Question about ViewSonic (CW2206) Keyboard
Not responding to movement
I have a cw2206 and the keyboard works just fine, however, the mouse does not want to sync to the receiver.. It worked for about a month and a half than I started experiencing problems with it wanting to respond to movement. I need to know if anyone knows how to fix this. It may need to be reset but I don't know how.
Dear Stef, First try replacing the mouse's batteries, if this fails then try resetting it using the reset button - both on the mouse and the receiver. If you experience trouble resetting, you may try to disconnect the receiver and the mouse physically. Unplug the receiver and take off the mouse's batteries and then reconnect them.
Posted on Jan 19, 2006
SOURCE:
Changed batteries on keyboard and now wont sync. Cant see a sync button on the keyboard so dont no wat to do
Hi.
You should find the sync/connect button underneath the keyboard. You must also press the button on the receiver.
Regards.
Jun 08, 2011 | ViewSonic ViewMate CW2206 DHCW2206...
I moved my computer from one home to the other, also installed new batteries, now my mouse or keyboard will not respond to any commands.
some wireless mouse keyboard combos have a unique way to sync them to their receiver. Even if they aren't together, they still might require you sync them to the receiver. (usually a button on the receiver and the keyboard/mouse that you press together). If this doesnt help, please clarify the Brand and Model of your keyboard and mouse.
Oct 03, 2010 | Computers & Internet
Keyboard not responding. just bought it today.. i've check everything, battery, drivers and receiver are all ok.
After six months of using the same keyboard / mouse combo with no problems, I had exactly the same problem as you one day (keyboard wouldn't connect, but mouse OK), I resolved it by powering down the mouse (hold the 'connect' button) and then sync-ing the keyboard using the USB key. When I powered the mouse up again, both pieces of equipment worked fine again. Hope this helps.
www.myspace.com/misnomeruk
Apr 24, 2010 | A4tech A4 tech G6 saver Mini Wireless...
My hp wireless mouse does not work and i cannot sync it to my PC. the wireless keyboard works fine and i am able to sync it. how do i fix my mouse problem?
Remove the battery of the mouse and install new one and then press connect button from the mouse side and the receiver side also.
Nov 25, 2009 | HP Wireless Optical Mouse
Mouse Stops Responding
You need to reset the mouse and keyboard to the sensor. On the sensor(base) you should have a button and under the mouse you should have also a button. Press the sensor(base) button first and quickly the one under the keyboard and mouse. If the doesn't work shut down the system, unplug the mouse and keyboard sensor(base) and re-plug it back in . Start the system and try the process again.
Oct 03, 2009 | ViewSonic ViewMate CW2206 DHCW2206...
Vx problem:movement
First try this
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
If that doesn't do it theen try this.
Normal 0 Disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Dec 30, 2008 | Logitech VX Revolution 931690-0403 Mouse
Boot Manager
Did you enable USB Legacy support in the bios?, if not, that should fixit
Sep 06, 2008 | ViewSonic ViewMate CW2206 DHCW2206...
Solution. My wireles keyboard stopped working except for the F-Lock key, the Media key and the sleep key. It wasn't batteries, even though I tried, communication was there because the above keys were working. Remove the batteries from your keyboard and let it sit for about 10 minutes. Press the red connect button a few times and other various keys every few minutes during that time. This may be the whole "capacitor discharge" trick, but I tired that with someone elses instructions and my keyboard did not work after 2 minutes of key pressing. I think it just needed more time to clear out the secure settings. Good luck, I was about to trash this keyboard until I tried again
Nov 26, 2007 | Elite Logitech Media Keyboard(KB9675590403
No Cursor
Did you register the mouse to the receiver? There should be a button on the receiver, the bottom of the mouse or both used to connect the wireless mouse to the receiver. Also, if you do not have a red light on the bottom of your mouse it may have a battery problem.
Jul 22, 2007 | Logitech Optical Mouse Plus Usb Port...
ViewSonic (CW2206) Keyboard Logo
191 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
