Question about Kenmore 75050 Wall/Window Air Conditioner
I have a Kenmore window AC. Model # 25370071000.
Can this unit be recharged? (refrigerant)
    Problem Solver:
  • 15 Answers
Second try....
Any unit can be recharged, however, its not cost effective to repair most window units unless they are under warranty.
Posted on Sep 18, 2008
Isn't blowing cold air, clened coils, removed, dirt, leaves, but still no cold air. Seems to be low on Freon. How do I get the unit charged?
The compressor needs to run, does it run? If it runs and the outdoor radiator is not producing heat, then it may be low on refrigerant. The compressor refrigerant lines, the skinny gets hot and the thick line gets cold under normal operation.
To recharge the unit, it needs to be leak checked and repair any leaks found, then recharged. The refrigerant type used needs to be known, a manifold gage set is used to diagnose and recharge.
If you have a window unit, you should have it serviced or replaced.
Jul 14, 2015 | Kenmore 25,000 BTU Room Air Conditioner
Can you recharge kenmore ac window
you would have to put in a line tap valve. no access fittings to sealed system.
May 02, 2014 | Kenmore 76100 Wall/Window Air Conditioner
How do you put freon in a whirlpool window unit
you will need a AC Tech to first 'repair' the leak and then to 'recharge' the system. Also, the Tech may have to 'weld in' service valves on the unit if it does not have them - which most window units do not have.
Note: unless you've had a 'leak' you'll never need to recharge the system. I would 'be sure' you needed to recharge the unit before having it recharged.
Sounds like you might really need to have a AC Tech look at the unit before you do anything.
Aug 04, 2011 | Whirlpool Electronic Window Air...
I have a kenmore 18,000 BTU window unit that only blows out warm air . The compressor does come on but shuts right back off.Can you tell me what can be done to repair it . We cleaned coils and filter.
It may simply need to be recharged with refrigerant gas. R134a is the standard refrigerant gas now. But, it's best left to the pros.
Hope this helps and thanks for choosing FixYa.
Jul 28, 2011 | Kenmore Room Air Conditioner
I have an ac unit that is running but is blowing out hot are in random spurts while on cool I need some quick solutions to this problem.
From what you have described, it sounds like the compressor may need to be recharged with R134a refrigerant. Since the chassis will need to be removed from the outer shell and specialized equipment is required to recharge the compressor, it's best left to the pros.
Unfortunately, that's not a quick solution.
Jul 13, 2011 | Kenmore 76100 Wall/Window Air Conditioner
Window kit dimentions i have a window 18 inch wide
The portable AC units generally have a customizable, exhaust hose window, termination kit that comes with the unit.. In other words it can be cut to fit. The one that comes with the unit will fit casement windows, as well as sash windows.
To further assist you, I have included a link to the Owner's/Installation Manual for the model you referenced. You may download and print it if you like.
http://www.air-conditioner-home.com/manuals/ac-12000.pdf
Hope this helped you. Please let me know. Thanks.
Jun 13, 2011 | NewAir AC-12000E Portable Air Conditioner
AF-S80MX Thru-Wall/Window Air Conditioner: What kind of refrigerant does this unit uses? ...
Most new window units are using R-22 or it's most common alternative R-410A - but you will need to check the 'data tag' on the AC to be sure. All AC units have a data tag (either metal or paper label) - somewhere on the AC - which gives you model number, size, voltage, and type of Refrigerant, as well as other info.
good luck!
May 08, 2010 | Sharp AF-S80MX Thru-Wall/Window Air...
How interesting. My whirlpool window unit ac does that same thing
Hello Jeffrey. The window air conditioner is no longer designed to be recharged. It can be done but it requires modification.
Another problem is licensing. You need a license to buy the refrigerant now days.
Finally you need about 100 dollars worth of special tools, gauges, charge pipes and vacuum pump.
I know you will be further ahead to sell your old one for junk and buy a new one. OR you call around to the a/c repair shops and get an estimate. Good luck either way.
Jun 08, 2009 | Whirlpool ACQ158XP Wall/Window Air...
Kenmore 75050 Wall/Window Air Conditioner Logo
453 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
