Question about Maytag Atlantis MAV6000 Top Load Washer
Agitator came off
I found that when I finished loading the washing machine with the laundry and water...the agitator was floating. Now I've got the bolt and cleaned the agitator. I can find no problem with the threads on either..but, I can't get the agitator to fit back down again. I'm so frustrated right now. I need to get laundry done..
Thanks Irene
  • lilly262 Sep 07, 2008
    thanks for your advice. I had been thinking the same but I was hoping for a simple fix.. I'll be back here again.. Thanks again
  • 943 Answers
Hi thanks for the question did you drain out the water before you try & put the agitator back on as this will prevent you from pushing the agitator all the way the appliance doc
Posted on Sep 13, 2008
Sloshing water sound in washing machine
Actually a bit of water is always left in the machine , its made that way for a purpose. not sure how to explain it but has to do with balance and load stablization. Unless u have another issue and much more water is left in due to insufficient draining, then u have to look at ur water pump and sump filter. see attached pics
Jun 01, 2014 | Frigidaire Washing Machines
Tip
How to service tub & agitator
The washing machine tub, or basket, generally doesn't cause problems. However, at times it may cause damage to the laundry, make a lot of noise, vibrate, or stop completely.
If laundry is torn during the wash cycle, feel around the tub. If you find a rough spot, you may be able to smooth it with an emery board. Sand the spot lightly. If this doesn't work or if you have to cut to bare metal to remove the roughness -- the tub should be replaced. In this case, it's probably much wiser to replace the entire washer.
The agitator -- the finned part that fits on the tub shaft -- can also tear laundry if the fins are cracked or broken. You may be able to solve the problem temporarily by pinching off the splinters with pliers and lightly filing the plastic smooth, but this is just a stopgap measure; the agitator should be replaced. Replace a damaged agitator with a new one of the same type. To do this, unscrew the cap on top of the agitator. With the cap off, pull straight up on the agitator; it should lift off. If it doesn't move, rap its side with a hammer. If it still won't lift off, drive wedges under the bottom rim of the agitator to dislodge it. Then set the new agitator into place and replace the agitator cap.
Damage to the snubber, a padlike device sometimes located under the agitator cap, can cause the machine to vibrate excessively. The snubber may have a suspension spring in it. Lift off the agitator cap and examine the snubber. If the spring is broken, or if the pad is visibly worn, replace the entire snubber. Snubbers might also be found at the splash guard at the top of the tub, under the transmission, or as part of the water pump housing. Look around until you see it.
If the machine doesn't have a snubber, listen for noise at the suspension unit between the tub and the machine cabinet. The suspension unit has fins or pads that may need replacement. In some cases, the entire unit may have to be replaced. Another noise point is the basket support nut. Tighten the nut or, if you can't tighten it, replace it.
Sudden tub stops can be caused by a broken motor belt, but they are usually due to poor tub loading. Check to see if wet laundry is wadded around the bottom of the tub shaft, or under the basket or agitator assembly. Remove the basket or agitator in order to remove the laundry easily.
on Jan 16, 2010 | Washing Machines
One piece agitator wraps cloths
When loading the machine, load towels, sheets or jeans with an accordion fold instead of putting the laundry in a circle around the agitator. It helps to put the clothes in at the twelve o'clock position, then six o'clock, then nine o'clock and then three o'clock. Repeat this sequence until the washer is full.
The laundry can circulate much better and get cleaner too.
Feb 08, 2014 | Washing Machines
During filling reaches fL before finished filling and stops
Not sure if this was explained to u but these washers do not fill like the old top loads did... the machine uses very little water, the clothes are rolled over and over through the water as it cascades down and up through the agitator. If you look at the agitator you'll notice it does not have an elongated spindle, it's not required. Although the machine doesn't fill your clothes will be fully washed, this design was developed to conserve water...
Aug 19, 2013 | Kenmore Oasis Agitator 4.5 cu. ft....
It knocks on spin cycle
The tub may be off balance.
Servicing the Tub and Agitator
©2006 Publications International, Ltd.
Unscrew the cap on top of the
agitator and pull straight up;
the agitator should lift off.
If laundry is torn during the wash cycle, feel around the tub. If you find a rough spot, you may be able to smooth it with an emery board. Sand the spot lightly. If this doesn't work -- or if you have to cut to bare metal to remove the roughness -- the tub should be replaced. In this case, it's probably much wiser to replace the entire washer.
Sep 10, 2009 | Washing Machines
Washer drum bangs from front to back
This may be a drum or agitator problem. Possibly bad bearings or coupler
Sep 03, 2009 | Frigidaire ATF6000ES Front Load Washer
The agitator stops moving during the wash period, and sometimes it slow when is suppose to be spinning to remove the water from the clothes.
We will conclude our tour of the washing machine on the next page with tips for servicing the water pump, the belts and pulleys, and the motor.
Servicing Water-Related Problems, Belts, Pulleys, and the Motor
On this page we will explore some of the more mechanical parts of a washing machine like belts, pulleys and the motor. First, we have some tips for water-related problems.
Aug 24, 2009 | Washing Machines
Agitator movement
Hi, If this is a two piece agitator, start the wash cycle with no laundry in it and see if the lower half of the agitator moves. If the lower half works, you will need to change the dog kit inside the agitator. There is a 7/16" bolt under the agitator cap the will need removed to get the agitator out.
If the agitator does not move at all, It could be the coupler connecting the transmission to the motor. If the coupler is bad, tub will not spin the laundry dry.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 13, 2009 | Whirlpool LSN1000LW Top Load Washer
How to remove agitator
hi The washing machine tub, or basket, generally doesn't cause problems. However, at times it may cause damage to the laundry, make a lot of noise, vibrate, or stop completely.
Nov 11, 2008 | Hoover HTC243 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
179 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
