Question about Compaq Presario 700 470024-192 Notebook
Volume is set at 100. I turn it down at 50 and it slides back up to 100 on its own. How do I fix this? Thank you
I have compaq c700 notebook but i am unable to start bluetooth and wifi on it
Posted on Sep 15, 2008
Unlock volume
The volume settings might be locked to '50'. If you have to release this, and to set it into 100%, have to enter its service mode option. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window. Service mode entry, adjust and exit procedure to many popular brand TVs are given in detail.
Oct 27, 2013 | Orion1934 19" TV
Power outage
It sounds that the main system control memory IC data has been currupted.
Sep 26, 2013 | RCA L32HD31 32 in. LCD HDTV
I recently had my fender acoustasonic telecaster checked out because the volume kept shorting out. It seems the volume pot was dirty or had a short. Took it to my local fender guitar and fender electronic...
If the problem is actually the volume knob, then the guitar shop did not fix it and you should bring it back. There is a test you can do to see if the problem is your volume knob. With the guitar unplugged, you can turn the knob up to the max and down to the min a lot of time (like 50-100 times or more) plug it back in and see if the problem is a little bit better, if it is I would bring it back to the repair shop and demand they fix it properly.
The problem could be the cable you are using. Sometimes it can seem like it's a volume knob problem when really it's a cable issue. Jiggle the cable and connector while the guitar is plugged in to see if the sound cuts out at all or you get crackling.
May 04, 2011 | Fender Acoustasonic Telecaster 3TSB
Tv nt coming on red light is on next to power light 50 inch lcd projection sony tv
hello. it sound's like you need to replace the lamp in your set. and here is how to do it the right way. rember to all ways unplug your set.. # 1 first. .Remove the outside lamp cover. The lamp cover is located on the right side of the Sony television. To remove the lamp cover, simply pull down. You will now have access to the lamp housing. # 2 Open the lamp housing door by turning the locking handle counterclockwise while pulling the door toward you # 3 Pull the lamp unit straight out of the television unit. Be sure not to touch the bulb, as it may still be hot. # 4 Slide the replacement bulb into the lamp housing. # 5 The lamp will slide securely into place.!!! "Do not" touch the new bulb as it will cause damage to the bulb and result in malfunction. # 6 Push the lamp door back into place. Turn the locking knob clockwise to secure the door in place.# 7 Slide the outside lamp housing cover back into place on the television.!!! plug your set back in to the wall & The television is now ready for use. thank you
Oct 21, 2010 | Sony KDFE50A10 50" HDTV
I have a 52 inch rca dlp hdtv. the color is out of allign and the tvs menu convergence adjustments isnt gooe enough, how do i enter the advanced convergence settings. my S/N is D52W23WX32F445C1002. thank...
Turn off your TV. Hold down the Channel Down and Volume Down buttons on the front of the TV. Hold for 8 seconds. The set will boot into the service menu.
I just fixed my convergence issue with this, no parts.
Jun 15, 2009 | RCA HD50LPW175 50" HDTV
Volume won't turn down
Try the setup program. When you get to the main setup screen, look for a reset all to standard setting. That may solve the problem. If it doesn't then the sound module may need to be replaced inside the TV.
Apr 11, 2009 | iLO 3200 32 in. LCD Television
Volume is locked
thank you soooooo much!!!
it worked :)
Sep 01, 2008 | Boston Acoustics Duo-i Horizon Clock Radio
Mackie 450, signal light off, Sound only comes out when amp. turned up above 75%, when usually used at 40-50%. too loud at 75% and UP, does not Work at ALL below 75%. only 2 years old, with 25 uses... i...
Doesn't sound like a fuse. They don't fix themselves when you reach 75%.
Try shaking the volume knob while in the 30-50% range and/or try (with the power off) rotating the volume knob numerous times from 0% to 100%. If when you plug it back in it responds ANY differently, you might have a bad volume potentiometer. If when you shake the knob you hear static or intermittent sound, you have a bad volume pot.
The only other thing I can think of is that the wiper of the volume pot is not in contact with the windings inside the pot until you reach the 75% mark. When the volume comes on at 75%, does it start off kind of "static" then come in loud and clear? Also try this.... adjust the volume pot to 74% (or when the sound just begins to come on). At this point shake the knob. If you hear static, replace the volume pot.
Unplugging it when still on shouldn't cause any damage... in fact it probably hasn't considering it works at 75% plus.
Mar 14, 2008 | Audio Players & Recorders
Compaq Presario 700 470024-192 Notebook Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
