Ok ,
Does it trip all the time now,or only after running a while.?
If it trips right when you reset breaker with machine OFF, have the wiring checked for a dead short to ground up to the thermostat.
If it trips after running ,as it starts or intermittently there's a dead short to ground that could be any where.
You can simulate what is going on by doing this check.
Unplug machine.
Using an ohm meter,set to ohms, place a test lead on the ground prong(round one) .Place the other test lead to one of the remaining prongs.If there is any reading youv'e got a short. Try the other prong as well
However, if you get no reading there still could be an intermittent short .
Another thing to check. It might not be the machine at all.
Sometimes,if your wall recepticle is worn or old it can heat up causing circuit breaker trip.
Make sure there are no extention cords involved.
If you're on a 15 amp circuit ,you might want to upgrade to 20
Good hunting
