Question about Onkyo DR-C500 Multi-disc DVD Player
DR-C500 problem with turning the system ON
When I turn the power on in my DR-C500, the system does not turn on. The display changes from not lit to slightly lit. The display as well as the system does not turn on.
    Problem Solver:
  • 29 Answers
Make sure all power connectors, cords and plugs are inserted securely and that the outlets are in good working order Be sure to select an audio source (CD, AM/FM, etc.) For powered systems, unplug the power pack for a few seconds, and then reconnect it. This allows the unit to reset itself after a power surge or power interruption. good luck!
Posted on Jan 08, 2006
No display
The following applies to Acer Laptops...
If the power indicator is lit but nothing appears on the screen - The computer's power management system automatically blanks the screen to save power. Press any key to turn the display on.
If pressing any key does not turn the display back on, check the following....
1. The brightness level might be too low. Press Fn and the right cursor key to increase brightness level
2. Display device might be set to an external monitor. Press Fn and F5 to toggle to the internal display
3. Backlight might be turned off. Press Fn and F6 to turn on the backlight.
4. If the Sleep indicator is lit, the computer is in Sleep mode. Press & release power button to resume.
May 09, 2011 | Acer Aspire One PC Notebook
Shut down my Acer 2480 wrong by pressing the power button. Now it doesn't reboot or boot up. I tried to pressing F2 to reboot but it doesn't do anything. Any suggestions?
Look at the power indicator:
If it is not lit, no power is being supplied to the computer. If the computer has a battery, it may be low and unable to power the computer. Connect the AC adapter to recharge the battey pack and make sure the AC adapter is properly plugged into the computer and to the AC power outlet.
If the power indicator is lit, check if a non-bootable (non-system) disk or USB thumbdrive is in the computer. If so, remove it and press Ctrl + Alt + Del to restart the system.
Pressing F2 by itself is only used to enter the system's BIOS on startup. If the power indicator is lit but nothing appears on the screen - The computer's power management system automatically blanks the screen to save power. Press any key to turn the display on.
Apr 03, 2011 | Computers & Internet
Hello. I want to ask. I have a Acer Aspire 9300 and I have a problem with it. When I try to turn it on it only ignites the green light and the computer does nothing and does not make any sound. What could...
First, make sure it is fully charged and plugged in.
If it is not lit, no power is being supplied to the computer. Check the
following:
If you are using on the battery, it may be low and unable to power
the computer. Connect the AC adapter to recharge the battery pack.
Make sure that the AC adapter is properly plugged into the computer
and to the power outlet.
If it is lit, check the following:
Is a non-bootable (non-system) disk in the external USB floppy drive?
Remove or replace it with a system disk and press <Ctrl> + <Alt> +
<Del> to restart the system.
Nothing appears on the screen.
save power. Press any key to turn the display back on.
If pressing a key does not turn the display back on, three things might be
the cause:
The brightness level might be too low. Press <Fn> + <→> (increase) to
adjust the brightness level.
The display device might be set to an external monitor. Press the display
toggle hotkey <Fn> + <F5> to toggle the display back to the computer.
If the Sleep indicator is lit, the computer is in Sleep mode. Press and release
the power button to resume.
Aug 28, 2010 | Acer Aspire 9300 Notebook
Turned on system. it shut off. tried to turn it on again the display screen lit up and went out now i get nothing.
If every segment on the display lit up it will need a display driver IC (pain in the a## to replace need to remove the display to get at it) and it will also need a transistor in the power supply.
Feb 10, 2010 | Samsung HT-Q70 Home Theater System System
I can only recieve and make calls on my spv c500
You can do a Hard Reset which will reset your phone to its original factory settings. Any applications or personal data you put on the phone since owning will be lost. You can recover personal file if you have backed them up, of if you have License 'Key' numbers you got when you purchase them. Some App suppliers will have you an record and will email your Lic # if your email has not changed since purchase.
To Hard Reset, turn off your phone and then turn it back own while holding down both left and right soft keys till you get a screen asking if you want to Reset it. Another Hard Reset method, if you can get to Start Menu/Accessories folder when phone is powered, is choose Clear Storage and clear the storage. This may not work on some phone models, but note this method will also reset your phone to 'as purchased' state, with all stuff you added since removed.
Note a Soft Reset is the same thing as just turning phone off then back on as normal. It does nothing but re-power your phone, but a Hard Reset recovers your phone operating system from phones MFG ROM and resets it back to original as purchased state.
Jan 22, 2009 | Orange SPV C500 Pocket PC
Installation of SPV C500 windows mobile OS
Dec 11, 2008 | Orange SPV C500 Pocket PC
Not responding after flashing "loading" for 1 minute then get message R-Lk --:-- on display
Hard drive issue or power supply. Power supply prone to bad capacitors (look for leakage/swollen tops)
If hard drive faulty you'll need a new one which is no small task. Disk contains firmware and custom file system and smallest I've got image is 10.7gig
Feb 02, 2008 | JVC DR-MH30S DVD Recorder
On button
Look at the power indicator. If it is not lit, no power is being supplied to the computer. Check the following:
  1. If you are using on the battery, it may be low and unable to power the computer. Connect the AC adaptor to recharge the battery pack.
  2. Make sure that the AC adaptor is properly plugged into the computer and to the power outlet.
  1. Is a non-bootable (non-system) disk in the external USB floppy drive?
  2. Remove or replace it with a system disk and press <Ctrl> + <Alt> +<Del> to restart the system.
The computer's power management system automatically blanks the screen to save power. Press any key to turn the display back on. If pressing a key does not turn the display back on, three things might be the cause:
  1. The brightness level might be too low. Press <Fn> + <→> (increase) to adjust the brightness level.
  2. The display device might be set to an external monitor. Press the display toggle hot key <Fn> + <F5> to toggle the display back to the computer.
  3. If the Sleep indicator is lit, the computer is in Sleep mode. Press and release the power button to resume.
Dec 17, 2007 | Acer Aspire 3000 Notebook
System is lit with no display does not turn on
your set needs to be repaired have a tech look at your set, the power supply is defected along with the audio output.good luck
Jun 03, 2007 | Teac CD-X8 CD Shelf System
Onkyo DR-C500 won't recognize discs
Onkyo units as well as several other manufacturers have a common problem where the spindle motor gets intermittant or wont come up to speed.Its not hard to replace this motor, but could be a trick to adjust the platter height. Also the unit probably needs a servo alighnment as well. This unit could also have a simple problem as a dirty laser lens. You can try to use a disc lens cleaner to see if that helps. Good Luck
Jun 24, 2006 | Onkyo DR-C500 Multi-disc DVD Player
Onkyo DR-C500 Multi-disc DVD Player Logo
259 people viewed this question
Top Onkyo Televison & Video Experts
Steve
Are you an Onkyo Televison and Video Expert? Answer questions, earn points and help others
