Question about Panasonic SC-AK66 CD Shelf System
Sound and speakers
When i turn the stereo up to loud the cd will continue to play but no sound comes out of the speakers its like it can't handle the loudness but its 280 watts i dont get it
    Problem Solver:
  • 29 Answers
Check the speakers connections. The speaker cables may be shorted. Turn the unit off, check and correct the connections and turn the unit on. good luck :-)
Posted on Jan 12, 2006
SOURCE:
Adcom gfa-5500 sounds like **** when turned up loud,whats the issue? distortion lights dont come on.
Your Speakers Can Only Handle So Many Amps Sent From Your Amplifier Adjust Your Amp To Pair With Your Stereo
Mar 17, 2012 | Audio Players & Recorders
I connected a after market stereo in 2000 yukon the stereo turns on but no sound comes out and the stereo good what might be the problem?
If you got the stereo used the speaker wires might not work. I stereo only puts out sound thru the RCA output using an amplifier.
Aug 18, 2011 | Chevrolet Tahoe Cars & Trucks
I have a Kenwood KDC-MP435U radio in my car and when ever I turn in up kinda loud it will shut off and come back on on its own. Any idea why this is or how I can fix it?
The wattage of the speaker is higher than the required wattage of the stereo. The stereo cannot drive the speaker very well. Use an amplifier if you want to have a loud sounds. Or if you already have sound set-up make sure that you have a capacitor for your amplifiers and fuses to support the power input to your stereo.
Apr 07, 2011 | Kenwood KDC-MP435U CD Player
I just hook up an after market cd player up in my 2001 chrysler 300m and the radio play but the cd player want play, it turns on and everything just no sound. do anyone have any ideas of what i did wrong?
DOES THE RADIO PLAY? HERE ARE THE FACTORY WIRING COLORS FOR THE RADIO HARNESS, RECHECK YOUR WORK. IF U FIND NOTHING THEN IF THE RADIO PLAYS THE CD PLAYER IS DEFECTIVE, IT HAPPENS BELIEVE ME.
2001 Chrysler 300M Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis or Strap
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange
Car Stereo Antenna Trigger Wire: Orange/Red
Car Stereo Cell Phone Mute Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: Located under the rear deck in the trunk.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Nov 05, 2009 | 2000 Chrysler 300M
Left front and rear speakers sound muffled when playing cd's
after you play a cd while the cd is playing go into your audio settings and adjust theres settings foe each part on a stereo if u set the audio for AM//FM then play a cd the stereo changes to the cd settings
Jun 01, 2009 | Jensen Car Audio & Video
I love loud music
i have alpine stereo's in all my vehicles and i have had this problem. if you run a 10-14 gauge constant wire from the stereo directly to the battery the stereo will not shut down in protection mode. it is not the cd it is the stereo going into protection mode because of lack of current not voltage. i hope this helps after i did this i could play the stereo as loud as it can go until my battery died
Oct 28, 2008 | Alpine CDA-9856 CD Player
Delayed Sound from Center Speaker
Go to this website, make an account, go to support, help center. Thenfollow the instructions and you might get your answer.
Hope this helps. :)
Jan 21, 2008 | NAD T762 Receiver
Stereo System Doesn't Make Sound
Tell your son not to play with your stereo.
Sorry that was a bit blunt. The Speakers from a bose system generally run at about 4 ohms of resistance, your sherwood amplier is spitting the dummy because it can't handle that sort of a load. get some proper speakers and make sure that they are connected up properly, and that none of the cables are touching.
Dec 11, 2007 | Bose 901 VI Main / Stereo Speaker
Sound problems
are the cds you are using copys or originals as sometimes the copy wont give you the stereo sound that you want but if you are getting stereo sound through the radio and all speakers are working there should be no reason why you dont get sound through all 4 speaker through the cd as they all go through the same channels and produce sound the same way as the radio the only problem i ever had with sound was that the copys wouldnt give me stereo sound but the only other problem could be is that the cd player in the unit is damaged or something come loose on the actuall cd unit in the player itself have you tried ajusting the loudness of each speaker and see if their is any sound at all if not and you are using originall cds then their should be no problem with the sound you could try turning the stereo sound off and have it on mono then see if you get any sound in the other speakers if not then it is fault with the unit itself this can be difficult to repair and expensive to get parts for how old is unit try playing round with the speaker volumes if this dont change anything and the mono and stereo sound dont change anything then it will need to be repaired so i would sugest to take this to repair shop as this would be difficult to repair hope this is some help to you ........................................
Nov 17, 2007 | Alpine IVA-D310 Car DVD Player
Panasonic SC-AK66 CD Shelf System Logo
118 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Joaquim Martins
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
