Front loading washing machine,the door won't lock
The washer was overloaded,stopped, the door opened before the end of the cycle, since the door will not lock<<<<<<<<<<<<<;
  • Anonymous Mar 13, 2014
    beko washer wmb 81221ls
THANKS FOR THE TIMELY REPLY
UNFORTUNATLY MY MISHAP FELL ON A WEEKEND.
WE HAD TO REACT FAST. I HAVE AN AGENT COMING TODAY
I HAVE SAVED YOUR ADDRESS FOR NEXT TIME IF THATS OK BY YOU
THANKS AGAIN. GOOD DAY TO YOU;RICHARD
Posted on Sep 10, 2008
How do I unlock a whirlpool duet washer
from a previous discussion:
Wait at least three minutes after the end of the cycle before attempting to unlock your Whirlpool washer. The door will not unlock until the motor speed equals 0 and 180 seconds have elapsed since the motor control unit received the "Stop" command. If the water in the washer is warmer than 122 degrees Fahrenheit or the water level is set higher than Wool, Delicate or Hand Wash, the washer must drain before the door latch will unlock 2 Hold down the "Control Lock" button on your Whirlpool washer for three seconds at the end of the washing cycle. Listen, and when you hear the unlatching sound, the door should open.3 If your Whirlpool washer did not unlock at the end of Step 1, press and hold the "End of Cycle" button for five seconds to manually reset your washing machine.4 Unplug your Whirlpool washer and leave it unplugged for 45 minutes. After 45 minutes, plug your washer back in. The washer's programming should be reset and the door should open.5 Manually unlock the door of your Whirlpool washing machine. Make sure to unplug the appliance before completing the manual unlock. Use a screwdriver to remove the metal strip, called the toe panel, at the bottom of the washing machine. Once you've removed the toe panel, reach up inside the front panel of the washer and feel around for the door latch. Locate the tear-drop shaped tab at the bottom of the door latch and pull it gently. When you hear a click, the door should open.
Jan 04, 2015 | Whirlpool Washing Machines
Asko service
Please refer page 12 and 24 in the washer manual to find out how to open the locked door. You have to press the door open button for 3 secs at end of cycle.
Asko Front Load Washer Use and Care Guide W6021 W6441 W6761...
Aug 10, 2014 | Asko W6441 Front Load Washer
Motor won't turn on Samsung VRT Plus WF433B*GJ**
When washing heavily soiled loads, do not overload your washer in order to assure good cleaning results.
To add a forgotten item:
1. Press the Power button.
2. Press the Start/Pause
3. Wait for the door lock light to go out (Immediately).
4. Add the item, close the door, and press the Start/Pause
The door safety state continues for 15 seconds and the cycle is restarted.
ensure thorough cleaning,
To
Try washing bedding, towels, undergarments,
contact using the ActivFresh
GETTING STARTED
1. Load your washer.
2. Close the door.
Z_
Push the laundry into the drum completely to prevent the laundry from being caught in the door or
....... from falling out of the drum.
3. Press the Power button.
4. Add detergent and additives to the dispenser (page 20-21).
5. Select the appropriate cycle and options for the load (page 14-16).
6. Press the Start/Pause
7. The Wash Indicator light will illuminate.
8. The estimated cycle time will appear in the display.
The time may fluctuate to better indicate the time remaining in the cycle.
The actual time required for a cycle may differ from the estimated time in the display depending on the
water pressure, water temperature, detergent, and laundry.
9. Before your washer starts to fill, it will make a series of clicking noises to check the door lock and do a
quick drain.
When the cycle is complete, the door lock light will go out and "End" will appear in the display.
DO NOT attempt to open the door until the door lock light is off. To add a forgotten item, see
"Loading your washer" section (page 13).
When your washer is restarted after a pause, expect a delay of up to 15 seconds before the cycle
continues.
Pressing Power button cancels the cycle and stops your washer.
The pre wash, wash, rinse and spin indicator lights will illuminate during those portions of the cycle
Nov 28, 2013 | Samsung 4.3 cu. ft. VRT Plus , Steam and...
Door won't open and is jammed.
We have an electronic Sears front load model with which that happened. . If this is a Sears machine contact the service number located in your manual and they should be able to talk you through it. For us it ended up being a door switch that had become misaligned. Make sure the machine spins the water out of the tub before you try to open the door if it is a front loader.
Apr 02, 2012 | Amana Washing Machines
Model fwt645rhso will agitate but won't drain out, on spin cycle washer spins one way, stops goes back the other way, but water will not drain out. Does not rapidly spin on final cycle. Any...
There's an auxiliary switch in the door lock.switch assembly that is activated at the end of the wash cycle for the machine to advance to the spin cycle. The machine will NEVER advance to the spin cycle unless the auxiliary switch is activated as a safety feature to prevent the door from opening during a high-speed spin cycle that may result in physical injury. The drum tumbles back and forth while the machine control checks the auxiliary if activated but since it's not, the control will not command the motor speed control to spin the drum at high speed. These symptoms may indicate a faulty door lock/switch assembly and may need replacement. Click on the links below for the detailed troubleshooting instructions and replacement of the door lock/switch assembly.
Electrolux and Frigidaire Washers Door Lock/Switch Assembly Troubleshooting
Replacing the Door Lock/Switch Assembly on Electrolux and Frigidaire Washers
Jun 18, 2011 | Frigidaire GSTF1670A Front Load Washer
How to operate the washing machines front load washer brandt bf850
  • Open the front door and load the clothing into the washing machine. Check the owner's manual for the maximum load size. Overloading the washing machine may interfere with its ability to spin the clothes and rinse them clean.
  • Fill the detergent receptacle on the front of the washing machine, making sure not to fill it past the indicated line. Always use a liquid detergent that is designed for front-loading washing machines.
  • Add bleach or fabric softener, if needed. Most front-loading washing machines have a section for fabric softener inside the detergent receptacle. Check the instructions on the bleach to find out when it should be added to the washing machine.
  • Close the front door of the washing machine and make sure it locks into place. The machine usually will not turn on unless the door is securely locked.
  • Check the owner's manual to find out how to select the different options and wash cycles. As a general rule, use warm or cold water for most types of colored clothing. Hot water should only be used when washing white cotton items.
  • Start the front-loading washing machine and let it run through the entire wash, rinse and spin cycles before opening the door to unload the clothing.
  • Please rate this solution. Regards.
    Nov 04, 2010 | Brandt WFH1176 Front Load Washer
    Can't get the door open
    Make sure you are allowing the washer to completely finish its cycle before opening the door. It is normal for the door to lock at the end of a cycle. The locking mechanism keeps owners from opening the door before all of the water has been drained. If the door on the washer is locked, select the "Drain" or "Spin" options on the front-load washer. This will completely drain the water from the system and unlock the door, allowing you to open it.
    Thank you !!
    Jul 06, 2010 | Frigidaire ATF6000ES Front Load Washer
    Stops agitating when door is open
    I thought that all front loading washing machines were supposed to stop when you tried to open the door.
    And I'm as perplexed as "dauphine." How did you get it opened? Mine won't work at all if the lock/latch doesn't lock at the beginning of the cycle.
    Apr 27, 2008 | Kenmore Elite 45986 Front Load Washer
    Washing Machines Logo
    60 people viewed this question
    Top Washing Machines Experts
