Question about RCA T20062BC Combo
Power went out, unit won't turn on now.
We lost power in our building, then had a period of "brown out" where the computers worked but there didn't seem to be enough voltage for the video electronics which were trying to turn on. When power was restored the T20062BC Combo would not turn on.
    Problem Solver:
  • 29 Answers
A fuse or circuit breaker may be blown or switched off. Check the fuse or circuit breaker. Test the outlet with a lamp good luck
Posted on Jan 10, 2006
2005 Chevy Colorado LS 5.3L Blower motor iOS not working. Replaced the resistor because that was burnt out but it didn’t fix the issue. Figured out the connector only gets power at the brown wire and...
The top wire at blower motor is voltage, the bottom wire is ground. So brown wire is voltage, orange wire is ground. So, the resistors, havc control, on and off and speeds are controlled on the ground circuit. Generally if ground is good, no voltage or very little on the ground circuit, because the component is using the voltage. The wire connector for your blower motor is it any good? You could remove blower motor, use jumper wires off battery for voltage and ground, the blower motor should run up a storm. It wouldn't hurt to use inline fuse, just incase.
I looked at info for 3.5L, my info didn't show 5.3L?
Oct 28, 2017 | Cars & Trucks
Ac to DC power supply
A rectifier is an electrical device that converts alternating current (AC), which periodically reverses direction, to direct current (DC), which flows in only one direction. The process is known as rectification. You can't run DC through a transformer to change voltage/current because it works on the building and collapsing of the field that comes with the sine wave of each phase. DC is just a straight line.
Apr 07, 2017 | Power Computers & Internet
My whirlpool microwave model gh4184xsb needed a new cooktop light bulb so I removed the cover to replace it. I didn't unplug it (BAD!) and there were sparks and the microwave lost power. We repla
there are short. go to www.repairclinic.com for to get the parts.
2) test the switch door for short and replace see the diagram
3) test the high voltage capacitor+ high voltage diode
see the diagram
7_15_2012_12_42_08_pm.gif7_15_2012_12_42_27_pm.gif7_15_2012_12_42_40_pm.gif7_15_2012_12_43_03_pm.gif7_15_2012_12_43_25_pm.jpg
Jul 15, 2012 | Microwave Ovens
My IBM server x226 not starts. SMPS working after that part with battery lights on then suddenly stops. pls tell me solution pankaj
Welcome to fixya
This should be a power cage problem. If server didn't get enough power from the power supply it will stop suddenly when power on server . Your complaint seems to be the same . Replacing the power cage will fix the issue
Thanks
Jan 12, 2011 | IBM xSeries 226 Server
1997 Audi died, lost power acts like bat dead but then starts?
the alternator is not charging and once you run out of battery power car dies when you let it sit battery builds a small charge enough to run short period of time.get charging system checked.
Jan 12, 2010 | Audi A6 Cars & Trucks
WR55X10697 unit will not defrost
GE's which use these electronic control boards are very temperamental and are susceptible to power surges and brown outs, etc. In addition, there could be another problem causing it to build excessive frost. Defrost heater and/or thermostat (bi-metal). I recommend calling and experienced technician.
Aug 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
WAS working fine but seems lost part of listening frequency (IC Burnt??) Help
I had a similar problem with popping and then no audio for an extended period of time. I found the solution on another site, http://dexsoft.com/blog/?p=15
Apparently the solder joints are weak, and just a the blog described when I opened up the receiver I saw the same scorch marks from overheating. Just as the blog described, I added solder to each of the joints in the photo and have had no problem ever since.
I am no solder expert, this is my 2nd time, but all I did is build up each of the joints and I have been listening to music, playing movies in surround sound with no problems for the last 2 weeks.
Feb 21, 2008 | KLH R7000 Receiver
What is brown out
Brown-out .... What is it? Brown-out is a condition of lower than normal power line voltage being supplied by your local utility or generating equipment. This condition may be short term (minutes to hours) or long term (1/2 day or more). A power line voltage reduction of 8 - 12% is usually considered a Brown-out.
What causes Brown-outs? Electric utilities (your local, lovable Power Company) may occassionally reduce line voltage to Brown-out levels in an effort to adequately manage power generation and distribution during periods of heavy usage. Very hot days, when most air conditioning and refrigeration equipment would be operating almost continuously, is an example of such a situation.
Even without utility intervention, extreme overloads caused by most air conditioning and refrigeration equipment operation could tax the electrical distribution system to the point where a permanent brown-out state could exist over much of the power company distribution network.
Locations at ends of long electric distribution lines may experience chronic Brown-out conditions due to line loss. Intermittent heavy loads on this trunk circuit may cause the Brown-out effect to fluctuate with the load.
Installations using ship-board or temporary power sources are especially prone to operation in a Brown-out mode. Usually of limited capacity, it is quite easy to overload the power source, giving rise to permanent Brown-out. (Permanent Black-out, if users are not careful).
What are some common effects of Brown-outs? Brown-outs are the mother of all sorts of Bad Stuff.
Power supplies in some electronic equipment may fall out of regulation. Errors, due to erratic power supply performance, may creep into computer operations.Other electronic equipment may function poorly - or not function at all.
Marginally performing devices (electronic or electric) will probably cease operation entirely.
Motors will overheat. Some motor types will slow down.
Electrical interference will greatly increase. Increased interference may affect computer and communication operations.
Off-line UPS units (the vast majority of lower cost units) continuously cycle between power line and internal battery operation. UPS batteries (generally sized to provide only 5 - 10 minutes back-up) will soon be discharged, unable to generate additional Back Up power. You are out of business. If system has not been shut-down, the entire system (UPS & computer) may snap back to life when power rises slightly, only to again shut down when the power line voltage falls back into the Brown-out zone. Such "ON-OFF" operational cycling is unhealthy for UPS, batteries and connected electronics. For Brown-out correction see our Voltage Regulator Page.
Spikes generated by electrical machinery also greatly increase. Air conditioners, refrigerators and other motorized devices generate local spikes. Industrial machinery (often miles away) create additional spikes which may find their way unto the electrical distribution system, and into your sensitive, valuable equipment.
Oct 25, 2007 | Samsung RS2630SH Side by Side Refrigerator
Battery
When batteries are low and they are not used for a period of time, they can build up enough voltage to give a full battery indication. The batteries only had enough power to shoot one image. The batteries are exhausted and need to be replaced or recharged.
Aug 31, 2005 | Olympus Camedia D-425 / C-170 Digital...
RCA T20062BC Combo Logo
116 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
