Question about Sharp Microwave Ovens
Control panel light
The controls work, but the light can't be seen. Is there a way to replace the light without going to a repair store?
  • Sharp Master
  • 8,872 Answers
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If you don't have your instructions, please reply back with your brand and model number.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Sep 07, 2008
Counter top lights not working. new bulbs replaced. still not working.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Sep 04, 2012 | Panasonic NN-H275SF Microwave Oven
The light bulbs that light up underneth the microwave don't work. I've replaced the bulbs twice but they still don't work.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a one year guarantee.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Jan 01, 2011 | Whirlpool Microwave Ovens
Clock on control panel works, control panel counts down when start is pushed, light inside doesn't work nor fan or light under unit. I replaced fuse but wasn't the problem. Any ideas? I first noticed...
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
Dec 02, 2010 | Whirlpool MH1150XM Convection/Microwave...
Over range lights not working
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
Jan 30, 2010 | Amana ACM1580AS Microwave Oven
Replaced microwave bulbs, light still doesn't work.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Jan 10, 2010 | Panasonic Microwave Ovens
My over the range microwave oven light(underneath) does not work. The bulbs were tested, they are OK. Is there a fuse to replace?
Maybe. In some Whirlpool models there are several fuses.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
I doubt that it's a fuse, though. We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
prototech@usa.net
Jan 09, 2010 | Whirlpool Microwave Ovens
We had a lightning strike near our home and our Ewave OTR microwave quit, nothing works but the light inside and the vent fan comes on automatically. We've been told that there is a fuse that can be...
If the light and fan work then it cannot be the fuse. When the fuse "blows", it stops the electricity totally from flowing into the microwave and nothing will work or respond. The fuse is behind the control panel and this requires several hidden screws to be removed. Also, you must be very careful of the 2000 volt charge that is stored in the wiring further into the compartment behind the control panel. Therefore, do not attempt to open the micro control panel without proper service knowledge.
Because you say the light and fan operate, the fuse (as I stated ) is not your answer; most likely the problem is in the control panel circuit board. The circuit board is like any sensitive electronic component that goes crazy when there is a voltage surge that strikes it such as lighting throughout the house wiring. The board needs to be replaced unless you can have an electronic wizz-kid test is out and repair it , or just by a new board. By the way, the board is not cheap and may be difficult to locate since I understand the the manufacture stopped producing it.
Aug 13, 2009 | Microwave Ovens
Fan lights don't work.
The lights can can be inoperable or stuck on or no bright, too. Sometimes this will similarly affect the exhaust fan operation or inside light, too.
prototech@usa.net
Aug 01, 2009 | Kenmore 62622 Microwave Oven
Surface lights
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
Dec 18, 2008 | Frigidaire FMV157GM Microwave Oven
Fan and Lights do not work
Sorry a bad controller printed circuit board or what GE calls a smart board. I have seen these smart boards as low as 85 bucks, go up to a price of 179.00!
Sep 18, 2006 | GE JVM1651 Microwave Oven
Microwave Ovens Logo
44 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
