Question about Nintendo Wii Console
How to Get a Foreign Object out of Wii CD Slot?
My 3 year old inserted a tiny, rubber thingy in the disk slot, and now it won't work. How do I remove the cover to get it out?
  • 928 Answers
You may follow the video at the link below. Please see it as soon as possible.
http://www.metacafe.com/watch/757800/opening_up_nintendo_wii/
Posted on Sep 06, 2008
My dvd is stuck inside the dvd tray, how do i remove my dvd from my naxa ntd 2256
I was not able to find the owner's manual on the manufacturer's website, so I'll make a general suggestion: look for a small hole next to the DVD slot (it may be at the end of the slot rather than outside of it). Straighten a paper clip, and carefully push it straight into the hole. When the paper clip wire touches a stop, push it a little bit further. If you feel it moving a part inside, you've found the emergency eject commonly incorporated into optical disk readers. Push it another couple of millimeters, and the DVD should pop out (if the DVD loader mechanism is not broken).
If there is a possibility that a small child has inserted a coin or other foreign object into the slot, you may have to remove power from the set, take the back off, then remove the foreign object. Otherwise, the DVD player will be unusable.
Aug 27, 2017 | Televison & Video
Coins in macbook cd slot
This happened to me yesterday. My 3-year-old stuffed the Macbook's DVD/CD slot full of game tokens, hoping that one of them would play a movie. Took me his entire naptime to extract them, but everything works fine now.
First, open the guts of your laptop and remove the optical drive. Depending on your model the appropriate guide should be here:
www.ifixit.com/Guide/search/macbook+optical+drive+replacement
Among those I found the following excellent guide for mine:
http://www.ifixit.com/Guide/MacBook+Core+2+Duo+Optical+Drive+Replacement/518/4
Once the drive is out you can skip most of the remaining (replacement) steps, since you're putting the same drive back in.
Now switch to the following guide to get foreign objects out:
http://www.ifixit.com/Guide/Optical+Drive+Disc+Removal+Technique/772/1
Jan 23, 2013 | Apple MacBook Mac Notebook
Aspire one keep saying no bootable device insert boot disk and press any key and I don't have a disk slot
You hard drive is missing from the system. Or, just does not recognize it. The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB... Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Nov 19, 2012 | Computers & Internet
Wii makes grinding noise, when disc is inserted, it immediately ejects it, accepts it back in, then ejects it onto the floor while making horrible grinding noises
There is either something inside of your Wii's DVD Drive blocking the insertion of the disc, or some of the gears inside of the DVD drive are damaged. Lots of times, one of the kids will stuff a penny, credit card, or some other foreign object inside of the Wii's disc slot. The following website sells the DVD drive mechanisms and does repairs on the Wii as well:
http://store.richspsxparts.com/wiiredvddr.html
Jan 15, 2010 | Nintendo Wii Console
CD/DVD drive will not accept any disk I try to put in it.
Do you have any small children in your house?
Seriously, I have 6 children. One (or two) of them put a quarter and two flat washers in my slot load CD drive. Took me over an hour to take it apart to fish them out.
I've also had a friend whose young children managed to get 2 cds into the slot load at the same time.
So, my primary suspect is a foreign object has gotten into the drive. I've never had a CD/DVD drive fail on an iMac other than that.
However, if it is a foreign object, you will need to take it in for repair, most likely. It is difficult to see in there. and even more difficult to grab the object.
I suppose that the cable could have become disconnected. I really doubt that the drive was a lemon, seeing that it worked for a year.
Apr 05, 2009 | Apple Mac OS X 10.4
Eject
frist make sure you are inserting the disk correct label side up or label to the right if you are which you mostly Are then your console has a propbelm with feeder which mean it must go back to the store
Jan 03, 2008 | Nintendo Wii Console
Nintendo Wii
From the official Nintendo website:
"Object inserted into the Disc Slot If an object is inserted into the Disc Slot, it will automatically be pulled in, and it won't be possible to eject it. Do not attempt to open the Wii console or otherwise try to remove the object, as it may result in further damage to the console.
The Wii console will need to be repaired. Because this type of damage is not covered under Nintendo's warranty, there will be a charge for the repair. Please call 1-800-255-3700 to discuss available options."
Nov 17, 2007 | Nintendo Wii Console
There is a sd card stuck where the cd should go. There is also a disk there. Do you know how to fix it?
If you can see the SD card, Get a toothpick and wrap Tape onto it then reverse the tape so that you have sticky on outside. See it you gcan retract it that way. You risk damaging the Disc eject system if you try to force the disc to eject by pressing the eject button more than 10 seconds. Once you get the SD card out you can do the 10 second eject button thing.
Nov 15, 2007 | Sony Playstation 3 (PS3) Console
Nintendo Wii Console Logo
2,913 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
