is no light on range
Get an over thermometer Until you get it sorted out. Otherwise, ours "clicks" and light goes out. If yours has light when you turn it on, just watch for the light to go "out" You can understand better if you turn the thermostat dial up and down and get an understanding of how it works.
Mar 08, 2015 | Kitchen Ranges
Control panel light dim
Have you checked your use and care manual ? There might be a solution there
Jan 24, 2014 | Samsung Refrigerators
I have a blue vertical flashing light showing just above the Dell emblem. In the past there has been a solid light. I have checked on OpenManager which indicates all is well but I do not like unexplained...
Great thanks,
That's just a system indicator flash. Solid blue means on and normal, blinking means someone either turned on the system indicator in the management software or bumped the indicator switch on the back of the server. This was designed to make easier transitions from back to front when working with multiple servers in a rack. To turn the indicator off, just go to the back of the server and find the Ethernet and usb ports that are together. If the usb is the bottom and Ethernet port is the top then just to the right you should see a small blue blinking light and a button, pushing the button wil turn the blinking off.
Again, no worries this is just a "locator beacon" not an error message, if the light ever blinks yellow then you have an issue.
Hope this helps FixYa,
Chris
Jan 10, 2011 | Dell PowerEdge 1800 Server
Router was fine last night - but the two wireless computers in the house are unable to get online this morning. What lights are supposed to be "lit" on the front? I see Power wlan and Internet are lit now.
Hi Friend,
Please follow the steps in order to resolve the issue:
1.Open the router page (192.168.1.1)
2.Enter the username and password (by defualt password is admin and leave the username blank)
3.In the router setup page click Wireless and fill the sections and mentioned
Wireless Network Mode-Mixed
Wireless Network Name- As per your choice
Wireless Channel-6-2.437GHz
Wireless SSID Broadcast-Enable and click Save settings.
4.Now click Wireless Security and select the Security mode as WEP
5.WEP Encryption should be 64 bits
6.In the Key1 enter a 10digit/10 letter password and click save settings.
7.Click Advanced Wireless Settings and fill the section as mention
Beacon Interval-75
Fragmentation Threshold-2306
RTS Fragmentation-2307 and click save settings.
8.Turn off the router for 30 seconds and then turn it on and try to connect your laptops.
I hope this will resolve the issue.
Regards
Chiranjeet
May 20, 2010 | Linksys Wireless-G WRT54G Router
My back light does not turn on automatically at night
Most likely a wiring issue. Possibly a wire touching bare metal.
May 21, 2009 | 2000 Toyota Camry Solara
It beeps and beeps but doesn't turn on
ours stopped no power no lights i am replaceing the control board on order
Jan 16, 2008 | Frigidaire ATF6000ES Front Load Washer
No lights no power
i had the same problem, but husband just unplugged the machine and plugged it back in and now its working again. dont know why, but that worked. good luck
Dec 24, 2007 | Electrolux Frigidaire Professional Series...
Heating & Cooling Logo
3,110 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
