Question about Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine
Hoshizaki F-800 MAH
Need to know were the violet, red and orange wires go on the flush timer. The timer wires fell off when replacing the timer. Please help, Thanks, david
  • Hoshizaki Master
  • 1,238 Answers
Check their web site. can get lots of info. their tech support line is worth the wait. 1800-233-1940
Posted on Feb 13, 2009
  • Dennis Boxerman Feb 16, 2009
    I have found a model F800 MAF and MWF. Could not find MAH.
    First, the flush switch looks like a SPDT switch. The violet wire attaches to the single pole side of that switch. The other end attaches to terminal 3 on the flush timer.
    The other 2 poles on the switch has a red and orange wire. The orange wire goes from the switch to the number 1 terminal of the flush timer and then "Piggy Backs" from there to the gear motor relay terminal 4.
    The red wire goes from the switch to the float switch and also branches off to the water control relay terminal 5.
    The flush switch is not numbered in the diagram. You can try to figure out the poles on the switch with a meter.
    Again, good luck
Ice machine not harvesting
if you are sure the float swith is good and the dip switches on the board are correct, you most likely have a bad 1 minute timer on the control board. will have to replace board.
Nov 30, 2012 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki km-650 mah keep dumping water nothing at all running.
really sounds like the board needs replacing. after 1 minute, if the float is doing it's job, the compressor is to come on provided the water level is correct and the float is doing what it was designed to do.
Nov 30, 2012 | Hoshizaki Commercial Freezer KM-500MAH
Hoshizaki km - 280 mah ice maker not making enough ice
A few simple things to check is the condenser for dust. Blow it out. If their is a water filter going into the unit change it. Get some ice machine cleaner and follow directions. Do these things before calling anyone out.
Aug 12, 2012 | Hoshizaki Freezer Commercial Ice Machines...
Hi i have km-320-mwh hoshizaki ice machine, this machine is discharging water in drain continuesly except when it is dumping ice is this normal ...too much water is being lost please help many thanks...
By looking at the model number it is a water cooled unit. It will dump water down the drain continuosly as that it how it cools the compressor. If it was a MAH it would be air cooled and no continuos dump of water.
Aug 09, 2011 | Hoshizaki Freezer Commercial Ice Machines...
I have a model # f-450 mah ice machine. After the bin gets full of ice it stops making the ice but the water continues to run and runs out of the machine. Any ideas on how to stop this?
Sounds like the water valve is stuck. Probably needs replacing. Turn off water after machine shuts down and see if water stops. If it does, water valve is most likely the issue.
Mar 01, 2011 | Hoshizaki Freezer Commercial Ice Machines...
LOOKING FOR A TIMER AND RELAY FOR HOSHIZAKI ICE MAKER MODEL dcm270BAH THE TIMER # IS HRDE412SA90M AND THE RELAY # IS UPMDD I NEED THE BUY ONE OF EACH WHERE CAN I GO ??
Try Rick and Restaurant Parts and More. I get all my Hoshi parts from him. Make sure you have model and serial numbers as he verifies information to help minimize errors. Very reasonable and dealer pricing. 1-888-814-1110
Jun 26, 2009 | Hoshizaki Freezer Commercial Ice Machines...
My ice maker 10amps fuse burn out when turn on the machine
This may sound too simple. A fuse is a safety. It usually blows when the amps are higher than the fuse rating. Since yours blows immediately, I would look very closly for a pinched wire, a crossed wire, or a wire that has rubbed through. Once that is eliminated, start isolating components one at a time. Check their web site. It's pretty good. Also, their tech support line is pretty good. It's worth the wait. 1-800-233-1940.
Jan 22, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Harvest cycle on ice machines
My ice machine Hoshizaki km-500 mah is cycling to fast. Causing poor production of ice it's real small and it doesn't produce enough ice aswell. Wha seems to be the problem.
Jun 20, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine Logo
204 people viewed this question
Top Hoshizaki Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Hoshizaki Freezer Expert? Answer questions, earn points and help others
