Question about Canon Cameras
When I insert a memory card, all of a sudden I get "999" as the number of pictures available in stead of the accurate number. I have a G& and have never had problems before.
    Genius:
  • 1,550 Answers
It may be fault with your memory card .
There is a chance that your memory card might have been corrupted
Also ensure that your battery is properly charged
There is also chance of mechanical problem existing in your camera .
Is your camera canon s3 or s5 or some other model
Posted on Sep 06, 2008
Frame no. full
In the English Manual on page 150 it says Frame no. full:
The frame number has reached 999-9999. Remedy:
1 insert a formatted Memory Card into the camera. 2 Set RENEW as the FRAME NO. setting in the (SET) SET-UP menu (> p.117).
3 Start taking pictures (The frame number starts from "100-0001").
4 Set CONTINUOUS as the FRAME NO. setting in the (SET) SET-UP menu. Good luck
Jan 13, 2014 | Fuji FinePix S700 Digital Camera
Tip
Transfer photos from Camera to PC
<span><span><i><b>Hello and welcome to FixYa!</b></i><br /> <br />To transfer your photos from your</span><span> Digital Camera</span><span><span> to PC, Follow the given steps:</span><br /> <span style="font-weight: bold;">1.</span>First connect your digital camera to your computer.<br />You can do this in two different ways:<br /> <br /></span></span> <ul> <li><span><span> <b>Use a USB cable:</b>Most digital cameras come with a cable that connects the camera to a USB (Universal Serial Bus) port on your computer.</span></span></li></ul> <ul> <li><span><span> <b>Through memory card:</b>A memory card reader is a piece of hardware that plugs right into your computer. You remove the memory card from your camera and insert it into your memory card reader, similar to the way you might transfer a file between two computers using a floppy disk.</span></span></li></ul><span><span> Now connect USB cabe or Memory card Reader to the port of the computer<br /> <span style="font-weight: bold;">2</span>.Once you've connected your camera to your computer or inserted your memory card into your memory card reader, your computer will detect the connection and ask you what you want to do with your pictures. If you connected your camera with a USB cable, click <b>Microsoft Scanner and Camera Wizard</b>, and then click <b>OK<br /><br /><img src="angel_bird_1.gif" /><br /><br /></b></span></span><span><span>If you are using a memory card reader, click <b>Copy pictures to a folder on my computer using Microsoft Scanner and Camera Wizard</b>, and then click <b>OK</b>.<br /><br /><img src="angel_bird_2.gif" /><br /><br /></span></span><span><span><span style="font-weight: bold;">3</span>.When the Scanner and Camera Wizard appears, click <b>Next</b>.<br /> <span style="font-weight: bold;">4.</span>All of the pictures on your camera (or in your camera's memory card) are now displayed on the Choose Pictures to Copy page. By default, Windows XP selects all of the pictures for downloading. If there are pictures you do not want to download, just clear the check box next to those pictures. At this stage, you can also rotate pictures that you took while holding your camera vertically. To rotate a picture, click it, and then click either the <b>Rotate clockwise </b>or <b>Rotate counterclockwise </b>button on the lower-left side of the page. When you have reviewed the pictures for downloading and rotated your vertical pictures, click <b>Next</b>.</span></span><br /><img src="angel_bird_3.gif" /><br /><br /><span><span><span style="font-weight: bold;">5.</span>On the Picture Name and Destination page, type a name for the group of pictures. (This name, plus a number to differentiate each picture, will be applied to each of the pictures you download; for example, if you name the group "Vacation," the pictures will be named "Vacation001," "Vacation002," and so on.) Click <b>Browse</b>, and select a folder in which to save your pictures.<br /> <span style="font-weight: bold;">6</span>.If you want to erase the images from your camera's memory card to make space for new ones, select the <b>Delete pictures from my device after copying them </b>check box, and then click <b>Next</b>. The Scanner and Camera Wizard copies the pictures from your camera to the folder you specified and then removes the pictures from your camera's memory card.<br /><br /><img src="angel_bird_4.gif" /><br /><br /><br /></span></span><span><span><span style="font-weight: bold;">7.</span>On the Other Options page, you can choose to publish your pictures to a Web site or order prints. If you have finished working with your pictures, click <b>Nothing</b>, and then click <b>Next</b>.<br /> <span style="font-weight: bold;">8.</span>On the final page of the wizard, click <b>Finish</b>. Windows XP opens a Windows Explorer window showing the pictures you downloaded from your camera. Your camera's memory card is now clean and ready to store new pictures. If you connected your camera to your computer using a USB cable, disconnect your camera. If you used a memory card reader, return the memory card to the camera.<br /> Your photos are now stored on your PC, ready for whatever you want to do with them, and <span style="font-style: italic;">your camera is ready to take more pictures.</span></span></span><br /><br /><span>Thank you for Using FixYa!</span><br /><span><span><br /></span></span>
on Apr 28, 2011 | Cameras
My screen's camera says, "Card is Full."
in camera memory is alredy full but u say only memory card formaat pls look the camera memory and no answer that the card is full
Oct 24, 2012 | Fuji FinePix S5200 / S5600 Digital Camera
Nikon D90 and memory card counter
There doesn't seem to be a problem. The 3.7k means 3700, the k meaning thousand. If you were to take about 2700 pictures, you'll then see 999, then 998, and so on.
Apr 07, 2010 | Nikon D90 Digital Camera with 18-105mm...
The remaining picture counter stays at 999
The maximum number of remaining shots that the display can show is 999.
If the memory card has space for more than 999 pictures, the number will stay at 999 till less than 999 remain and it will start counting down from there.
Jul 09, 2009 | Canon EOS 30D Body Only Digital Camera
Chip says full after few pics
The chip may not be inserted correctly. You can tell by seeing or not seeing SD symbol in the view screen. Try removing the SD card. Go through the memory and see if the pictures were saved to the camera or to the card. If the pictures were saved to the camera, turn off the camera and re-insert the card. See if the cards responds by showing more pictures available for taking and move the pictures to the card. If the pictures were saved to the card, then the card may need to replaced.
Dec 31, 2008 | HP Photosmart R717 Digital Camera
Count down on memory card
Hi!
The K100D's lcd read-out is limited to displaying 999 as its maximum. This means that the card is capable of storing 999+ pictures. Once it gets to a point that the card can only store 999 pictures or less, then it will begin to count down.
Hope this helps!
Sep 26, 2008 | Pentax K100D Digital Camera
Reset Folder No.
Finally, I have contacted the Panasonic Repair Centre. The answer is the only way to reset the folder no is to bring it back to the repair centre and have it rested there. Moreover, say there is a file 1000001 in the memory card now. After you use the "No. Reset" function and if you do not format the memory card (in other words, the 1000001 file is still in the card), the new file no will become 1010001 when you take a new picture with this memory card. Therefore, I will format the memory card before I use the "No. Reset" fuction in order to make the new picture started from 1000001.
Sep 13, 2005 | Panasonic Lumix DMC-FZ10 Digital Camera
Internal memory or to the optional xD-Picture Card?
The internal memory and xD-Picture Card cannot be used at the same time. When the card is inserted the internal memory is disabled. When you want to use the internal memory you must remove the xD-Picture card. The LCD display indicates the images are being saved to the internal memory by displaying [IN] in the lower right corner of the screen. When using the xD-Picture Card the LCD will display [xD] in the lower right corner. These indicators are displayed just above the number of available frames.
Aug 31, 2005 | Olympus Camedia D-435 Digital Camera
Cameras Logo
22 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
