Question about Dishwashers
Dishwasher- water doesn't come into the top of the machine
    Novelist:
  • 166 Answers
Peace,
How old is the machine?
More than 9 years old? Throw it out and do not put good money into bad!
Other wise you need hands on service! And a new machine will pay for itself in only a few years!
Bless You!
Posted on Sep 07, 2008
Lg dishwasher ldf7932st motor starts but doesn't work
Is the water turned off? Dishwashers normally start a wash by emptying any waste water tipped into them during loading. Problem could therefore be a blockage somewhere, most likely in pump inflow under the filters in bottom of machine. Lift these out to check. Also check your sink drain isn't blocked and preventing the water from being pumped out.
Jan 19, 2013 | LG LDF7932ST Builtin Dishwasher
Tip
How to repair or fix a Dishwasher if it doesn't wash well
A common cause of poor washing results is improper loading—dishes that block or impede the spray arm(s) or prevent the soap dispenser from opening. On the other hand, if your dishwasher has chronic problems with good washing, the problem may not be your dishwasher. A good first step is vary the amount of dishwasher detergent you're using and try switching brands.
Other possibilities: Your home’s water pressure may be too low, your water may be too hard, or the water temperature may not be hot enough.
In order for your dishwasher to fill to the appropriate level, water pressure should be from 20–120 pounds per square inch. If you suspect that your water pressure may be low, turn off all faucets or other users of water (such as washing machines and sprinklers) and then put a half-gallon jug under the kitchen faucet. Turn on the hot water full-blast. If the jug doesn’t fill within 14 seconds, your water pressure may be too low for proper dishwasher operation. Call your city water utility to discuss your options, or avoid drawing water elsewhere in the house or yard during dishwasher cycles.
The right amount of detergent to use depends on how large your load of dishes is and how hard your water is. Hardness is measured in grains of minerals—the more grains per gallon you have, the more detergent you’ll need. If your water has 12 grains or more of hardness, fill both dishwasher soap cups completely with detergent. If that doesn’t work, consider installing a water softener.
To check water temperature, hold a meat thermometer under the hot water faucet for two minutes; if it doesn’t register a minimum of 140 degrees F., turn up the temperature dial on your hot water heater. (However, if you have a newer dishwasher that heats the water internally, it isn’t necessary to turn up your hot water heater.)
If your dishwasher has worked fine in the past but suddenly your dishes aren’t clean after the dishwasher completes all cycles, listen to the spray arm(s) spinning inside during the wash cycle. If spinning poorly, wait for the machine to cool down, remove the spray arm(s) by unscrewing the hubcap(s), lifting the arm(s) off, and then cleaning out the spray holes in the spray arm(s) with a stiff piece of wire.
on Sep 03, 2010 | Dishwashers
AEG Favorit 35080vi is not heating water
Hello
You need to take the machine out and remove the top and side panels from it.
(If it's integrated there's no top).
Once you have the side panels off, remove the water in the base of the machine.
Dry out the electrics
Once dried out, try the machine again.
If it doesn't trip and starts working, watch to see where it's leaking from.
Locate the leak, cure it and that should rectify the problem.
Hope this helps
Jan 26, 2012 | Dishwashers
How do I ge to the pump filter to see if is clogged
electrolux_154547901-001.png This is a basic blowup of your machine. all of the parts that you need to check are inside of the dishwasher. the dishwasher strainer catches any food or material before it gets to the pump system. make sure that it is clean, and as above, make sure there is no food particals in the long wash arms. If your machine is draining into the top of you garbage disposal, make sure it is cleaned by running water through it with it running for about 15 secs.. If this doesn't help, msg me back and I will go over some simple other items with you, before you tear it all apart.
Nov 27, 2011 | Frigidaire 24 in. FDB1050RE Built-in...
We have a 4 year old dishwasher.It is not washing as good as it should.The machine seems to rinsing the dishes etc in soiled water.I've checked the syphon and it doesn't appear to be blocked.I...
Hi wesalado,
Please follow my Tip below on some hints on how to keep your Dishwasher in tip-top shape:
DISHWASHER NOT CLEANING PROPERLY ANYMORE...
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 08, 2011 | Zanussi Dishwashers
Fdd914 dishwasher error code A10 appears and its not in the booklet
Hi, the interpretation for error code A10 is: A10 = fill solenoid valve triac closed/open circuit - check valve/ operation - machine drains until level switch resets + 30"
Now, to try and solve the problem yourself: Turn off the water supply to the dishwasher & remove the hose, Run the machine for several minutes in a normal position. Turn the machine off, reconnect the fill hose, turn the water back on then turn the machine back on.
If this doesn't solve the problem, then you'll need to call a service person.
Jun 12, 2011 | Hotpoint-Ariston FDD914 24 in. Built-in...
My knemoor dishwasher doesn't seem to be getting water. When I dump water in to the machine it runs but otherwise it seems to be water starved??help!
It sounds like the pump, the function of which is to pump water into the machine. Since it works when you add water manually, it doesn;t sound like a switch or anything.
A pump is easy to replace. It's usually attached with just a few screws/bolts and the hoses.
Feb 14, 2011 | Kenmore Dishwashers
Bosch SHU 5302 Machine doesn,t fill with water.
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Jun 16, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Moyer Diebel Dishwasher arms are not spinning and doing lousy
Hello there
First to check is the water level is it just cover the round filter and no more, or is it much lower from the filter. It seem you have not enough water in the tank to do the washing that is why you have a lousy washing job, not enough water to spray upwards don;t talk about the top spray arm , the water doesn't reach there at all.
You can check it out by manually fill the machine with water up to the filter and start the machine up when the machine is running open the door and you can see the water spray up to the top be careful the water will spray out to your face too.
This is only to check to see the motor is running normally.
If the water level is good ( that is just touch the filter) and the problem still there, then the other cause the problem will be inside the pump motor the part call the impeller may need changing.
Do you have the manual book so I can show you which part we're talking about and let me know where your district so I can tell you where to get the parts from . My email address is dickson@lau.com God Bless Have a nice day, Dickson
Apr 27, 2009 | Moyer Diebel 24 in. 501HT Built-in...
Dishwasher problem
My dishwasher Indesit DI67S will not run on the number 1 cycle. It will fill and then when that programme finishes it jumps straight to the drying cycle missing all the rinses out etc. If on the number 2 programme it goes all the way through but then doesn't dry. I've also noticed that the water doesn't seem to be heating up much and certainly isn't drying. Is this the element or something else? Once its reached the drying cycle the light for this just flashes then I have a job to try and reset the machine. It can take endless attempts. Will switching the machine off at the mains solve anything or is it the element?
Thankyou
Oct 09, 2007 | Indesit 24 in. DI67 Free-standing...
Dishwashers Logo
81 people viewed this question
Top Dishwashers Experts
