Question about Dometic Rooftop RV Air Conditioner
Bent grates on the roof unit how serious of a problem is it??
My roof unit has bent grates, the thing that looks like a radiater, Got bent by a pressure washer.. How serious of a problem is that?
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
That is what removes the heat from the hot gas, if bent or pluged, it will make the system work a lot harder. Just take a knife and straighten them back, or go to a supplyhouse for ac and ask for a coil fin comb to straighten back out fins on a coil!
Posted on Sep 07, 2008
2001 chevy cavalier rear ended truck with hitch, which went through my bumper and bent some things along with puncturing my radiator
The bars are likely part of what is called your core support. They are structural items needed to maintain the dimensions of the fit of the rest of the front end parts.
Apr 09, 2013 | 2001 Chevrolet Cavalier
Dometic rooftop ac not getting cold
Could be any number of thing.
Things you can check yourself, get on the roof and see if the vents at the back of the roof unit are clogged with dirt or if the fins on the condensor ( behind the cover) are bent. If so clean the vents and use a comb to straiten the vents so air can flow. You can wash this out with a garden hose.
If that doesn't help and the unit is running the next stop is at a garage or camper store to see if the refrigerant level it low and if so why.
Please be aware the refrigerant should not leak out if it is leaking there is a reason and while recharging the a/c will help for a while it is only a temporary remedy.
Feb 25, 2012 | Heating & Cooling
I dont know exactly what happened my buddy had my bike out and wrecked it .. Looks like the front wheel came back into the radiator. Its not in the radiator now. But I know something is bent because the...
The forks usually bend well before the frame.
Take the forks off the bike and turn the chrome part in the fork leg and you will soon see if they are bent.
If they are only slightly bent a dial gauge will help.
Dont even think about having them straightened, get new ones
Jul 17, 2011 | kawasaki ZZR 600 Motorcycles
The sun roof won't close all the way shut. it opens ok and closes but won't lock shut
there shoulde be a hand crank (looks like a bent up allen wrench type thing) in the glove box...
there is a small hole in which it fits on the roof pannel... hand crank it tight to seal from inclimate weather.
Sounds like the switch is misalligned somehow.. and is stoping the glass short of full closed..
Open the glass full open and check the track area for debries and clear it out if there is any found.
use the tool to close the roof fully ...
Mar 31, 2011 | 1998 Chevrolet Cavalier
I bought a 1200 serious heat cool window unit.. I noticed when we removed it from te casing, that one of the copper tubes, a small two inch extention on the top was bent and crimped. This piece was a small...
Yes, that is the tube that was used to charge the unit...after the charging process the tube is often bent over, crimped and then soldered shut... that is perfectly normal and you should be okay...
heatman101
Apr 17, 2010 | LG Heat cool Window Air Conditioner
Radiator Protector installation issue
Normally at the end of the protector the rad grate is slightly bent to hold it in. If you bend them straight and slide them out the back this should work.
Oct 23, 2009 | 2004 Honda CBR 600 F(4)i
Bent A-Arm on a 1991 Chevy S10 Blazer...repair$???
I would guess $500 - $1500 to do this job depending on how much damage was done when the arm was bent.
"SMALL OIL AND TRANSMISSION LEAK AND THE RADIATOR LEAKS OUT SLOWLY." -- the radiator leak could get bad enough to require repair.
I think $400 obo is an okay price, can't get much lower for a vehicle that will get you to the store and back.
May 27, 2009 | 1991 Chevrolet S-10 Blazer
Motor g16A 16V, Borken cam belt, has it bent the valves ?
Hi, there is a posibility that it may have bent valves, install new belt ,if your engine misfire or dont start at all ,there are bent valves, be sure to aling the timing marks ,perfect.. good luck
Aug 24, 2008 | 1990 Suzuki Sidekick
Dometic Rooftop RV Air Conditioner Logo
166 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
