Question about Bose Lifestyle 28 System
Bose Lifestyle 28 /Sound - no picture
Hope you can help.  We've had our Bose Lifestyle for about 3 years now and it's always functioned fine.  Today, we moved the tv and components out to vacuum and when we returned them to their 'home' the Bose suddenly stopped putting out video.  We tried the obvious issues, such as loose and disconnected cables - to no avail.  Even tried turning off the power and resetting the tv and Bose.  This has happened once or twice before and my husband has managed to get things going again.  This time nada!  Is it possible the s-video cable simply crapped out?
  • TDAVISEMAIL Oct 05, 2008
    THIS WAS INTERESTING TO READ BUT MINE IS IN THE SAME SITUATION. I WILL PUT A DVD TO PLAY AND SOUND OFF DVD WILL PLAY BUT NO PICTURE? AT LEAST IM NOT THE ONLY ONE THAT THOUGHT IT WAS THE USER. SOMEBODY PLEASE HELP! LOUISVILLE KY
  • leopope Dec 25, 2008
    My Lifestyle 38 has a picture on some channels but not others. There is sound on all channels.
SOURCE: Bose Lifestyle 28
well s video is a good picture it is not the best and when you kink one or bend it too far they are no good i recommend using either the rgb cables or YPbPr also known as component video either of these cables will provide better image than the s video
Posted on Sep 06, 2008
SOURCE: HDMI cable between TV and Lifestyle 28
Did you set up your bravia TV to receive pictures throuh HDMI ?
Posted on Dec 28, 2008
realmacoi
  • 18 Answers
SOURCE: bose lifestyle 28 will not come on?
The Bose Lifestyle System has two power connection. One is the adaptor for the media center/DVD and the other one is the bass module/ subwoofer. Both has physical indicators showing that power is present. If your pwoer adaptor is ok, then the media center display should show "BOSE LIFESTYLE SYSTEMS" on startup. The bass module power module should be OK when you see a green blinking or steady linght underneath.
If only the media center/DVD has no display then there is something wrong with your pwer adaptor and should be sent for repair.
Hope I have helped you
Posted on Apr 08, 2009
57 varieties
  • 1653 Answers
SOURCE: Can you replace the DVD drive of a Bose Lifestyle
Yes providing you locate the manufacturer of the one that is fitted to your system
Posted on Aug 30, 2009
SOURCE: how do I connect my ipod nano to my bose lifestyle
tengo un Ipod nano 5° generation, con radio. Como lo escucho en el Bose?
Posted on Dec 18, 2009
I have a bose lifestyle 28 system purchased back in 2003. The remote broke when it was dropped on the floor (no longer functions). Is it possible to repair the remote or buy a replacement for this older...
Exactly how "broke" is the remote? (pictures help here, but if you don't know how to post one, or how to keep it under 150KB in size, then be as descriptive as possible in a REPLY to this post.
Feb 27, 2011 | Bose Lifestyle 28 System
Bose Lifestyle 28 Sound Problem
I also get this problem sometimes with mine. Usually when you call Bose they suggest that you do a "hard" reset meaning you unplug the power cord from the wall and wait about one min. Then plug the unit back in and it should work.
The other thing that you can try if the system still isn't working is to check that all the wires running into and out of the sub-woofer are all plugged in and aren't loose.
If either of these two solutions don't work you can alway call Bose tech support @ 1-877-210-3782 (they are open Monday Friday: 8:30 AM 8:00 PM ET)
Mar 31, 2010 | Bose Lifestyle 28 System
PS3 to Bose Lifestyle 28
hey, this is how i have mine set up.
Bose to PS3 via Digital Audio Optical
PS3 to TV via HDMI
This way you can get Full 5.1 surround sound, and good picture quality, also, go to the bose menu and set the optical source to your PS3.
Jan 29, 2010 | Bose Lifestyle 28 System
I can't get my remote to work. I have replaced the batteries, but still have no function. It has been working fine for 3 years, and today is the first time I've had any problem with it.
if you shake it gently can you hear any sound? If so you may have a broken wire inside your remote you can solder it if you have the tools
Jun 06, 2009 | Bose Lifestyle 28 System
Connecting lifestyle 27/38 to psp3
Your Bose system doesn't lead sound trough hdmi.
You must connect the optical cable with your lifestyle.
Change the sound connectionsettings in the menu of your ps3.
You also need to assgn the optical connection in the setup menu of the lifesyle. e.g. optical=aux.
Dec 28, 2008 | Bose Lifestyle 28 System
(Bose lifestyle 28) DVD picture is distorted, shadowy and difficult to discern
Try the settings setup and adjust the brightness, video format, or video black level. If you're using component connections then adjust the video output. You can scroll system setup through the remote control settings button.
Nov 10, 2008 | Bose Lifestyle 28 System
Will not play rented DVD's
This may sound silly, but have you tried a DVD lens cleaner?
Oct 18, 2008 | Bose Lifestyle 28 System
Bose Lifestyle 28
Sep 06, 2008 | Bose Lifestyle 28 System
Bose Lifestyle 28 System Logo
99 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
