Question about Solo S2 Radar Detector
Escort Solo 2 Locks up
My Solo 2 is about 2 years old. About a year ago, I noticed the unit began intermittently shutting off (while driving) and wouldn't restart without removing and re-inserting batteries. Now, it also shuts itself off (still while driving) and will occasionally re-start with a press of the start button (or not). I've noticed that the batteries seem loose inside the battery compartment.
Thanks for the feedback.
5 Suggested Answers
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
  • 68 Answers
SOURCE: Escort 8500 Restarting Constanatly
most likely u have a bad connection with ur cigarette lighter or the fuze in the end of the wire that goes into the cigarette lighter the cap screws off and theres a fuze there or there is a small cut in the wire or kink in it that if shutting off the power to it,.or the tip in the plug that goes into the detector isnt fuly pushed in but i believe its a fuze hope this helps
Posted on Nov 20, 2008
  • 134 Answers
SOURCE: escort doesn't work
There is no place where you can send it in for any type of service. Not only that, your Solo's performance is horribly outdated compared to any current Bel or Escort radar detector model. Even Whistler offers high end models which significantly outperform your old Solo. It is time to upgrade, plain and simple.
Posted on Mar 17, 2009
  • 63 Answers
SOURCE: Hi! Great site! I have questions about
Contact escort they have a mail-in repair service
Posted on Aug 27, 2009
Testimonial: "Great service! Thanks for speedy response!"
  • 4 Answers
SOURCE: Escort solo 2 won't power on
cinnatti microwave corp will repair the unit if returned to them,seems as if the power cable got switched around and power was reversed to unit causing internal fuse to blow. the chg is appox $25 takes about two weeks
Posted on Nov 14, 2011
Nov 14, 2011 | Escort Vehicle Parts & Accessories
Low humming sound from we don't no where. Have tried shutting everything off and I mean everything off and still it persists , mostly all the time. Sounds like a low rumble that waxes and wanes. Driving...
I had a similar problem on a unit for one of my customers several years ago. I thought it sounded like a transformer getting old and louder. I shut what I thought was all power to furnace,including unit switch,breaker,and blower door switch and still it would not stop.By luck and a healthy zap from 110 volt I found out they had run power back in to transformer from one side of contactor on a.c. unit. I installed a new transformer and rewired incoming power to repair. Hope this does you some good. Thank you.
Feb 02, 2011 | Heating & Cooling
I have a LG DR 389 recorder:it refuses to read certain discs it has recorded-I have been using imation DVD-R and R. I noticed sometimes by removing the recorded disc immediately it is ejected the problem...
Region error code comes up when trying to play a disc.Has worked fine for 2 years, no setttings have been changed. Even new discs give thge same error
Aug 13, 2010 | Televison & Video
3 YEAR OLD SANYO DP 32746. SHUT ITSELF OFF, CAN NOT TURN BACK ON
If you leave the tv unplugged for 2 days (atleast) then plug it back in and try to turn it on and if it comes on its the power supply board. If it comes back on it will probably shut off between 30min to 4hrs and you would have to unplug it for 2 days again. All the power needs to drain out of the tv. If thats the case take the back pannel off and check the part number out on the internet. Not hard to do becarefull touching things the power supply does store a little bit or shock in it. Good Luck.
Dec 13, 2009 | Sanyo DP32746 32 in. LCD Television
GE PROFILE REFRIGERATOR-PSC25MSTA NOT WORKING
check to see if the fan by the compressor is working when the compressor is running if not you have the problem control board .....replace board
Jun 30, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Programmable thermostat intermittent problems...
Some tstats control humidity as well. Temp will over shoot set point in order to reach humidity s
Jun 24, 2017 | Honeywell Programmable Thermostat Heater
Won't go off
The first thing to try is to do what is called a "factory reset". What this does is to force your RD to reload all of its factory default settings straight out of the programmed firmware. These new settings will then overwrite any present settings which may be corrupted. Here is how to do it (specifically for the Solo S2):
Solo S2’s Factory Settings
To reset Solo S2 to its original factory settings,press and hold the Mute and M (Mode) buttons while turning Solo S2 on.Solo S2’s display will provide a “Reset” message,accompanied by an audible alert,acknowledging the reset.
Mar 11, 2009 | Passport Solo Radar Detector
Escort doesn't work
Dec 18, 2008 | Solo S2 Radar Detector
Varifying detection
This happens often, as the units are basically very expensive bricks. They usually work quite fine for 12 months and 37 seconds though! The devices are built by prisoners in Ohio on a work-release program ... do you think they care? No, really, do ya? After getting hosed for $340, be prepared to cough up more cash. And, even then, there is no guarantee that the "repair" will last long, as it is only warranted for 6 months after the "repair" is completed. Oh, and btw, it WILL fail again. ZZTop watch  your speed, as the S2 you describe is doing squat. As for an onboard self-test feature, this is a GREAT idea, but, of course: 1) You are dreaming and 2) This would completely ruin Escort's business model.
Jul 26, 2007 | Solo S2 Radar Detector
Open Questions:
See all Solo S2 Radar Detector Questions
Solo S2 Radar Detector Logo
89 people viewed this question
Top Escort Vehicle Parts & Accessories Experts
John Nolan
Jason
Steve
Are you an Escort Vehicle Part and Accessory Expert? Answer questions, earn points and help others
