Question about Pioneer Audio Players & Recorders
Radio doesn't work
The receiver was dropped during a move. Now the radio does not work. The displays seem to work fine. The CD player that is plugged through the receiver works fine. Is this going to be an expensive repair?
  • 1,512 Answers
Hi ver4
Just a quick question, have all the antenna connections for the tuner been re-established? If the aerials are connected, the tuner module may have broken away from the printed circuit board or a crack has occurred to same. I expect that if it is a cracked PCB, then repairs should not cost more that $80-100.
Good Luck
regards
robotek
Posted on Sep 07, 2008
I cant get my subwoofer to work in radio mode. they work fine in CD mode, but nothing in radio? help
Make sure the antennae input is plugged into the back of the head unit. There should be a lead behind the dash coming from the car for the antennae. This will plug straight into the back of the head unit to receive radio signals.
Mar 07, 2011 | Alpine CDA-9827 CD Player
2004 chevy tahoe cd goes into radio and display
Yeah you need a new CD player common on those trucks but be careful the RDS radios must be programmed if get a used factory radio
Nov 20, 2017 | 2004 Chevrolet Tahoe
My friend pulled a KD-G729 from his mother's car, to install in his 2004 chevy colorado. The radio worked fine before he pulled it, and once installed in his truck, the only thing that seems to work is...
acc is missing. the truck requires a data module for the radio to work properly. I suggest you take to stereo install shop and have this added. it should then work great
Sep 26, 2009 | JVC KD-G720 CD Player
No radio text display on vauxhall corsa
model cdr 2005 radio/cd player works fine except there is no display above where the radio station2_bing.gif/cd track number is supposed to be displayed. I have time and temperature as normal
May 07, 2009 | Car Audio & Video
2007 Chrysler 300 , AM radio not working , but FM works fine
Usually when you lose only AM it is an antenna issue. Check for a loose antenna plug on the back of the radio or connection to the antenna.
Nov 15, 2008 | JBL - MR4W Am/Fm with CD Player White
Cd stuck
5 Other Users Have The Same Problem Comment by babba booey, posted on Jun 26, 2008before you spend $$ to have someone do anything, take the radio out of the dash yourself. what;s the worst thing that can happen, you break the radio that doesn;t work?
take the top of the radio apart and move the cd around... it's jammed and needed help to set up in the player.
put it back in the dash and push play. it should work. i just fixed mine and i am happier than paris hilton in a sausage factory.
May 02, 2008 | Car Audio & Video
Display on a Kenwood KDC-MP532U radio
not grounded well at all ground it man form main bolt on back to car chisis bet wont happen again
Mar 14, 2008 | Kenwood KDC-MP235 CD Player
GES050 undercounter radio/cd player
..just read about your reception/interference problems and, having lived through similar situations for some time — particularly with different weather conditions. The following solution has settled it all : wrap power cable around storage brackets at back of radio with a short length then wound around support posts (between radio and cupboard from which radio hangs), then run short length to power supply outlet. In my case this result comes after much experimentation with the length of unwapped power cord (including fully unwrapped and stretched out) and different patterns of winding around the support posts. This final result takes care of everything (better sound, no interference/loss-of-reception when moving around in the room or in front of the radio, weather has no effect, stations received that could not be before due to overlap by nearby, more powerful ones). I have only about 2 1/2 feet of cable running from the brackets at back of radio, then wound once around center support and half around right support to then go to wall and down to receptacle close by (I tried all kinds of combinations of unwrapped lengths and winding patterns around 1 to 3 posts)...individual cases may be different. so GOOD LUCK, 'cause the radio is great...!
Oct 26, 2007 | GE 7-5295 Undercounter DC /Radio Combo -...
Pb10-cd
You're welcome in advance.
This particular unit was advertised to be unbreakable when dropped due to its shock absorbers; therefore dropping it will fix it.
Oct 24, 2007 | Bosch PB10-CD Radio/CD Boombox
66 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
