Question about Yamaha Electrical Supplies
Yamaha Generator YG4600D
I am trying to convert from gasoline to natural gas to run the generator. Does Yamaha have any such conversion kit, or do you know of any such conversion kit I could install? I know other engines are doing this.
Thanks for any help you may give
Bill Shamburger
225-752-0913
bnsham@cox.net
    Novelist:
  • 72 Answers
My answer:
Hello Bill:
Here are the site links you'll need to check and/or get info, or buy your adapter kit for your Yami YG4600D Genset conversion kit.
Most likely it's running an 8 or 10HP engine on it now? In any case it's most likely less then 12HP. Not sure what size engine you have, as you didn't say only for the model #? On older Gensets it's harder to track down the HP rated engine is all.
For your Yami YG4600D Genset there you most likely will have your choice of at least 4 adapter kits depending on if you are going to keep gasoline as an option. If you're definitely NOT going to be ever running gasoline again then there are 1 or 2 adapter kits to choose from.
Use the site links below, and then browse whichever area you want as there are many options there. The last link listed takes you through all the different engines by make & model #'s.
I would also shop around locally where you are in LA, as you might be able to get that adapter kit for a lot less then the $227 to $267 they are asking for there at that site.
If you don't see your exact model # (or kit) there call them on their 800 toll free # listed at their site.
Also - if this site doesn't meet your expectations customer service wise at least you will have a starting off point with the wealth of information supplied there!
http://www.propane-generators.com/what_kit_do_i_need.htm
"What Kit Do I Need?"
http://www.propane-generators.com/simple_explanation.htm
"Simple Explanation"
http://www.propane-generators.com/a-c_kit_list.htm
A and C Kit List
Please post me a reply as to this info helping you solve your adapter kit problem there by following my posting recommendations above. Also please rate my troubleshooting fix as well.
Keep me posted and I'll follow up as well.
Best regards,
Frank
Posted on Sep 07, 2008
How reliable is patriot Power Generator?
Best to look for reviews on websites of companies that sell particular brands. Regardless of brand, make sure to drain fuel completely after use. Most small engine equipment, including generators, are not ethanol friendly, so use Pure Gas if available in your area. I recommend you look for a tri-fuel model that will run on gasoline, natural gas, or propane. Also, there are kits available to convert gas generator to tri-fuel or bi-fuel.
https://www.pure-gas.org/
Generator Conversion Kits to Propane and Natural Gas
Jun 18, 2017 | Miscellaneous
How to find portable generator brands?
There are numerous sites online that are providing specifics of portable generator. These are typically specially manufactured for those people who are looking for good quality portable electrical generator and it's assessment. To find out more please click here.
Best Selling 2000 Watt Portable Generator Brands 2016 Top Brands Guide
Aug 05, 2016 | Electrical Supplies
Generator w/nat gas conversion kit sputters
THAT SOUNDS like a VERY LEAN condition. The exhause glowing is because its so lean. The stalling the sputtering. OPEN the gas valve more WHILE its running. With a load if possible.. If you have a tri fuel kit like I do, going from propane to nat gas I need to open the load block (gas valve) 2 turns more .Then it starts and runs great.
Jul 27, 2012 | Electrical Supplies
Generator with natural gas conversion intermittently sputters
running out of time and too rich
suggest that you call in an auto gas technician to check and adjust the regulator /converter for the gas to get it running right
Jul 03, 2017 | Grilling
I have a grill Frigidaire FD27LKEC 27 it is running with natural gas and I would like to convert it to propan. Is there a convertion kit or what do I need to change.
At one time, there was a conversion kit available to convert your model from Natural Gas to Propane Gas. Unfortunately, it is no longer available and has been removed from the retail market. This, usually happens, when a problem resulted from a conversion of one gas type to another.
Hope this helped you.
May 23, 2011 | Frigidaire FD27LKEC (LP) Grill
Conversion of yamaha gasoline generaor into natural gas...
i know YAMAHAwere doingsome work on converting outboard motors to run on LPG they may be able to get a bit of info from the STATE distributors might be worth a phone call
Jul 20, 2009 | Electrical Supplies
Engine cant run with air filter fitted, I have cleaned it .but the problem remains the same
This means that you are over fueling. There is more fuel going to the carberator than air. By removing the air filter you are allowing more air flow into the carberator, which is allowing the engine to run right. Natural gas and propane generator must have no more than 11 inches of water column. Gasoline engines should have no more than 3.5 psi out of the electric pump. If gasoline is gravity fed, then this means that you need to rebuild the carberator or purchase a new carberator, but try to adjust the flow valve on the bowl of carberator first.
May 19, 2009 | Kipor Parallel Wiring Kit, 30 amp...
Conversion of Yamaha gasoline electricazl generator engine to natural gas
My answer:
Hello Bill:
A and C Kit List
Best regards,
Frank
Sep 06, 2008 | Yamaha Electrical Supplies
Electrical Supplies Logo
622 people viewed this question
Top Yamaha Electrical Supplies Experts
John Trevino
jmt
Level 1 Expert
Roland W VanLue
Roland W VanLue
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
