Sansui LCD TV SV-3255 problem with LCD screen
A large smudge has appeared on the right hand side of the screen only right along the edge of the screen and appears worse with certain colours - dark colours accentiate the smudge while light colours one can hardly see the smudge. It almost looks like a water stain
SOURCE: looks like a water stain on screen
IT SHOULD NOT NEED A "REPAIR" PER SAY. HOWEVER, I OWN AN LCD TV, BUT NOT A PROTRON. YOU'RE GONNA FIND THIS PROBLEM WITH ALL LCD TV'S. IT SOUNDS LIKE IT IS SIMPLY DIRTY. THIS IS THE WAY YOU CLEAN YOUR SCREEN. IT IS VERY EASY AND FAST, AND YOU SHOULD HAVE THE SOLUTION IN YOUR KITCHEN AND BATHROOM. TAKE THE CLEANEST, MOST SOFT CLOTH YOU HAVE IN YOUR HOUSE. DAMPEN,NOT SOAK IT, WITH WATER, AND LIGHTLY RUB A SMALL SECTION OF THIS STAIN, AND SEE WHAT HAPPENS. IF THIS DOES NOT WORK, ADD A SMALL AMOUNT OF SIMPLE RUBBING ALCOHOL, AND TRY ANOTHER SMALL SPOT OF THE STAIN. IT SHOULD COME OFF. SOME OF MY "HI-TECH" FRIENDS USE STRAIGHT RUBBING ALCOHOL, AS IT HAS A TENDENCY TO EVAPORATE A LOT FASTER THAN WATER AND LESS LIKELY TO LEAVE ANY "WATER STAINS". HOWEVER, IF YOU CANNOT SEE THROUGH THIS STAIN, THEN YOU'RE BETTER OFF BUYING A NEW TV. SOUNDS LIKE SOME KIND OF LEAK OR MAYBE THE TV IS JUST NEVER SHUT OFF, THEREFORE BURNING IMAGES INTO THE SCREEN. FORTUNATELY, IF IT IS STILL UNDER WARRANTY, YOU MAY GET HELP THERE. MY FIANCE TOUCHED THE LCD SCREEN WITH HIS FINGERS, AND IF YOUR FINGERS ARE DIRTY, THEY WILL LEAVE OIL STAINS. PEOPLE DO SOMETHING TO A PRIZE POSSESSION IN YOUR HOUSE, DONT TELL YOU THEN ACT LIKE THEY DONT KNOW WHAT HAPPENED. ITS HILARIOUS. HOPEFULLY THE ISSUE YOU HAVE CAN BE FIXED BY YOU!
Posted on Jan 08, 2008
zjut
  • 106 Answers
SOURCE: dark vertical line(s) on Lcd tv
Most likely it's the LCD panel failure. You can replace the panel if you can find a spare part. But the new panel may cost you as much as to buy a new tv. Hope that will help you.
Posted on Jan 27, 2008
  • 78 Answers
SOURCE: Sansui SV 2102 GOT SOME PROBLEM PLEASE HELP TO FIND OUT A SOLUTION OR KINDLY INFORM ABOUT THE SANSUI HELP NO.
on some tv's you can get to the menu by pushing both the channel up and down buttons at the same time.
Posted on May 05, 2008
SOURCE: Black smudge marks along left side edge of paper.
Its probably a defective toner. If the film on the toner drum is scratched it can cause toner to stick to the drum everytime it spins causing the constant marks.
Posted on Jul 30, 2008
Jay_Sav
  • 93 Answers
SOURCE: Samsung scx5315f printing black smudge along edge of page
The fact that it's printing anything suggests that it is not a Toner problem. Remove the toner, and have a look at the run inside the printer, checking for any excess toner which is in there. Also, check the Drum and Imaging Unit for damage, wear and tear etc. There will also be a static strip near the imager, with a little tab which you can sweep across the unit to clean it.
Posted on Mar 05, 2009
How do you change the input without the tv remote?
I don't have a grundig tv, but most tvs have the buttons to change input / channel /volume ect. hidden, normally at the back along one edge, but some times along the bottom. My LG has them on the right hand side when looking from the front. Hope this helps.
Oct 28, 2015 | Grundig GU22DVDPX 22 in. LCD TV
Sansui sv 3220 lcd screen just white,but sound ok
T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jan 23, 2015 | Sansui Televison & Video
Hi, I have a Sansui SV-4210 LCD HDMI TV . It does not switch on with the remote and only works once I unplugged the power cable and plug it back again. Lately it occurs every time and I have to do th
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Sep 20, 2014 | Sansui Televison & Video
Picture shows for 1 sec when switching on TV, and then screen goes black on my Sansui TFT SV-2010 LCD Monitor
Now u turn on the tv the tv pictures only flashes a few sec.than dies,but the tv still have audio sound left only?Yes,mean ur tv have a 1 or 2 long boards that are call a LCD inverter boards are the causes and the problems.These 1 or 2 long LCD inverter boards only job are to provided the tv LCD screen panel for a backlight for the tv to have picture only.Tries websites like Shopjimmy.com,Ebay.com to buy a 1 or 2 the tv long LCD inverter boards for the replacement.
Oct 03, 2011 | Sansui HDLCD3210 32 in. LCD TV
Sansui SV 2938 picture disply too big for screen
first is that tv have a tube if it does take back off and you will see what looks like a large light bulb tube and theres a clamp or two maybe even three clamps holding it inside the main big tube loosen the clamps being carefull not to get shocked by touching the wrong thing and the tube will slide back and forth it will also turn so place a mirror or just try looking around it when you adjust the tube to the correct messurement and make sure its level then lightly retighten screws be very carefull not to crack tube by over tightng hope this helped
Sep 09, 2009 | Televison & Video
PIP are stuck
Do a hard restart by unplugging the tv waiting an hour and checking. If it is still stuck you have a internal component that failed on the video board.
Feb 22, 2009 | Sansui HDLCD-2600 26 in. LCD Television
Unlock childlock sansui sv-t21pa2s
hi
how to open child lock for this sansui tv
Feb 29, 2008 | Sansui DTV2760 27" TV
Televison & Video Logo
133 people viewed this question
Top Televison & Video Experts
Electro Med Services...
