FixYa.com
Tags:
Epson Projector Lamp for EMP-50, EMP-7
Problem with the lamp (by 3 users)
posted by jjredox on Jan 11, 2006
I have used my projector to display photos on a screen from a computer. Everything was fine and i turn the projector off at the end of the presentation.
The next day when i wnated to use it to watch a movie, the lamp led had gone flashing red...
I thought the lamp was broken because i moved the projector and break it, so i bought a new one (really expensive)
After placing the new one..... the led is still flashing red =(
I think there's another problem than the lamp behind this... Any ideas??
Thank you very much
Remi
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by buddur, posted on Jan 09, 2008
Projector switches on and display pic for a minute then red lamp flashes and unit shuts down.
CLeaned all fans, contacts etc. lamp is obviously still working.
Comment by Kapem, posted on Nov 26, 2007
I have change the lamp for the Epson EMP-50 and the red led still flashing
Best Solution
posted on Feb 02, 2006
FixYa! (100)
Boba
Rank:Wiz Wiz
Rating: 83%, 161 votes
According to Epson the led will flash red in one of two cases:
Flashes red with 1 sec intervals - either the lump has burned out(We can rule this one in this case) or the lamps cover is open (try checking the cover's sensor)
Flashes red with 2 sec intervals - an internal problem, I'd suggest contacting Epson's support.
Good Luck
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Multimedia Projector Replacement Lamps problems?
Continuity test for a projector...
Can I use an ohm meter to test... Answer This...
invert image on projector
i have a generic chinese... Answer This...
magnavox replacement remote...
a some where to purchase one in... Answer This...
serial port
a serial port was broken off... Answer This...
image is flickering
The ?flickering? of the... Answer This...
Repair Service
Find Multimedia Pro. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
