Question about Sony NWZ-S615F Walkman Video MP3 Player
Mp3 player My mp3 player went dead now it want charge up, What should I do?
  • 1 more comment
  • camillacepha Sep 06, 2008
    the screen mp3 player sreens lights up in black with the sony walkmen logo.
  • zbarfield_0 Mar 08, 2009
    my mp3 wont turn on even after it was on the charger what do i do?
  • Crystal Cousins
    Crystal Cousins Mar 23, 2009
    i plug in my mp3 player and it says its not pluged in and im usin the usb cord that came with it? the screen says low battery please charge what the f****!!??!!??!
  • 8,596 Answers
Make sure the hold switch if off. Reset the player. Try a different USB port on same computer. Try a different computer with the same OS (to prevent formatting-related errors)
Here's some general info about the problem: 1.      1.       “My Mp3 player won’t turn on” or “My Mp3 player won’t hold a charge.” (POWER SUPPLY ISSUE)
The tricky part about these issues is that there are several possible causes – it could be software or it could be hardware.  Before you try anything else, make sure the mp3 player’s “hold” or “lock” switch is not engaged.  See your user’s manual for location of switch/ instructions (available from manufacturer’s website).  If the hold is engaged, the mp3 player will not charge, and it will not turn on.  Then, make sure the player is plugged into a compatible computer with a USB 2.0 port.  Many laptops and older desktops lack sufficient power resources to properly power/charge/utilize an mp3 player.  Next, try resetting your mp3 player.  If that still fails, try your device’s “recovery” button.  There is a specific button that triggers the recovery mode – volume + for most players, REC button for others, play for others, and skip forward for still others.  The general formula goes something like this, although you may have to substitute another button for “volume +”: disconnect the player from the computer, turn it off even if you have to reset the player to turn it off (if it is dead, this won’t be a problem), hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player (even if it is completely dead) - it will pop up a window that says Found New Hardware Wizard.
Make sure that your mp3 player is not designed for a country other than your own – this information can be obtained from the manufacturer in most cases.  European and some Asian current systems are different than in the U.S., Canada, and Mexico.  If you plug a United States mp3 player into a European wall outlet, you will fry the player.  If you plug a German mp3 player into a US outlet, it will have insufficient power to power the player.  There are transformers available that can correct for this issue.
If you have lost the original charger for your mp3 player, try to obtain the original charger.  If the original is no longer available, check your product specs to get EXACTLY the correct voltage.  It may seem harmless to use a 5V charger on a 4.5V mp3 player, but in many cases you will damage the mp3 player by doing this.
Also, never unplug an mp3 player while it is transferring music/files/performing a firmware upgrade (and also, never perform these activities when your player is not at least 75% charged).  This is a sure way to kill most mp3 players.  As a safety rule, always check and use the “safely remove hardware” option if it is available on your computer – lower right hand corner (green arrow pointing to chip) in most Windows taskbars.  If it is not available, wait one full minute after your last file transfer to unplug the mp3 player – even if your mp3 player says “OK to disconnect.”
If your mp3 player uses AA, AAA, or any type of user-removable battery, you must take extra steps to prevent equipment damage when replacing batteries (most product manufacturers do not know this tip).  Before removing the batteries, power the player off and let it sit for one minute or longer.  Run your hand along the side of your computer tower to dissipate static electricity (or use any other method available to dissipate static electricity).  Use only and exactly the replacement battery recommended by the manufacturer.  Carefully remove the old battery.  Hold and gently squeeze the new battery for a few seconds to dissipate static.  Hold the mp3 player case in one hand, and carefully insert the new battery.  One single static spark, and your mp3 player could be history.  Also, check your product documentation beforehand to see if removing the battery will result in your song’s being erased/data being lost.  Many, if not most, mp3 players do not have replaceable batteries – the manufacturers do not have them, and popping open your mp3 player more often than not causes damage to additional components.
If the solutions above do not work, and you have gone through troubleshooting with the manufacturer, you may have hardware damage and the player will need to be replaced. -Tha Mp3 Doctor
Posted on Sep 14, 2008
My player went completely dead and now it wont charge. what do i do?
if your mp3 player is full dead you loss.but you istall the driver iof softwere problem
Apr 09, 2011 | Audio Players & Recorders
My battery went dead. plugged it in and wont do anything
mine is doing the same. i have a SanDisk 4GB mp3 video player & mines went dead too and it will show it charging for a few seconds then it will just stop & it will just show the connected sign. try holding the power button for 15 to 20 seconds. maybe that'll work
Sep 03, 2009 | Philips Audio Players & Recorders
Playing normally on full charge suddenly went
what kind of mp3 player is it... i need that info to help you
Jul 25, 2009 | Audio Players & Recorders
Hi There
my zen mp3 went dead
i was downloading from the computer and it went dead
won't even turn on now
Aug 14, 2008 | Creative Labs Zen Touch MP3 Player
Player won't turn on
My player went dead and now it will not charge.
Aug 10, 2008 | Sony NWZ-S615F Walkman Video MP3 Player
You tries to replace the batteries or its charge vis USB? its happening to a lot players, i had to buy 3 playes because the copy song in the player is not good, today i have 2gb Sanse clip, very god plater, and he reads hebrew too!
Jun 17, 2008 | Sony NW-A1000 MP3 Player
My mp3 player isn't cutting on
"If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Jan 14, 2008 | Creative Labs ZEN V Plus MP3 Player
Mp3 player
Dec 26, 2007 | RCA M2000 MP3 Player
Sony NWZ-S615F Walkman Video MP3 Player Logo
197 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
