Question about Panasonic Televison & Video
We lost our electricity this week, and since then the RTune button on our remote control will not work! Plus with the up errors to scroll channels it will go up to channel 22 and then goes back to channel 2. Frustrating, to say the least. If you have some solutions they would be appreciated. Tks. Marion
It was a question of using the programming menus in the correct order.
Confusing TV !!
Posted on Sep 07, 2008
I have lost the remote for my tv. How can I change from tv to video on the tv itself? I have tried hitting the source button then scrolling to video with the channel buttons but nothing happens
Unfortunately with most tv's today, you can't do much other than change channels or volume control without a remote.
Do you have an input button on the tv, if so, that will allow you to change from TV to video.
Jun 07, 2015 | Televison & Video
Lost Remote Control? Here's a way to help.
So you have lost, or, your remote doesn't work? You can't "Do anything" without it.... Right.... NO Wrong... ALL TV sets have a number, usually about 5 - 6, "Buttons" on the side, front, somewhere. usually close to the "Power ON" switch. Now these "Buttons" will perform nearly all, if not all, of the main functions of your "Remote" They WILL be marked, MENU, +, -, <, >, & OK or ENTER. Now you simply have to depress each button to access the "Functions" you want. One button WILL control the "Function" say Channel, and the <, >, will Go UP & DOWN. This is the same for everything. So one button will make it, say go UP, another will make it,say, go DOWN. Repeated presses on the "Function" Button will scroll through the "Functions" IE: Channel, Brightness/Contrast, Selecting Inputs, once "Selected" another "Button" will move the "Selector" through to the Bottom & another will scroll it back Up, sometimes the ONE button will simply continuously scroll "right around" Of course have a look in your manual... you know that paper thing you shoved away in the cupboard... This will explain it all. ALL TV's and devices that use a "Remote" are ALWAYS able to "Control" the MAIN functions of the unit,via keys on the actual unit itself. So don't despair, just spend a bit of time learning your "Buttons" that way even if the "Remote" does go walkabout, or the batteries go flat, or it just stops working.. well now you can still have complete control.. the only draw back is you will have to get put of your seat to do it. A small price to pay?
on Feb 13, 2010 | Televison & Video
Scroll channels with TiVo remote control
Use the Ch up and down button on your remote..It is opposite the volume can scroll through channels quickly. Hope this helps
Aug 04, 2012 | Tivo Televison & Video
Toshiba tv 40rv525u has started to change channels
My TV 40RV525U changing channels, menus itself for few months ( I use antenna).
my son tried to stop the channel scrolling by enter weird number into the channel to stop it scrolling such as 555, 777..
later, it turn on off by itself and unable to hold on a channel
I call Toshiba customer service and they ask money $25 for troubleshooting but I denied since I do not want to waste money and time.
Now, I found how to fix it myself.
In my case, something was wrong with the signal comes from the button control on the left side of the TV.
What I did
unplug the power cord.
Remove back cover.
Look into the motherboard ( biggest green at the center).
First, I disconnect a connector on the motherboard come from the IR board that receive the wireless signal control ( meaning the remote is disable).
I turn on the TV, press on Menu button on the TV side. Menu is still scrolling.
I turn off TV, disconnect power cord and connect the IR connector back to the motherboard.
I then disconnect the nearby connector that comes from the side control buttons.
Turn on the TV by remote, press menu button on the remote to check. The menu stays.
I use electric tape to seal off the connector and let it hanging there.
Close the TV back panel
I have been watching TV for 3 nights without menus/channels scrolling.
NO AVAILABLE red message when watching DVD is no longer existed.
Hope this help someone else.
Jan 20, 2012 | Toshiba 40RV525U 40 in. LCD TV
Toshiba 40rv525r screen says NOT AVAILABLE
I've had the same issue! This is caused by the control panel telling the TV what to do - does it change channels on its own, too, or turn off or on on its own?
What you need to do (if you've not already done it) is lock the control panel out, which you can do under the LOCK menu.
What may help is running the factory reset on page 54.
Mar 22, 2010 | Toshiba 40RV525U 40 in. LCD TV
The remote actions things twice with one button push
technically we call it debouncing it causes due to the faulty microprocessor in remote also it can happen due to faulty carbon contacts of remote below buttons.the solution to this is to replace remote but before that do one thing 70% THIS WORKS open ur remote then take a dry cloth & clean the surface below buttons if u r lucky then remote will be OK
Mar 14, 2010 | Logitech Harmony 550 LCD Remote Control
Channels Missing
All my channels are missing what are the new codes
Jun 10, 2009 | StarView SV211K 2-port KVM...
Mitsubishi WS-65611 tv channels cannot stop scrolling
Check to make sure the channel down button is not stuck. If it is not the button is probably defective. Mits has had a lot of problems with the buttons.
Jan 21, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Lost booklet
link to codes is at bottom
Great News!! We can program most Philips Universal Remotes with Automatic Code Searh. Here's how it works on most of our remotes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
The above assumes that you want to store the VCR you want under the VCR but, Cable codes under the CBL, etc
Note: if the device does not have a chat channel at a button, you should Play (VCR only) or Power instead.
Here is a Code List on PDF that shoud be universal for most remotes. It worked for me.
Hope this helps you out, good luck.
Nov 24, 2008 | Philips Magnavox Learning Universal Remote
Televison & Video Logo
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
