My frontload washing machine makes a lot of noise during the spin cycle. It appears that the drum is loose or not in its track. It there a way to fix it myself before I spent a lot of money for a mechanic?
    Novelist:
    Champion:
  • 261 Answers
First grab the steel basket and see if it wobbles. Second check for leaks underneath, there is two screws at the base of the kick panel to check, looking for wet stains at the back of the machine or pull it out and unplug it remove the screws on the back panel. Next watch out for any edges they are sharp!, I have scars to prove it. Ok you will see a flywheel with a belt attaching it to a motor. Grab the flywheel and apply some pressure up and down and please look for water stains. Any movement? Check the nut or torx bolt first for looseness, it may only need to be secured better, If not and you see water you will two guys and good digital camera and part 134453200 which is a fully assembled basket and tub ready to go, the camera is to take photos of all the stuff which is attached, it will be easier than a grainy stick drawing when re attaching. TIP the pin on the shocks can be depressed with 1/2 deep well socket and the pump boot only need to be unscrewed from the tub after carefull viewing of the boot where it is attached, it is a little tricky, good luck.
Posted on Sep 07, 2008
Started making a lot of noise during spin cycle. The drum seems loose. How do I fix?
Big job replacing bearings damaged for sure you can buy kit for it on internet washing machine spares hope this helps
Mar 06, 2016 | Bosch Nexxt 300 Series WFMC2201UC
Noisy spinning
First make sure that the load is balanced, if you are washing and spinning a dense load like trainers etc this can cause an imbalance. If you are washing a duvet cover or a pillowcase, make sure that the loose clothes washed with it haven't migrated inside the cover or case, this happens so easily. It is always worth checking that the support feet are all touching the ground when the washing machine is empty as this can cause excessive noise
hope this helpsKind regards ki
May 11, 2015 | Washing Machines
Drum appears to be loose and makes a lot of noise when on the spin cycle
With the washer empty, spin the wash tub by hand. The drum should be spin true without any noticeable wobbling and spin without much noise. If it wobbles or makes any kind of rubbing or banging noise as you turn it by hand. The problem is that the spider support arms are broken. It is an expensive repair job since the washer has to be completely torn apart and the wash drum needs to be replaced. Get a few estimates before deciding whether to repair or replace. Sorry.
Mar 08, 2011 | Whirlpool AWM6100 Front Load Washer
The washer shakes uncontrollably during the spin cycle also a loud banging noise is heard during the spin cycle.....
If front load check the inner drum If it is loose at all you have a lot of problem . Very expensive.
Nov 17, 2010 | GE Washing Machines
During the spin cycle the washing machine becomes VERY noisy, sounds like its off-balance, but happens EVERY time, even with very small loads. The whole unit doesn't move when it happens, just extremely...
During the spin cycle the drum moves at a higher RPM and so the counter weight of the clothes within can make the drum rotate eccentric or out of sync.
So check if the belt is loose on the motor, checck if the spindle is tight with friction or the drum assembly suspension is out of alignment.
You must check the reason with the following points to confirm the drum spinning making noise. check point of noise , is this on hitting the sides , or from the motor, any foreign objects or the drum spindle. But you are the judge with a first view. Use good lighting to look out and confirm the fault.
Sep 16, 2010 | Frigidaire FEX831CS Top Load Stacked...
Makes clunking noise when changing modes--does not spin dry
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 24, 2010 | Amana 3.2 cu. ft. Top-Load Washer
My Frigidaire frontloader is not spinning until dry. The drum appears to be banging against the interior, making a loud noise.
were the drum support brackets removed after purchase? you may need to open the front access panel and remove two brackets that support the drum during shipping. also at the rear are support screws that need to be removed
May 09, 2010 | Frigidaire ATF6000ES Front Load Washer
Wfw8300sw01 - makes loud noise sounds during spin
The bearings have collapesd due to the seal going faulty. If bearings can be accessed to from the outside, it is possible you could do the repair. If big bearing and seal is accessed from the inside, suggest tech. do it as it gets dirty and a lot more complex.
Sep 20, 2009 | Washing Machines
My LG TROM wash googd but dosn't want to spin
Check and see what type detergent you are using. I bought regular liquid detergent and the machine began making noise during the spin cycle and the drum would not spin. I was informed that you have to use detergent that is labeled HE (High Efficiency). The regular liquid detergent will suds up during the wash cycle which then causes the drum to slip and not spin during the spin cycle. What you are hearing during the spin cycle is the drum slipping. Unplug your washer for 30 minutes and let it reset. This lets the suds dry out. Run a cycle with no spin to rinse out the drum. This should eliminate your problem. If you have clothes in the machine, run a cycle with no spin, just don’t add any more detergent. Then run the normal cycle with spin a second time with no detergent. I hope this cures your problem.
Apr 11, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
During spin cycle started making loud noise now drum feels loose
during spin cycle it makes a lot of noise could it be the bearings that have gone
May 17, 2008 | Hotpoint First Edition FEW12 Front Load...
Washing Machines Logo
148 people viewed this question
Top Washing Machines Experts
