Question about Sony STR-DE995 Receiver
My 2003 STR-DE995 goes into "PROTECTER" mode
Hey, hope you guys can help ? I've had a problem with my 2003 STR-DE995 jumping into "PROTECTER" mode, and shutting down when I listen Loud, ever since I hooked-up a pair of large tower Paradigm Studio 100 speakers as my main speakers, and I hear the Paradigm Studio 100s draw a lot of power. I unplugged from a muti-plug situation and gave it a "dedicatied" (just it's own plug) AC line which helped a little. It sits with open ventilation, However still a problem at peak "noise" levels, (applouding on a concert DVD) Overheating is not necceassarly the prob. as it has happened even before it warms-up. I have speakers running to all 8 chanels, so I'm "working it" but the suround speakers are minimal in size, and of course the subw. powers itself. I thought 100 watts would handle it. I'm thinking of hooking-up another amp to the system but have No clue as to how to go about it and maintain best sound integrity. I've read about bi-amping but don?t want to go buy an identical amp. / bi-wiring? I do have a 20 year old, but limeted hours "Bedini" amp and pre-amp (2-channel, 150 watts per) I could utilize. Then would I use the amp Only? Should I configure the pre-amp power to the big speakers only? The only amp outputs I see on the SONY is the ?Zone2?. I can hook-up to this, but I think I won?t be getting true surround channels to the main speakers will I? The Paraigm Studio 100 Speakers have the option to Bi-amp (separate Bass terminals / Mid & Tweeter terminals) Shall I hook-up the extra amp to say Bass Only ? Then do I need to use the Pre-amp w/the extra amp too? So I'll have to use separate volume control (which would suck) And Would be nice not to have to kick-on the second amp constantly as I only go Loud a small percentage of my listening. And the Bedini was a nice "clean" amp in it's day, but will this 20 yr old compromise the whole system by beig so "old-school" ?? Thanks Guys, I appreciate your time. Roy
  • 277 Answers
Re: My 2003 STR-DE995 goes into "PROTECTER" mode
Hi roy for starters hooking up more then 1 speaker to 1 input makes the total impedance higher\lower then the reciver "sees" there for u r causing the amplifier work hard and warm it up for no reason attach each speaker to 1 inlet look on the speaker for level of resistance (4 Ω, 8 Ω) and adjust the reciver for that level in that inlet if u want morn power ull have 2 connect the 2 amps in line as you sed, although the Bedini is "old-school" im sure it will do just fine and then u can crash ur whole house down from endless power... its difficult to say without any parameters what kind of connection will be the best result, so just try them all and see what u like the best keep in mind that loud music is hearting ur ears and if ull keep up this way ur wont be able to hear your child not to say when you will b older.... good luck windman
Posted on Feb 14, 2006
0 characters
3 Points
Sony str d1090 owner manual
You should be able to get a free PDF on the Sony website.
Aug 21, 2011 | Sony STR-DE995 Receiver
My sony str db790 is in protect mode, i have disconnected all the speakers and when i turn it on it goes in to protect mode again. i have connected back 2 speakers that i know have no faults and still it...
Hi Kevin, This may not be a solution but you`ve most likely burnt out the amplifiers, I have the same model and its just burnt out the amplifiers for the second time. I was`nt cranking the volume and it was running my Bose AM 5`s which are very good speakers.Its expensive to repair and not many tech heads will take on anything "Sony". If you do have any luck fixing it please get in touch. ** Regards, Neil.
Dec 11, 2010 | Sony STR-DB790 Receiver
I couldn't able to switch on my sony str db930 .when it was use it say me protecter.
Check all of your speaker connections... usually the PROTECT cuts in when speaker wires get crossed or you have blown a speaker.
this PROTECT message also shows if the amp chip(s) have blown in the unit
Sep 01, 2010 | Sony STR-DB930 Receiver
I have a Sony STR-DE995 receiver and surround speakers set up. However, most music material is not multi-channel. Is it possible to configure the unit so the rear speakers get the normal L-R stereo. I...
Stereo source material can actually sound pretty interesting when various DSP surround modes are applied to them.
Or you could seek out some multichannel music. Look on eBay for Super Audio CD's, DTS-CD's, Dual-Disc or DVD-Audio. Though these formats died on the retail battlefield they still can be found and will demonstrate some awesome capabilities of your receiver. I have about 100 of them.
May 25, 2010 | Sony STR-DE995 Receiver
Yes I have a problem with my sony str de 525 receiver its stuck on Protecter every time i turn in on it flashes protecter and i cant get it to stop what do i do
Disconnect the speaker wires from the rear panel, turn the volume down, and see if the receiver still goes into protect when you turn it on. If it doesn't, you need to check your speakers and wiring. You may have a speaker that's gone bad, or a wire that's shorted. Likely causes are too much insulation removed when you stripped the ends and now they are touching, the wire's been pierced by a mounting nail or staple, or it's been damaged somehow.
If the receiver still goes into protection with no speaker load, it's the receiver at fault. I have seen this problem caused by bad solder connections on several areas, bad components in the power supply, and trouble in the amplifier section.
I can't point you toward any specific "most likely" cause, but the bad soldering is something you can check by eye. Any other cause is probably going to require service by a technician who has the test equipment and service information to do more in-depth troubleshooting.
Good luck, and thanks for using Fixya!
Mar 05, 2010 | Sony STR-DE545 Receiver
Can't change FM input mode! Stuck at analog...
Tuner is only analog. As for the Video 1 input you need to go into the menu and change it to the digital port you want to use (optical, coaxial or HDMI) you can set only one input to each digital input port.
Nov 30, 2009 | Sony STR-DE597 Receiver
Sony str-de525 system "protector" problem
You've blown it. It recognizes a potentally harmful situation and goes into protect mode.
Mar 15, 2009 | Sony STR-DE935
Sony STR DB-930 Receiver jumping into protector mode
I went through the amp/receiver and used small star washers on all the grounding screws I could find including the one securing the transformer, cleaned dust off all circuit boards, checked output transistors and fuses, all OK.
Re Assembled unit and it worked OK.
I will buy a fan and fan it to avoid sourcing heatsinks for the previusly suggested IC's.
Thanks for the technical help, sure solved my problem.
Mar 07, 2008 | Sony STR-DB930 Receiver
Sony STR-DE995 Receiver Logo
222 people viewed this question
Top Sony Audio & Video Receivers Experts
Pieter Vleeshouwers
Are you a Sony Audio and Video Receiver Expert? Answer questions, earn points and help others
