Question about HP 4570C Flatbed Scanner
Scan image is discolored
I scan the document, and the document (on the monitor) is blue, or yellow, or just dark. What needs to be repaired? And, where do I go to get it? MRD
  • msen_02368 Aug 11, 2008
    When I scan a document the image is black with colored streak.
    Problem Solver:
  • 29 Answers
The scanning carriage in the scanner may have lost the home position and needs to be reset. 1. Shut the computer system off, and then disconnect the scanner from the power source. Leave the scanner disconnected from the power source for at least one full minute. 2. Reconnect the power, and then restart the computer system. 3. When the computer system has fully restarted, try scanning again. Ensure the issue is not caused by Electro Magnetic Interference (EMI) EMI can cause similar Image Quality issues. Verify that the scanner is not in the direct vicinity of the computer monitor and/or speakers. If so, relocate the scanner at least three feet away from the monitor and/or speakers and retry the scan. good luck..
Posted on Jan 08, 2006
How to use the *2670 lexmark scanner
Please follow the steps below on how to scan using your Lexmark X2670 printer:
Using the printer control panel
1. Open the top cover, and then load an original document face down on the scanner glass.
2. Close the top cover to avoid dark edges on the scanned image.
3. Make sure that the printer is connected to a computer, and that both the printer and the computer are on.
4. From the printer control panel, press the scan button.
5. Follow the instructions on the computer screen.
Using Windows
3. Do one of the following:
• In Windows Vista, click > All Programs, and then select the printer program folder from the list.
• In Windows XP, click Start > Programs or All Programs, and then select the printer program folder from the list.
4. Click Lexmark Productivity Studio.
5. On the main screen, click Scan.
6. Follow the instructions on the screen.
Using Macintosh
3. From the Finder desktop, double-click the printer folder.
4. Double-click the 2600 Series Center.
5. From the "What is being scanned?" list, choose the type of document to be scanned.
6. Click Scan.
Source: Lexmark X2600 Series User's Guide
Oct 09, 2011 | Lexmark X2670 All-In-One Printer
Tip
How to Solve No Scan Options: Refer to device documentation to troubleshoot
How to Solve Cannot Scan Error or No Scan Options: Refer to device documentation to troubleshoot
1. Click Start ,
2. Click Run and type Msconfig and then click on ok
Will show the new screen of System configuration utility
3 Click on startup option
4. Search the list for HP Digital Imaging Monitor .
5. Select the HP Digital Imaging Monitor check box.
6. Click Apply , and then click Close .
7. Click Restart to restart the computer.
*Note : If HP Digital Imaging Monitor is not on the list,
it means the driver was not correctly installed.
You need to reinstall the software.
on Jan 22, 2010 | Office Equipment & Supplies
Lost the directions for the printer directions need to know what button is for scanning pictures,
Follow these steps on how to scan from the Lexmark X2670 printer using the operator panel. 1. Open the top cover, and then load an original document facedown on the scanner glass.
2. Close the top cover to avoid dark edges on the scanned image. 3. Make sure that the printer is connected to a computer, and that both the printer and the computer are on. 4. From the printer control panel, press printmastert_51.jpg 5. If you are using a Macintosh operating system, click on the document or image preview and drag to select the part that you want to scan, and then click Scan from the Scan dialog on the computer screen. 6. If you want to save the scanned image, then from the software application, click File > Save As. 7. Enter the file name, format, and location where you want the scanned image saved. 8. Click Save.
May 11, 2011 | Lexmark X2670 All-In-One Printer
How do I use the scan feature on my HP Officejet J3680 All in One. I pressed the "scan" button and received message "No scan option, refer to device documentation to troubleshoot". I do not have "device...
The HP Digital Imaging Monitor (DIM) software must be running in order to scan from the printer.
  1. Click Start , and then click Run .
  2. In the Open text box, type msconfig , and then click OK .
  3. In the System Configuration Utility window, click the Startup tab.
  4. Search the list for HP Digital Imaging Monitor .If HP Digital Imaging Monitor is not on the list, the driver was not correctly installed or a custom install was used. You need to reinstall the software.
  8. Try scanning again
Regards,
Riztech
Jun 16, 2010 | HP J3680 Officejet All In One Printer
How can i scan a photo?
You can scan photos by
1 Open the top cover, and then load an original document facedown on the scanner glass.
2 Close the top cover to avoid dark edges on the scanned image.
3 Make sure that the printer is connected to a computer, and that both the printer and the computer are on.
4 From the printer control panel, press "scan" button.
5 If you are using a Macintosh operating system, click on the document or image preview and drag to select the
6 If you want to save the scanned image, then from the software application, click File Save As.
7 Enter the file name, format, and location where you want the scanned image saved.
8 Click Save.
done..
May 23, 2010 | Lexmark X2670 All-In-One Printer
I scan a document and then I click on
I suppose you should have some software running on your system to accept the file.
Check the user guide.
Scan an image
You can start a scan from your computer or from the HP All-in-One. This section
explains how to scan from the control panel of the HP All-in-One only.
To use the scan features, the HP All-in-One and computer must be connected and
turned on. The HP Photosmart Software (Windows) or HP Photosmart Mac Software
(Mac) must also be installed and running on your computer prior to scanning.
● On a Windows computer, look for the HP Digital Imaging Monitor icon in the
Windows system tray (at the lower right side of the screen, near the time) to verify
the software is running.
HP All-in-One overview
Note
Closing the HP Digital Imaging Monitor icon in the Windows
system tray can cause the HP All-in-One to lose some of its scan
functionality. If this happens, you can restore full functionality by restarting
your computer or by starting the HP Photosmart Software.
● On a Mac, the software is always running.
Tip You can use the HP Photosmart Software (Windows) or HP Photosmart
Mac Software (Mac) to scan images, including panorama images. Using this
software, you can also edit, print, and even share your scanned images. For
more information, see the onscreen Help that came with the HP All-in-One.
To scan to a computer
1. Place your original print side down on the left front corner of the glass.
2. Press Start Scan/Reprints.
A preview image of the scan appears on your computer, where you can edit it.
3. Make any edits to the preview image, and then click Accept when you are
finished.
Dec 19, 2009 | HP Photosmart C3180 All-In-One InkJet...
Faulty scanned images
Pls check your color Scan settings. Generally there will be some color difference between the original and scanned Image because, the original is 'reflected light' whereas, the scanned image is a 'source light' on the monitor. The monitor setting can also affect the color output. S. Mohan
Jan 28, 2009 | HP ScanJet 2400 Flatbed Scanner
Scanned image appears to have an exposure problem
Are you using the software from HP? It sucks. Use the one provided my your operating system works great. Go your Control Panel, Printer and other Hardwares and click Scanners, make a shortcut to your task or start menu and Scan Away!!!!
Jan 10, 2009 | HP ScanJet 5300C Flatbed Scanner
How do I scan colored paper and still read print? HP Scanjet 8270
First thing to try is just play with all the scan settings to see what gives you the best result - try changing resolutions, type of document, type of output document, contrast, brightness, type of scan. If this doesn't give you any better results, then one of the best ways to do this is to get some plastic sheet of the same or almost the same as the predominant colour on your forms (you can go one step further and make a multi coloured filter if you are feeling creative and your forms are all identical). The text jumps out of the page and most scanners will give you a good scan - just make sure the filter is not too thick/dark. Hope this helps :)
Jun 25, 2007 | HP ScanJet 8270 Flatbed Scanner
HP 4570C Flatbed Scanner Logo
283 people viewed this question
Clive
Clive
