Question about Kenmore 53701 Dehumidifier
Warm air from side vents..
Why does warm air come out of the side vents?
Thanks..
  • rjburer Oct 02, 2008
    Thank you :)
If your dehumidifier is one that runs at colder temps so it does not ice up, it will have a heater in it to prevent this. That is the warm air you are feeling.
Posted on Oct 02, 2008
Why is it blowing cold air?
A dehumidifier should blow cold air Carole. It takes in warm moist air, chills it, condenses the water out of the air and returns it chilled and dry to the room. That is the function of a dehumidifier. They often have the function of an air conditioner and blow cold air out of one outlet into the room and hot air out of the window via a venting hose. If yours is just a dehumidifier, it is working as designed
What were your expecting a dehumidifier to do?
Jan 15, 2016 | Amcor Dehumidifiers
Sometimes it blows out warm air warm enough to warm an entire room, yet at other times is blows cool air that can kkep a room cool. I want it to blow cold at all times. how do i do that?
dry air feels cool on the skin
moist air feels warm on the skin
this is why the perceived temperature of air from unit changes
Apr 14, 2015 | Dehumidifiers
I have a 30-pint KUL dehumidifier that works GREAT and is fairly quiet. My question is: the air that flows from the vent is lukewarm at best and sometimes warmer than that. If the a/c is on, this affe
A/C removes the heat found in the air and so gives out slightly warf flows but normally this is cooled of by water but that is why air con home units are vented to the outside atmos
Sep 21, 2012 | KUL 30 Pint Dehumidifier
MY dehumdifier is blowing warm air ,Is there a fitler that needs to be cleaned and how is this done ? Model 3fdl5051 50pints
It's not unusual for a dehumidifier to blow warm air. As it may be in defrost mode. Even so, they still blow warm air.
The model number you furnished is slightly helpful. Knowing what brand it is, would be even better.
Never-the-less, the filter should be located behind the front louvers of the unit. Turn the Master ON/OFF Switch to OFF and unplug the unit. Remove the water collection bucket and look up inside the bucket holder, just behind the front louvers. You may see a plastic pull tab handle. If so, that's the filter frame. Pull it straight down and out.
If you didn't find it there, look on the right hand side of the unit, just behind the louvers for what looks like a a flip open door. If you see that, flip the door open and remove the filter.
The filter can be cleaned using a vacuum cleaner or if it's really dirty, wash it in warm water and dish washing liquid. Thoroughly rinse and allow to completely dry, before reinstalling it. NEVER operate the unit without the filter in place.
Hope this helped you. Please let me know. Thanks.
Jul 12, 2011 | Frigidaire Dehumidifiers
Cold air is coming out, instead of hot air. how can i fix problem thanks john
if you want hot air the you need a humidifier, it puts warm moist air into the room. used to put moisture in the air if your running a wood stove
Mar 04, 2011 | Kenmore 54701 Dehumidifier
My dehumidifier runs but lets out warm air. Is there anyway I can repair myself ? What could be the problem? Help,,, Thanks
The dehumidifier is supposed to be releasing warm air. In order for the built-in refrigerator to lower the coolant's temperature, heat must be removed from it. Thus, that removed heat flows out of the unit. If it's a problem, I would suggest having a fan nearby, or perhaps you could put the dehumidifier in a cooler part of the house. (In case you're curious, try looking for any vents near your refrigerator or freezer, and you'll see what I mean.)
Aug 03, 2010 | Kenmore 54501 Dehumidifier
My maytag dehumidifier doesn't dry the air
It's a refrigerant leak. (very common with virtually all dehumidifiers) If it's out of warranty, it's time to buy a new one. (cost prohibitive to repair)
Jun 19, 2010 | Maytag M7DH45B2A Dehumidifier
Air conditioners remove the moisture from the air, and so does a dehumidifier. Does running a dehumidifier make the air conditioner run less? Does running the small dehumidifier save energy in that the...
a dehumidifier is basically the same thing as an air conditioner but both coils (condenser and evaporator) are in the same unit meaning a dehumidifier exhaust warm air in the same room it is in. running a dehumidifier would make an air conditioner run more because of the warm exhaust, but you are correct, when you run an air conditioner it acts like a dehumidifier and dries the air. as far as saving energy it all depends on the size of the AC and dehumidifier and the size of the room. If you want warm dry air use a dehumidifier if you want cool dry air run the AC but not both.
May 18, 2010 | Dehumidifiers
Turns on but blows out warm air
Is the compressor on as well? or just the fan, if the compressor is on and fan is on and it is blowing warm air it could be a charge (refrigerant problem)
Jul 27, 2009 | Goldstar DH4010B Dehumidifier
My Danby DDR586R dehumidifier shouts hot air, it was shooting cool air before, what can the problem be?
Here is Danby's official response to a similar question on their FAQ page for Dehumidifiers:
https://www.danby.com/faqs.php?cat=12
Q) When the dehumidifier is operating, is it normal for the expelled air to be quite warm? We find that the dehumidifier is warming up the room noticeably (a finished basement).
A) The warm air that is being expelled from your dehumidifier is normal. When the unit is dehumidifying the compressor is working which causes the compressor to become quite hot. In order to avoid having the compressor overheat, air is drawn by the compressor at a rapid rate and the heat is then transferred to the air which must be expelled from the unit. The warm air will stop shortly after the unit has reached the desired humidity. This warm air should not change your room temperature by more than a degree or two.
May 07, 2009 | Dehumidifiers
Kenmore 53701 Dehumidifier Logo
105 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
