Question about Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLT5087S TV
New TV--sound is not working properly. Sounds like the bass is up too high. However the sould menu doesn't allow me to change it off Mono. Any suggestions?
    Genius:
  • 2,920 Answers
Take it back to the store and get a different tv
Posted on Oct 24, 2008
How do I change my audio setting
It depends on what you want to change about your audio setting. My cable box remote has two audio settings: one for changing the SAP language sound from English, to Spanish or French; and a setting that changes two separate audio functions: one changes the broadcast sound from Dolby Digital (TM) sound to regular stereo sound, and the other will allow using either a fixed setting (cable box sound level is at a fixed level allowing one to use the sound control on the TV, or other audio receiver), or a variable setting (allowing the use of the cable box to adjust the audio level).
My Sony TV control also allows me to adjust the tv's audio treble, bass, balance, and special effect sounds, and if needed, to turn the tv speakers off. Hope this is helpful..................Gary
Apr 23, 2014 | Sanyo DP26640 LCD TV
How to adjust Dg11100 car amp
If your head unit has an amp gain, turn it up as high as it will go. If it is hooked up to subs, the head unit will say subwoofer output in the menu. Then take a small screwdriver and turn the amp gain on the side of your amp counterclockwise to zero. Turn your freq. up to about a third. Crank your system up, with a song with good bass, and slowly turn your gain up till the bass from the subs sound distorted, and back it back down. If the bass is drowning out the other speakers in your car, then turn the gain down some more. I find it works best if you have your trebble up high, your mid range at a little less than half. And your bass at zero or one. Your amp is cranking up the bass, so let your other speakers handle the rest. This allows it to sound clearly at higher volumes.
Jan 02, 2013 | Cars & Trucks
Samsung TV will not turn on.
OK if it is LCD your and have sounds but no picture you possibly have faulty inverter board that need to be replace
Dec 03, 2012 | Samsung LN-S4692D 46 in. LCD HDTV
Hello there,i have a samsung cell phone model SCH-R351.My phone is on silent mode.What can i do to get it off silent mode and turn the ringer on
In the Settings menu, select Sounds. The Sounds menu appears in the display.
Select the Master Volume sub-menu which allows you to set the default volume for incoming
calls, messages and alarms. You can set the volume to Silence All, Vibrate, Low, Low/Medium, Medium, Medium/High, or High. The Vib. on soft key allows you select vibrate in addition to the sound.
Hope this helps. If so, please rate this solution.
-best regards,
M
Mar 10, 2011 | Cell Phones
TV color changed to display green only
IF THE GREEN IS ON ALL INPUTS, THEN YOU WILL NEED A DIGITAL AND ANALOG BOARD REPLACEMENT, VERY EXPENSIVE REPAIR, TRY HDMI INPUTS FIRST, THEN COMPONENT AND SO ON
Dec 30, 2009 | Samsung HLT5089S Television
HP Pavilion 6704nr laptop, can't plug bass guitar
you sould instal the proper driver(for XP) for the sound card,before that check in my computer-advanced-device manager- if the driver is working properly.
Dec 08, 2009 | HP (153147-001) Sound Card
No sound or picture HL-R5067w
sounds like ur tuner is bad.. ur better off buying a new tv then geting it repaired
Jan 18, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung HT-X200R Cinema
According to other internet sources, this device does not allow you to adjust the bass or tremble. Very disappointing Samsung.
Sep 30, 2007 | Televison & Video
Samsung HLP4663W 46" Rear Projection HDTV Logo
109 people viewed this question
Jerry Greenberg
Jerry Greenberg
