Question about Vtech V.Smile TV Learning System
Vtech smile toy.
When i try to connect to TV i can only hear the sound, but not picture, any idea? Thanks in advance. please reply to my email id.
maruthy@gmail.com
  • maruthy Sep 07, 2008
    Thanks for helping,
    i tried all the channels and its there in right color cords, but still it just play the sound but not picture....
    is that any thing wrong with catridge? any idea?
  • prozycki Dec 14, 2008
    Hi how did you fix it thtat problem with no picture on tv. I have that same problem you had before. I would be very grateful for your help as my boy doesn't give me a life as only ask when you gonna plug it etc... Please email me at p.rozycki@gmail.com
    Thank you so much for your help
    Scholar:
  • 125 Answers
Have you tried making sure you have connected the right color cords in the back? My guess is that they are in the wrong place as that has happened to me before too. Other thing you can try is make sure your tv is on the right channel, 3,4, AUX channel, etc. If you can hear it, than the sound plug is in correctly that is for sure. Let me know if these work. (I have a vsmile too and am happy to help)
Posted on Sep 06, 2008
  • Mighty B
    Mighty B Sep 07, 2008
    I wouldn't think the cartridge is the issue. Even as per the manual, this issue is a result of the tv connection, incorrect tv mode/channel, or a reset issue. Try resetting: disconnect all the cords and hold down both the two buttons on the front for 1 full timed minute. Then plug everything back up and see what happens. Is this a brand new system? If this doesn't work, you better call tech support at 18005212010. They are usually very helpful. Good luck! :)
Hi, I have a vtech smile pocket and it won't turn on. I have tried replacing batteries and even a suggestion off of here - but nothing. can someone please help me as I don't want to have to replace the...
Does it have a socket for an external supply? If so try it Most likely reason for not turning on is bad batteries or connections followed by a loose wire inside. If you are sure you have tried good proven batteries and the battery contacts in the smile are clean, then you have nothing to lose by opening it and looking for a dropped off wire, as long of course as it is out of warranty. I hope I have been of help but please do not hesitate to ask if you have any further questions. I appreciate your vote if you appreciate my reply and remember, even if you don't vote for me a please and thank you goes a long way.
Mar 04, 2011 | Vtech V.Smile Pocket
I want to pluge a v smile on my tv
You need to use the composite (Red, White, Yellow) connections that come with the Vtech. Once connected you will probably need to change your TV to use the 'EXTERNAL' input source.
Mar 01, 2011 | Vtech V.Smile TV Learning System
Controller lighting up but not moving anything on screen,
Hi gregmussmach,
There are lots of issue with this toy, try to check the batteries 4 "AA" batteries, and the connection to the tv is properly secure.
Thanks,
Banaple
Sep 01, 2010 | Vtech V.Smile TV Learning System
V-Tech Cyber Pocket Screen will not work
Hi i'm Ryan, have you tried to reset it? Remove the battery cover there should be a small pin hole with a button in it, push it to reset. It worked on my daughters.
Dec 29, 2008 | Vtech V.Smile Pocket
Citizen ID
There is a tool on the VTech website to help you set it up:
http://www.vtechkids.com/product.cfm?productID=636
-Tha Mp3 Doctor
Dec 28, 2008 | Vtech V.Smile TV Learning System
My daughter v smile pocket does not work
Sounds like the contacts on the games need to be cleaned. On the game cartridge, push back the little cover and clean the gold colored contacts on both sides. I use a cotton ball or q-tip with alcohol on it. Let it dry before you put it back in the v.smile.
Dec 09, 2008 | Vtech V.Smile Pocket Pink Electronic...
V tech smile.
It sounds like you need a new cable that runs from the unit to the TV. Check the cable for cuts, etc.
My kids damaged mine closing the entertainment center door on it. I cut the wire, reconnected the wires all and taped it back up. Works fine now :D
Dec 05, 2008 | Vtech V.Smile TV Learning System
New Vtech Smile won't advance to games in TV Mode
Try plugging the joystick into the opposite port - if it is on the Player 2 port, plug it into Player 1, etc. If it works in one port, but not theother, then one of the ports is bad/damaged. If it doesn't work in either port, it is the joystick itself. Replacement joysticks can be ordered from VTech, Amazon, Target or Walmart.
Other troubleshooting methods:
1) Press the Reset – Press and hold the ON button for about 10 seconds
2) Make sure the game is inserted far enough into the system, and that it is pointing in the right direction. You may occasionally need to clean the contacts.
3) Also, make sure you are using the supplied power cord/adapter, not batteries. Batteries cause more problems than they’re worth.
-Tha Mp3 Doctor
Sep 28, 2008 | Vtech V.Smile TV Learning System
I have sound, but no picture.
It is most likly the problem is where you put the game in. Try using a can of air to spray in there. If that doesn't work, It would be cheaper to buy a new one then to have that one seviced. You could also spray the air into the cartridge.
Sep 22, 2008 | Vtech V.Smile TV Learning System
Any ideas on the v smile game???
yes this will be permanet damage .
Aug 11, 2008 | Vtech V.Smile Adapter
Vtech V.Smile TV Learning System Logo
157 people viewed this question
Top Vtech Toys Experts
Nikki  Mclean
Nikki Mclean
Are you a Vtech Toy Expert? Answer questions, earn points and help others
