Question about JVC GR-D20EK Camcorder
Firewire problem I cannot get my JVC DV to work with my laptop. The DV comes with a firewire cable IEEE 1394 4-6 pin. It works with my desktop but the laptop is 4 pin IEEE 1394. I puchased a 4 pin IEEE1394 but the software on the laptop cannot find a device. Is this because DV needs to be 6 pin. Thanks Mark Green.
    Problem Solver:
  • 15 Answers
It should work. Laptops have a 4pin connection. There is a video on how to specifically connect digital cameras to laptops using 4pin to 4 pin IEEE 1394 cable. So it should work... The video is on www.HandBookLive.com under Electronics category. It doesn't cover the software because all softwares would be different, but you can see that it uses 4 pin to 4 pin. You can double check on this site though.
Posted on Sep 07, 2008
Transfer video to laptop or pc
This requires a i.LINK socket on the PC, is also known as Firewire or IEEE 1394; if your PC doesn't have one of these inputs, adaptors and add-on cards are widely available). This page from sony shows how
How to transfer DV or Digital8 videos to your PC and supplies the software required.
You can buy a Firewire to USB lead from here.
USB to Firewire Ieee 1394 4 Pin Ilink Adapter Cable 5 feet
Sep 16, 2013 | Sony Handycam DCR-TRV22E Mini DV Digital...
Connect JVC GR-D240ek to vista laptop
Hi and welcome to FixYa,
A firewire to USB will not work. It has to be firewire to firewire. A JVC GR-D240ek uses 4-pin, IEEE 1394 compliant Digital Video Connector [DV OUT] to connect a 1394 cable (also known as a FireWire or i.Link cable) to a laptop equipped with an equivalent IEEE 1394 port. Please note that some laptops firewire port could either be 4 pins or 6 pins.
Soon as that connection as shown above is established, you can use Windows Import Video to capture / download the videos.
Other notes (from the same Windows Help link above) :
  • You can also open Windows Import Video by using Windows Movie Maker. After you connect ... your DV camera, and your computer, start Windows Movie Maker, turn on your DV camera, put it into playback mode, and Windows Import Video should open automatically.
  • You can also open Windows Import Video by using Windows Photo Gallery. After you connect ...your DV camera, and your computer, start Windows Photo Gallery, turn on your DV camera, and put it into playback mode. In Windows Photo Gallery, click File, click Import from Camera or Scanner, click your DV camera in the list of devices, click Import, and then follow the instructions.
  • You can also open Windows Import Video by using Windows Live Photo Gallery. (This options requires you to install Windows Live on your computer.) After you connect your...your DV camera, and your computer, start Windows Live Photo Gallery, turn on your DV camera, and put it into playback mode. In Windows Live Photo Gallery, click File, click Import from a camera or scanner, click your DV camera in the list of devices, click Import, and then follow the instructions.
Verify that the laptop's firewire port is 100% up to specs and totally compliant to IEEE 1394.
God luck and thank you for using FixYa.
Jun 18, 2009 | JVC GR-D240 Mini DV Digital Camcorder
I dnt hav usb cable for my handy cam DCR-HC52E ...
Product Summary
    4-pin to 4-pin IEEE 1394 iLink FireWire Cable dv out to laptop Connect and transfer home movie from your digital camcorder to Notebook computer.
    You will need a Firewire port on your computer, also known as a DV port or IEEE 1394, to use this cable. This is NOT a USB cable.
    This DV cable will connect your laptop (notebook)
    NOTE: for some models, becuase of no DV jack on the body, this cable connects to docking station/cradle instead of connecting directly to your camcorder.
Mar 20, 2011 | Sony DCR-HC52E Mini DV Camcorder
I can not download sony DCR-HC54E mini DV to PC, please assist me in details.
You require a firewire cable to connect to the PC then use Movie Maker to capture the footage.
Cameras use a 4 pin socket and computers can use 4, 6, or 9 pin sockets.
Determine which socket is on the trget computer and buy the necessary cable.
FYI: Most Laptops use 4 pin and most Desktops use 6 pin. Avoid adapters if possible.
For example; if your Desktop computer has a 6 pin socket you buy a 4 to 6 pin firewire cable. Firewire is also called iLink or IEEE 1394.
Feb 23, 2011 | Sony DCR-HC54E Mini DV Camcorder
Hello, My laptop does not have a firewire port. What do I have to do to transfer video to my laptop from my GL2?
What brand and model is your laptop?
Since we don't know the laptop model I have to cover a little more info here.
Most laptops have at least 1 expansion ports available on the side and you can use that to add additional ports or features if needed such as Firewire, USB2.0, or Ethernet, etc
Older laptops came with 1 or 2 full size PCMCIA ports. Those are rarely used anymore.
Newer laptops usually have an ExpressCard port.
These newer cards come with either 54 or 34 pins so you'd need to get the right one for your laptop.
For example, view the main ExpressCard info here
http://en.wikipedia.org/wiki/ExpressCard
Be aware that Firewire is officially known as the "IEEE1394" protocol. So some sites may refer to it with that name and it's the same thing. Apple calls it Firewire and Sony calls it iLink.
There are several different pin configurations for firewire.
Original 400Mbps speed Firewire from 1995 has a mini 4 pin or a full size 6 pin cable.
Newer Firewire 800 has 800Mbps speed and is called 1394b.
That has it's own cable connector as well and is not very common. It's much faster than USB (even Firewire 400 is ) but it didn't get used a lot.
The firewire connector s are visible here:
http://en.wikipedia.org/wiki/IEEE_1394_interface
The Canon GL2 uses the original 400Mbps 1394 protocol but the connector might be proprietary since it appears to have 5 pins.
It's visible here from the user manual.
There are 6-pin sockets and smaller (non-powered) 4 pin sockets and they are both still "firewire" but the small one has less options since it has no power connections with it. So the small connections can send data but can't run a portable hard drive or anything that needs power.
The small connectors are used for laptop ports and camcorders while full size desktops usually have the full size 6 pin ports. So to connect the 2 they make adapter cables with one of each type on each end.
Such as this one:
http://www.amazon.com/Phoenix-IEEE-1394-4-Pin-FireWire-Meters/dp/B000165AS0
That fits most applications but I think the Canon cable is proprietary, so hopefully you have the original cable.
So,
You probably need a laptop 1393 DV expansion card, DV editing software and the right cable. The socket on the GL2 doesn't look like a typical IEEE connector in the user manual so that may be Canon specific. If you still have the original cable that came with it then you're all set.
You can find a laptop expansion card online such as doing a search on Amazon.com with the words expresscard + 1394 and you will see many ExpressCard adapters to pick from.
Get the laptop 1394 expansion card that matches your Canon Cable and that can plug into your laptop on the other end (choose the right 54 or 34 pin type) that matches your laptop.
Jul 25, 2010 | Canon GL2 Mini DV Digital Camcorder
Hi i have a jvc grd250u mini video camera
Try googling IEEE 1394 and accessing the Wikipedia site. It shows a picture of both. The 6 pin is decidedly larger and of a different shape.
Oct 05, 2009 | JVC GR-D250 Mini DV Digital Camcorder
Windows vista won't pickup my jvc mini dv camcorder
try finding a driver from the manufacturer of the device windows vista sometimes can not find drivers for certain stuff
Sep 01, 2009 | SIIG 4 x 4-pin Type A Female IEEE 1394a -...
Do I need a fire wire card for PC
Hi a firewire input is different from an 1394 port. For the laptop you can buy an firewire interface.
Regards,
Rob NL
Apr 16, 2009 | JVC GR-D370 Mini DV Digital Camcorder
My GR-D77OU jvc camera
IEEE 1394 doesn't work like USB so it probably won't show up in devices. What you would do is go to a video editing/burning program and click on a capture video option. The program accesses the video camera and you can choose what video you wish to record onto your computer.
Apr 08, 2008 | JVC GR-D370 Mini DV Digital Camcorder
JVC GR-D20EK Camcorder Logo
210 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
