Question about Lexmark X7350 All-In-One Printer
Scanning slides into computer
I have a Lexmark 7350 and wonder if it has the ability to scan slides and negatives into my computer? Thanks, Vera
  • Lexmark Master
  • 4,338 Answers
From Lexmark's website:
To scan negatives, slides, and transparencies, you need to place the original between the light source and the sensor array so that the light passes through them before hitting the sensor. However, Lexmark scanners place the light source and the sensor array on the same side in order to catch the light as it reflects off the original. Accordingly, in order to scan originals of this type, you need a transparency adapter (also called a TPA or TPU), which is a back light that replaces the scanner cover.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 02, 2008
Hi, I have Canon Pixma MP270. IS it possible to scan photo negatives and change to colour prints. thanks. Blair
A multi-purpose printer scanner cannot scan negatives or slides.
You need a slide scanner or a flatbed scanner that is capable of scanning negatives and slides. Not all flatbed scanners are capable of scanning slides and negatives.
Sep 27, 2010 | Computers & Internet
Can HP psc 1410 PRINTER SCAN NEGATIVE AND SLIDES
Chances are that somewhere in your family photo collections you have a bunch of slides and negatives that you wish you could do more with. You may want to include them in your family history, to publish them on the Web, or simply to make digital copies so you can share them with the family.
If you've ever tried to scan a negative or slide on a regular flatbed scanner, you'll know that it doesn't work, and you end up with a pure black scan. In this article we'll show you how you get your negatives and slides into digital format, and what issues you may face along the way.
pixblue.gif Benefits Of Scanning Film
There are some key benefits to scanning film (we'll use the term to include slides and negatives) in comparison to scanning a photo. When you scan film, you can use the full area of the slide or negative, whereas a photo will generally only display a cropped portion of the original. You are also scanning the original source image rather than the color corrected and tweaked version of it that the photo processor has provided you with. The process of turning a negative image into a positive one involves inverting the colors in the image and removing the orange cast from the negative. This would be a complicated process if you were doing it by hand; however, your scanner will provide you with software to do this automatically, or you can purchase standalone software to do it.
Most cheaper flatbed scanners are designed to scan photos and other images that reflect light when it is shone onto them. The problem is that film is transparent and light passes through it rather than being reflected off it. Many flatbed scanners have an optional transparency adapter, which replaces the scanner lid with a larger box shaped ob....
Jun 09, 2010 | HP PSC 1410 All-In-One InkJet Printer
I am looking for instructions on this product.
Step 1: Open the scanner lid and remove the Transparent Materials Adapter (TMA).
Step 2: Place your slides or negatives into the appropriate template. Follow the orientation indicated by the icons on the template.
Step 3: Tip: If you are scanning fewer than the maximum number of negatives with the TMA, cover the empty spaces with the provided light shields to avoid letting any extra light in
Step 4: Place the template on the scanner glass, aligning the arrow on the template with the indicated mark on the scanner bed.
Step 5: Close the scanner lid and press the Scan Film button (or select the Scan Film option if you're using the HP Solution Center application on your PC).
Step 6: In the Scanning from dialog box, click Change Settings.
Step 7: Under Scan Shortcut Settings, select your Scan Type (either Negatives (TMA) or Slides or Positives (TMA)).
Step 8: Under Scan To select Save to file. Then click Scan.
Step 9: Under the Save Location dialog box, click Browse and enter the destination folder of your choice. Click OK and follow any on-screen instructions to finish scanning. The scan will be sent to the destination folder you selected. s.gif s.gif
May 01, 2009 | Office Equipment & Supplies
Slides scan as negatives
this scanner usb cabal no didact tell me bored problam ya cabl problam 6600E
Feb 04, 2009 | Canon CanoScan 4200F Flatbed Scanner
Cannon 4400F Scanner
I had the same problem with about 1 out of every 16 slides when I first got the scanner. The only way I found around it was to rearrange the slides and try again. I started scanning through the ScanGear software instead of Canon Toolbox, and haven't had that problem since. I've scanned about 6,000 slides and negatives so far.
Jan 25, 2009 | Canon CanoScan 4400F Flatbed Scanner
Faxing using Lexmark 1290
quero um dowlod pra instalar no meu computador...
Sep 21, 2008 | Lexmark X1290 All-In-One InkJet Printer
Scanning monochrome negatives on Coolscan 5000ED
Your killing yourself how big are you going to print this!!! Are you using Vuescan or silverfast for scanning or Nikons util? Stay away from Nikons utility! 2x sample is plenty and turn off ICE for monochrome (it makes a mess of things) but 16 bit yes until you print then go down to 8 after you resize for final print.
Morphoto.ca
Mar 05, 2008 | Nikon Super Coolscan 5000 ED Film Scanner
CanoScan 4400f
Keep the protective cover on except when scanning slides or film.
Jan 27, 2008 | Canon CanoScan 4400f MultiFunction Color...
Just got new computer with windows vista now my lexmark p6250 printer dos"t work
You will need to install Vista driver to suit, please note that orginal scanning software is not available but you will find within Vista itself the ability to scan.
Vista DRIVER Download
Nov 21, 2007 | Lexmark P6250 All-In-One InkJet Photo...
My 4 in 1 wont scan but does print
Before we give up on the scanning/copying ability of your machine. Try unplugging the machine from the wall and from the computer for at least a couple minutes. If that doesn't work, You may also check for a factory reset switch or reset mode you can choose. http://downloads.lexmark.com/cgi-perl/downloads.cgi?category=Drivers&ccs=229:1:0:94:0:0&os_group=WinXP&searchLang=en Last but not least. Uninstall the printer again, unplug it from the wall and computer. Make sure you restart the machine and even shut it down before trying to reinstall the drivers. The above site has a patch for the scanner. Not sure if its what may be ailing yours. Let me know what happens. Good Luck, Tim
Mar 01, 2007 | Lexmark X73 All-In-One InkJet Printer
Lexmark X7350 All-In-One Printer Logo
270 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
