Question about Panasonic KX-T7633 Corded Phone
Auto Answer Our Office Phone is set to go to VM on Saturday at 12 noon. We have been working on Saturdays and I need this to be disconnected on the Saturdays that we work. Can I do this myself are do I need to contect my Tech to do this?
  • Panasonic Master
  • 2,460 Answers
You can do it yourself, but if you forget to set it back you will be out of luck, probably until Monday morning.
From the intercom dial ^7800 to put the system back in DAY mode. When you leave, dial *7801 to put it back into nights.
Carl
Posted on Sep 07, 2008
Why does the date on my seiko sne881 change at 12 noon?
probably because you have it set to 12 pm midnight and not 12 noon so at 12 noon it is actually midnight when the date will change
reset the time of the day to am or pm and any pm settings will change the date at 12 midnight.
Aug 30, 2015 | Seiko Watches
Our Taylor soft serve ice cream machine model 142-12 is making a loud banging noise when turned on. Almost sounds like an uneven washing machine. Please help!!!
Phone: 416-266-2791 or 1-800-335-5018
Fax: 416-751-5691
Hours of Operation:
Mon - Fri 8am - 6pm
Saturday 9am - Noon
Sunday Closed
Equipment & Smallwares Sales: geoff@accurate-repairs.com
General Inquires: accu@accurate-repairs.com
Parts: paul@accurate-repairs.com
Address:
Accurate Repairs / Food Trade Service
763 Warden Ave. Unit 1
Toronto, ON
M1L 4B7
Jun 10, 2014 | Ice Cream Makers
W58814 RADIO
a quick tip for you. disconnect the battery negative terminal just before 12:00 O'clock noon. Then right at noon reconnect the cable. Most radio's default set to 12:00 noon. Now you clock is set.
Mar 11, 2014 | 2001 Toyota Prius
Voicemail is not picking up for incoming calls...
Sounds like you need to set the call forward no answer to the VM pilot DN for the set with the new mailbox.
May 26, 2010 | NorStar Startalk Flash 2 Phone
I have the correct time and date but the day shows Sunday and it should show Saturday. I need to understand the setting sequence.
The day changes at midnight but if your watch thinks it is displaying 11a.m. when it is in fact 11p.m., then it won't change over until noon the next day.
Solution; wind your watch forward 12 hours (tedious, I know). You will then need to reset the watch to the correct day.
Dec 19, 2009 | Citizen Watches
One of our phones voicemail does not pick up. I can transfer directly to the voicemail, but if I call the line, it just rings.... and vm does not answer...
You will need to go inthru f**config config. go to terminals and sets, select set, then go to capabilities and here select the ring no answer to the vm pilot # if you are unsure of what this is look at another ext that works. set the # of rings and the phone will not go to vm.
Nov 05, 2009 | NorStar M7324 Telephone
REPROGRAM USER NAMES PASSWORDS
This will be an incomplete answer because you asked an incomplete question.
The first pat of your question involves access to the voice mail system. You can change it from a PC with software to access the system, or from the system manager's mailsbox (999). WHen the system was installed, you should have been given instructions and a password to that mailbox. You log into the manager's mailbox and select options 6 then 1 then 1 to edit or 3 to reset the password.
Easiest for you is to reset the password and make each mailbox owner do his own name, password, directory characters, and greetings.
There are at least 2 ways to get someone's call to voice mail. The first is by setting call forward at the phone. That's the *710x (VM) # that you dial from the intercom. My voice mail system is at ext 165, so I use *7104165# to send it to VM only when I don't answer. The 4th digit options are 2 for all calls, 3 for busy 4 for no answer, and 5 for busy/no answer. Once you set it, the FWD/DND button functions as a selector.
The second way is, if you know the person is not going to answer, you set up a VM Transfer button.
That's where you take a spare button of the 24, label it, and dial the following. PROG press the button 94 (VM) ENTER. Again, mine is 94165.
The 3rd way involves system programming and has to be set up by the system installer. It involves extension intercept and has timing parameters and destinations that need to be programmed.
I think I got most of your question answered. Post again if you have any questions.
Carl
Oct 22, 2008 | Panasonic KX-T7633 Corded Phone
Call Waiting
THere are two answers to you question, depending on certain options and conditions.
First, where is the voice mail and where is the call waiting coming from?
1. If Voice Mail (VM) is located in the central office and you have a destination for call forward BUSY/NO ANSWER it will go to CO VM.
2. If Voice Mail on premise (Partner Mail), and you have CF BUSY/NO ANSWER set on your phone, it will go to voice mail....IF the call waiting is coming from another line. The CF and ring count is set in Partner system programming.
3. If you have call waiting coming on the same phone line and don't have CO VM, then you have no voice mail.
My CO codes for VM are 72# for Call Forwarding and *92 for CF Busy.
As Always, YMMV
Carl
Sep 14, 2008 | Avaya Partner 34B Corded Phone
How Can I check voice mail remotely
Do you mean check your v/m for your extension from somewhere other than your office by calling in?
If so, it would depend on how calls are answered at your office. If someone answers, have them transfer you to the ext number for VM. If you have an auto-attendant, or a DID directed to your extension, call and wait 'til VM answers.
Assuming the default settings are in place, dial "9" + your ext number, then your security code if you have one.
Mar 31, 2008 | NEC DTU 8D-2 Corded Phone
Override Passcode Samsung LCD 12B
what type of voicemail do you have?
Dec 10, 2007 | Samsung DCS 12 Corded Phone
Panasonic KX-T7633 Corded Phone Logo
153 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
