I recently purchased a hp photosmart c7280 and want to know if i can print photos on 5x7 paper.
    President:
  • 1,114 Answers
Hi - You can download the manual by clicking the link underlined in blue below:
c7280
See page 105:
So yes you can print 5x7 although 4x6 is recommended.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Sep 07, 2008
I have an HP Photosmart A646 printer that I bought in the hopes of printing to 5x7 card stock. We have pre-printed card stock that we use for gift certificates and we need to be able to feed the card stock...
Thanks for visiting FixYa!
Depending on the program you are using to print your gift certificates, try this-
1) Open the program and open the file you use for your gift certificate.
2) Click on 'Layout' then 'Page Set Up' (probably found in the top menu bar by the right side of, FILE.)
3) Select 'Landscape' and then select, 'Custom'.
4) Enter 5x7 for height and width.
5) Enter the information you need in the data field, (ie, name address, etc.)
6) Select, Print.
7) When the 'Print Manager' box opens, click on, 'Properties'.
8) Click on, 'Type' and choose, "Envelope'.
9) Click on, 'Size' and choose 5x7. - and click, OK.
Your printer should have a slide where the paper is inserted. Place one of the 5x7 cards in the slot just as you would an envelope and slide the slider until it is 'close' to the card but not directly against the card.
Click, 'Print'. The printer should recognize the card (due to its thickness) as an envelope and print it.
Mar 19, 2011 | Office Equipment & Supplies
Cannot print 5x7 photo on Photosmart D7360,
if you dont hvae 5x7 option you can creat your won setting open printer adn faxes ...>goto file ..>server properties there you can creat it......
Oct 30, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
How to print onto glossy photo paper in paper tray from my pc
set your printer with the paper size and selecect the type of paper - HP glossy paper. Youmight want to check below link for more details of any of HP printer issue
http://pc-and-peripheral.blogspot.com/
Oct 19, 2009 | HP Photosmart C7280 Printer
Have hp photosmart printer 7700 series problem loading 5x7 photo paper into printer
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
astrtr5
Aug 18, 2009 | HP Officejet 5610 All-In-One InkJet...
HP photosmart c7280 printing photos with purple hue
Does the c7280 use seperate Magenta and PhotoMagenta cartridges? If so make certain the right cartridge is in the correct slot.
Jun 20, 2009 | HP Photosmart Pro B8350 InkJet Printer
When I tryto print 5x7 prints from windows fax viewer my photosmart all in one model C4480 is printing the first 5x7 fine but the second 5x7 also has a small wallet size printed ontop of it
Solution one: Print on heavier paper Try printing on a thicker type of paper. Solution two: Check driver settings If printing on plain paper, make sure the driver settings are set to Plain Paper.
  1. To change the driver settings, click the Properties button in the Print window.
  2. If the Paper Type is not set to Plain paper, click the drop down box and choose More .
  3. Find and click Plain paper , then click OK .
  4. Click OK to return to the Print window and click OK to continue printing.
Jun 18, 2009 | HP Photosmart C4480 All-In-One InkJet...
HP Photosmart C7280 Paper Jams
It isn't always about the paper. The video shows a few other things to check.
May 04, 2009 | HP Photosmart C7280 Printer
How to load 5x7 photo paper into hp photosmart D7460 ??
Simply set the page layout option to select from printer. Place the cut & proper sized paper in the inlet tray, adjust the sliders so that they just rest lightly against the edge of the paper. Remember only one slider moves and the other one remains fixed to one edge. Click print preview. You might get a message saying paper orientation is not right...should I adjust the printer automatically, click yes and behold it will print in Portrait or landscape mode depending on the matter. If it warns that output does not fit on the media(paper) then select fit to page option.....sodeep
Mar 22, 2009 | HP Officejet 5610 All-In-One InkJet...
HP Photosmart C7280 All-in one says "out of paper".
If you get an 'out of paper' message when you do have paper loaded, this video will help. Following the steps of this video, you'll see if there's paper jammed in the printer.
Feb 25, 2009 | HP Photosmart C7280 Laser Printer
Printing 5X7 photos
try aligning and cleaning the cartridges
hope this helps
Apr 12, 2008 | HP Photosmart 2575 All-In-One InkJet...
353 people viewed this question
jasbo
jasbo
