Question about Linksys Wireless-G WRT54G Router
Wireless router(linksys wrt54g)
I need to find my wireless router settings to connect my wii
  • 928 Answers
You may follow the instructions below in doing so.
1. Go to a computer wired to the router.
2. Open an internet explorer browser
3. Click on the address bar and type in 192.168.1.1
4. Leave the username blank and password is "admin" in case you changed it. In which case put in your password.
5. Go to the wireless tab. There you will see teh SSID or wireless network name.
6. When you look at the word wireless under that is basic wireless to the right is wireless security. Go to wireless security to see your security mode and password.
If you need further assistance you may message me.
Posted on Sep 06, 2008
I need the Network security key to add my lapptop to the router.
http://www.pcwintech.com/screenshots-linksys-wrt54g-linksys-firmware
First, let's log on to the router.
  1. Open your internet browser and type http://192.168.1.1 in the address bar. This is the default IP address of the browser.
  2. In the login box that appears type 'admin' (without quotes) in both fields. 'admin' is the default username and password.
Write down the SSID
  1. In the Wireless > Basic Wireless Settings menu you will see the Service Set Identifier or SSID. The SSID differentiates one wireless network from another. It is the 'network name'. Write it down, or copy paste it to a text file. You will need it later. You can first set your own SSID if you like.
In the Linksys WRT54G router you will find the wireless security options under Wireless > Wireless Security. This page allows you to set wireless encryption options.
here you will find you wireless key. this can only be done by a machine connected directly by network wire. make sure you are connected first. wireless is unable to connect unless it is directly connected.
Sep 14, 2011 | Linksys Wireless-G WRT54G Router
Hello i need to open some ports in order for my ps3 will function properly..I need the Tcp ports open #'s (80)(443)(5223)(10070)(10080) and also need the UDP ports open #'s (3478)(3479)(3658)(10070) model...
LINKSYS ::::
NAT STRICT
Step 1 : Connect Router - Computer
Step 2 : Open Router Setup by typing http ://192.168.1.1
Step 3 : Click Applications and Gaming
Step 4 : Click DMZ
Step 5 : Select Enable and Give the IP Address of the XBOX/PS3/Wii in it
Step 6 : Click Save settings
Step 7 : Unplug the Power cord from the router and turn Off XBOX /PS3/Wii
Step 8 : Plug the power cord back to the router and wait till the lights are Solid
Step 9 : Turn on the Xbox/PS3/Wii
Step 10 : Test the Connection
Else ...
Under application and gaming you can find port range forward
There you can open the ports one by one
And give the IP Address of the PS3 for all the ports opened
Dec 21, 2010 | Linksys Wireless-G WRT54G Router
I am trying to hook up my Wii to the internet, but every time it says there is an error. what do i do
Setup your Wii to the your router's current security setting or add your Wii's MAC address in your router if using MAC filter security.
Apr 18, 2010 | Linksys Wireless-G WRT54G Router
Cannot connect wii to router linksys wrt54g v8 i have switched my channels to 1 and 11. I have also updated my firmware to the newest version. I have also tried the manual setup but to no avail I have...
If you have Wireless MAC Filter Enabled on the Router then Either ADD the Wireless MAC Address of the Wii on the router or disable the Wireless MAC Filter on the router, also check the level of the Wireless Security supported by the Wii and accordingly set it up on the Router.
Mar 27, 2010 | Linksys Wireless-G WRT54G Router
I can connect the internet on my wii with this
**I m not able to find a snapshot of the router interface. But i ll tell you what all to do there
1) Disable the router's inbuilt firewall
2) Enable DMZ for your Wii's IP address; assign this same IP address on your Wii manually
3) Change the bandwidth of wireless to 20/40MHz
This will surely work
Jan 17, 2010 | Linksys WRT54G-TM Wireless Router
Router not seeing internet connection
If you are on cable internet, you need to perform MAC Address Cloning. Access the router's setup page using your main PC, under SETUP tab, there's a sub-tab called MAC Address Clone. Enable that and click on "Clone My PC's MAC" then click on Save Settings. Power cycle the router and the modem. You should be online after that.
Jun 09, 2009 | Linksys Wireless-G WRT54G Router
Can't load updates to my wii
you have it connected via wireless? try with cable.
Jul 16, 2008 | Linksys Wireless-G WRT54G Router
Hooking up to Wii
Hi you have not mentioned your internet service provider ,,
However ,you can click on the link below to get basic information onhow to configure Wireless connection on the router.
http://register.wireless.utoronto.ca/?page=linksys
If the default user name or password provided in the link doesn't work then you will have to reset the linksys router to the FACTORY DEFAULT by pressing small "reset" button at the bottom of router all lights should go off briefly when you reset it.
After reset you can follow the steps given in the link.
Cheers
May 31, 2008 | Linksys Wireless-G WRT54G Router
HELP ME GET MY WII CONNECTED!
check...IP address..and the LAN configuration....
Feb 03, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
104 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
