Question about Toshiba 46H84 46" Rear Projection HDTV-Ready Television
No pictue but sound works
The TV will turn on and the sound works but the screen won't turn on at all. From what I can tell the tubes aren't glowing at all. The screen doesn't appear to be getting any power. Is it a problem with the hv splitter or possibly the deflection board and if so could you define what part? I might try replacing the deflection board. Is this the right part? http://jr.partsearch.com/Part/Toshiba/Toshiba/46H84/Toshiba/Toshiba/23762135/New.aspx Thanks
techman
  • 3130 Answers
SOURCE: Toshiba model 57H81
If you have zagged lines there are 10 small surface mounted capacitors you will need to change on the HYper Board. This is not an easy repair so alot of folks simply replace the hyper board. You will need a service manual to take this set apart and to get the proper part number. If you have no TV repair experience or do not know how to solder, as the hyper board has sheild arounfd it, you should play it safe and call out a pro to assist you in this repair. Good Luck
Posted on Mar 19, 2007
  • 375 Answers
SOURCE: Toshiba 46in Rear Projection TV Model#46H83
sammy jo ,you burnt the tubes by leaving it on with a vertical collaspe faultmnow you have three damaged tubes,i also think that you also have a bad yoke which is taking out the new parts ,the cost is within reason,the shop repair is to insprct it deeped for possible other faults and damage already done.
Posted on Dec 16, 2007
ctf1800
  • 4402 Answers
SOURCE: no power
push down and turn
Posted on Jan 17, 2008
Slinteriors
  • 8617 Answers
SOURCE: relays wont click on when
have you checked your fuse? Will the relay click when you press power? You may possibly have a bad relay or the bridge rectifier diodes could be open.
Posted on Jun 18, 2008
Slinteriors
  • 8617 Answers
SOURCE: We are looking for a
The deflectionmodule will be almost impossible to get. However it sounds like you quite possibly only need a flyback 259296 and the HV splitter which are the two most common items to fail. you can get both parts at the following link along with free online tech support so you can repair your set yourself, or they can rebuild your Circuit board. Leave them a email include the model number and what you need.
http://servicemanuals.vstore.ca/
Posted on Jul 13, 2008
My Samsung tv is old and the screen just won't
check whether the sound is there.
find out the picture tube filament is glowing or not. If it glow then you check the G2 voltage (<350v)
Increase the screen voltage on FBT and check the light come on screen or not.
Aug 24, 2011 | Samsung Televison & Video
No red pigment on Screen
Pull back to TV turn on watch to see if all 3 tubes are lighting up if Red is lighting but no red CK projection Fuild in Tube, look down into lenses if you cannot see pictue clearly then Fuild is Bad.
Sep 21, 2009 | Panasonic Televison & Video
The light stays on but there is no pictue or sound
picture tube shot or conections to the tube faulty take to a tv repairman
Jun 21, 2009 | RCA 24V412T TV
No picture at all,sound ok 3 tube crts off after 4secs when on
might be a crooked flyback transformer, first check for shorted transistors around the transformer and components at the horizontal output stage..
Mar 31, 2009 | Philips Televison & Video
Projection TV keeps shutting down
Good Day;
Sounds like you have a bad green picture tube that has failed. To check this out; remove front speaker grill, remove small panel, you will see three CRT's (pictue tubes) sticking down, remove the little board on the middle tube then restore power. If TV stays on more then likely the CRT is bad but not always the driver on board could also be bad, check voltages.
Good Luck, big IRISH.
Sep 05, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Sony KP-53V35 - red tube issues
In my computer the red tube is working properly. all pictures are not playing continuesly
Jun 19, 2008 | Sony KP-53V35 53" Rear Projection...
Rca projection tv has no picture or osd
Check the bulbs. If one is burned out, you will get this problem. The bulb is easy to change but will run you about $300.
Feb 10, 2008 | Televison & Video
Screen went black, no picture
A clue to what is wrong is by looking from the back (taking the back off) and looking to see if the three picture tubes have any yellow glow at the bottom of them where the three identical boards are located on each tube.. If you have no glow there you possibly have a resistor R4703 open. It is a 3.3 ohm resistor and feeds the voltage to the filaments in each tube where the glow is suppose to be. If you do have the glow the problem could be much more complicated. Another to check is to see if the menu comes up on the screen. You could possibly be in the wrong input mode, Check your input mode with the input button on the remote The number R4703 is a location number to identify where the resistor is. This is all I can tell you that would not require much more complicated procedures requiring a tv repairman to look at it. If you have an ohm meter you can check R4703 but it must be checked out of circuit. (or at least one leg loose) Hope this helps
Jan 04, 2008 | RCA P52930BL 52" Rear Projection...
Mitsubishi tv model cs35405
it sounds like you might have lost one of a number of things that cause sound but no picture . one which is common is loss of filiment voltage to the crt
Dec 15, 2007 | Sony KV-35S40 TV
Toshiba 46H84 46" Rear Projection HDTV-Ready Television Logo
27 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
