Question about HP Office Equipment & Supplies
When I try to print, the Send A Faz prompt comes up. I can't print from my computer
  • olmxer Sep 06, 2008
    The wrong computer was selected. I didn't know that there was a 5600 Fax selection that was wrong.
    Genius:
  • 3,422 Answers
HI,
Please reinstall your printer driver.Go to START>Control panel>Add/remove programs and select your printer driver from the list and uninstall it.
Posted on Sep 06, 2008
  • HP Master
  • 13,433 Answers
Make sure your printer is installed and working also set as default printer, try going File -> print -> select your printer, if you don't see your printer its not installed correctly or not connedted.
Let me know how it goes.
I have Zebra LP2844 printer and Windows Vista OS. I have installed Zebra LP2844 and ZDesigner LP 2844 drivers and I want to use ELP to print text, barcode etc. Printer is connected to computer via USB. How...
To send text to printer in dos command you should first install a driver from
www.seagullscientific.com
then in the properties you can use send file to printer.
To send the files from command :
Check if the program ssdal.exe has been correctly installed.
to have help use ssdel help send at dos prompt
to send the file
ssdal send filename printername should do the trick
hope it helps
Aug 01, 2011 | Zebra LP 2844 Thermal Printer
Kodak 5300 ksn#f212713 printer will not print center of page from computer& when coping not dark enough.I have new ink?
You need to get a new print head. Its free! Go on the Kodak website, under HELP, and follow the prompts. They will send one within 3 days.
Mar 24, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
It Just Wont Print
Have you tried installing the HP Print Diagnostic Utility?
This utility fixes some of the basic issues with the printer /computer.
Download/Install and follow the onscreen instructions to run the utility and restart the computer when prompted.
I hope this tool resolves your issue.
gud luck.
Oct 26, 2008 | HP PSC 1315 All-In-One InkJet Printer
I have an HP Officejet v series printer, fax, amd copier. It will send a fax, but it is not received. Someone can send me a faz, it sends, but I don't receive it.
Verify that the sender has the correct fax number.
Call your fax machine from a regular phone and listen for fax tones.
Fax machines are ANALOG devices. Make sure your fax machine is not connected to DSL or any other digital phone line.
Sep 30, 2008 | Office Equipment & Supplies
Ricoh 2050L
1.put the document for sending on the place
2.dial number
3.if you sending to a direct fax press start or send
and all is ok
Feb 06, 2008 | Office Equipment & Supplies
Canon FAZ-JX500 purchased can't get it up and running
Tell us your problem, if you copy/scan/send/receive, how you have it set up, what you have tried, what sort of phone system(DSL?), where cables are going, any filter locations etc and we'll try
Nov 03, 2007 | Office Equipment & Supplies
SCAN,COPY,FAX PROBLEM
Issue An 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved. If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.     Here is a manual if you dont already have one.   http://h10032.www1.hp.com/ctg/Manual/c00486336.pdf
Oct 26, 2007 | HP Photosmart 3310 Printer
Printing from Dos Prompt
1. Save your text file (.txt).
2. On the command prompt navigate to that directory
3.Type "Lpr -S 192.168.1.200 -P lp text.txt"
Substitute 192.168.1.200 for your copier's ip
Substitute text.txt to filename.
Or you can: to print from MS-DOS apps.
1. Share the printer on a networked windows computer. Make sure you make the name MS-DOS compatible.
2. At a DOS prompt, type the following command:
"net use lpt1: \\servername\printer_share/persistent:yes"
NOTE Servername=computer name
printer_share=printers share name
Sep 28, 2007 | Office Equipment & Supplies
24 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
