Question about Coleman Powermate Powermate 5000W Generator
Replacing eletric portion of Coleman PMA525500
Motor runs beautifully. No electricity. I want to replace the electriric portion. How do I do it. Where do I get the parts.
My voltage meter shows 300volts instead of 230-240 and continues to trip generator breaker. What is my problem?
Posted on Sep 08, 2008
Timber tuff 5 ton eletric log splitter will not move
check/replace the start/run capacitor/s
check that the hydraulic pump is not seized
Oct 26, 2015 | Timber Tuff 5-Ton Electric Log Splitter
2001 blade will bump start but wont start on electric start any ideas?
Check electrical feed to the starter solenoid. If it is and the solenoid activates, replace the brushes in the starter motor.
Jun 23, 2014 | Honda Motorcycles
Looking for a replacement motor for coleman thermoelectric cooler. Where can I look?
You can find the replacement motor here
Replacement Fan Motor For Coleman coolers
You need a set of basic tools including wire crimpers, cutters, soldering iron and solder and shrink wrap tubing.
Aug 31, 2010 | Coleman Electric Cooler 40 Beverage Cooler
5500 generator stopped producing eletric after
First check with the dealer and see if it is still under warranty. If it is not, make sure nothing is blocking the air flow around where the control modules are located. This could cause the voltage regulator and other electronic parts to overheat. Next check the brushes and make sure they are free of any dust or build up preventing them from making contact.
If everything is OK the next thing I would do is change the voltage regulator.
Nov 17, 2009 | Coleman Powermate Powermate 5000W...
Coleman Electric Cooler doesn't stay cold
the most common problem is that one or both cooling fans has failed. If you have the newer version, you can get replacement fans anywhere computer parts are sold
Jul 03, 2009 | Coleman Electric Cooler 40 Beverage Cooler
Replaced blower motor on coleman ac
You MUST always replace a capacitor when you replace a capacitor start/run device.
Replace the cap.
May 24, 2009 | Coleman Heating & Cooling
Have to manually help fan to start rotating
Nope, run capiacitor, fan motors don't use a start cap only compressors. However, the problem is most likely bad bearings in the motor and the motor needs to be replaced. If the run cap were bad you would have high amp draw when the motor is running and would trip out on overload or burn the windings.
May 01, 2009 | Coleman Mach III Air Conditioner
2005 Chevrolet Impala, Fans not turning fast enough to cool the vehicle.
you need to replace the the fan motor if eletrical. if electrical it could be a sending unit or switch.
If its a mechanical fan one that runs off the engine it needs to replaced.
Dec 06, 2008 | 2005 Chevrolet Impala
Coleman forced air furnace blower
Rmove the two screws holding the blower in place and slide it out. With the power off, rotate the wheel and inspect for debris or an impingement. If everything turns easy, you have a bad motor or start capacitor. If you have rubbing, adjust the wheel. If the motor will not turn, replace it.
Dec 11, 2007 | Coleman Propane Forced Air Heater...
Coleman Powermate Powermate 5000W Generator Logo
352 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Phil Walker
Phil Walker
Tim Garcia
Tim Garcia
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
