Laptop keeps shutting off at startup - Computers & Internet
  • smithmanny Sep 06, 2008
    acer aspire5610 vista home premium
    Genius:
  • 1,550 Answers
It sounds like there is some problem with your bios setup .
Are you able to login through safe mode
You need to format your system and reinstall the your windows cd
If you need further assistance provide details about
laptop model
what kind of os are you using
Posted on Sep 06, 2008
  • SAM ANDERSON Sep 06, 2008
    Thanks for your response
    This may be due to overheating of fan
    You should check where fan is sitting - is it near a heat source? Is it sitting on something that might block the ventilation?
    Can you feel ANY hot air coming out of the exhaust port?
    Does the fan initially kick-in when you power on, then subside?
Hi.. i have hp pavilion laptop and the problem is my laptop shutting down automatically at startup
The fan is probably stuffed with dirt, making it difficult to rotate. And if the processor doesn't get enough cooler (fan) it will heat up and burn. Thats why it keeps shutting down. The shutting down is actually protecting your pc from serious damage. So try cleaning the fan with a vacuum cleaner. Be careful not to use too much pressure. Goodluck
Aug 13, 2014 | HP Pavilion Computers & Internet
When i want to shut down my laptop it wont shut down. it keeps saying shutting down. I have to turn of my battary and put it back. this is not the best solution iv checked all my program files and all are...
Start-Run - MSCONFIG
unselect all the startup items and reboot. Then check if it shuts down properly (which it should now) - then go through each startup item with a reboot inbetween to see which is the troublesome one.
Bear in mind you may disable your antivirus program doing this, so make sure this one is reselected after your troubleshooting.
Aug 10, 2013 | eMachines Computers & Internet
My computer keeps showing rapair recommened or start up normally. what is the problem
If you close your computer without using the windows bar button, it will show the repair message on startup. You should always use the "turn off computer" in the start menu to shut down your pc.
Feb 28, 2011 | Compaq Presario CQ60-220US PC Laptop
I am using DEll latitude D430 running on windows XP. When I click on shut down it keeping on processing to shut son endlessly until I manually shut down. I have two laptops that are behaving this way....
Go to run> type msconfig> go to startup go and disable all unwanted programs, then go to the next tab ie. services , then at the bottom check hide all microsoft services and then disable the rest
revert back if more help is needed or if you ar not sure of what you are doing
Dont forget to say thanks
Aug 10, 2010 | Computers & Internet
Why does startup repair keep popping up on my laptop when i turn it on my sony laptop
This is the system error and it comes when the user doesnot shut the comp in proper way.//
it can also come if due to some reason the comp is shut automatically//
to get rid of it try last known good configuration.
shut down the comp// restart and immed start hitting f 8 cont to get the advance boot menu//
select LKGC and once that is done hopefully your computer will boot perfectly//
May 29, 2010 | Sony VAIO VGN-CS110E/W NoteBook
My sony vaio VGN-B1XP, running windows XP, keeps shutting down. It is now 5 years old?
hi
thank you for using Fixya
if your windows shutting down in startup then you have problem with windows only
if your windows runing till your desktop then it's shutting down it meance u have virus in your pc
May 14, 2010 | Sony Computers & Internet
My laptop as randomly started shutting down on its
Put you Vista DVD in the drive & boot off of DVD, and when you see the menu select Startup repair... leave it go on through it's process and reboot when told , this should repair your startup issue, otherwise get back to me.
Feb 18, 2010 | Compaq CQ60-215DX Notebook
Startup repair
Did you try using Safe Mode? Hit F8 when its booting and choose safe mode. See if that will let you boot into the OS.
May 15, 2009 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
