Question about Maytag Neptune FAV6800AW Top Load Washer
ND Code My washer is displaying the nd code when it goes to the spin cycle. It will not spin. It sounds like there's something grinding and then it just slows down. How do I fix this
    Novelist:
    Champion:
  • 261 Answers
The grinding is in the pump, probably some soda change. nd is no drain. Which model front or top load? Top load the pump is front right and has two hoses on it. Try to drain the water out and tip the machine back enough that it stays and spin the belt off. Set it down and use a putty knife and feel along the first two inches left and right where top meets the front panel. You find two catches that when depressed will allow access to the top underside. Hold the lid and tilt the top back, make sure the console clears the back wall and gently let the lid go back, make sure it stays. Ok the front panel has two 5/16 hex head screws holding it to the sides. They are one inch down at either side, hard to see with out light. Once these are out the panel tilts towards you held at the bottom by two prongs, tilt and pull the bottom towards you and up. The pump has three 5/16 hex screws or 3/8 and the rest is wet and looking in the pump for junk to clean out.
Posted on Sep 11, 2008
How to fix nd code
ND means no drain. The issue could be using the wrong detergent. IT could also be something stuck in the filter or the pump.
Aug 05, 2017 | Washing Machines
Spin cycle (7min) starts, spin perfectly, try to let water go (doesn't work) then reset back to 7min... ND code does appear but not all the time
ND error code means no drain check the pump filter check the pump and check the drain line that goes from the oulet port coming out of the outter tub to the pump and also check the drain hose leaving the pump that goes out of your washer as well. If you have any further questions message me back I await your rely
Thank you,
Rick
Oct 28, 2011 | Maytag Neptune MAH5500B Front Load Washer
My washing machine is displaying the letters "nd",
ND is no drain error code for the FAV6800A and most Maytag machines.
Is there water in the Wash Basket. If not this could be a stuck Pressure Switch. If there is water in the Wash Basket then there could be a Drain Pump issue/Drain Line clog.
If you want to DIY I can help you.
Feb 05, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Someone put some heavy things in it and it stopped mid-cycle. We removed the heavy objects, and then attempted to drain the leftover water by putting it on "rinse and spin." It never really...
The ND error code on a digital Neptune front load washer. The ND code means 'No Drain' and it is probably just something caught in the pump. Sometimes this is a early sign of the pump going out or a control board issue.
Nov 23, 2010 | Maytag Neptune MAH5500B Front Load Washer
Spin cycle doesn't get all the water out of clothes. Making a grinding noise when in spin cycle
Sounds like a Clutch issue. Can you confirm your model number is it a FAV6800A or FAV9800A?
Any error codes to the display ie. dC, uC, nd, etc?
Dec 04, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Error code nD, won't go into spin cycle
Is the Machine a FAV6800A or a FAV9800A?
Do you want to DIY the fix?
The nd error code = No Drain error code.
You could have drain line clog, an issue with the drain pump or a stuck pressure switch. Do you hear the machines drain pump turn on and pump out water before entering lnto the spin cycle? Is there water left in the tub with the nd error code? If you can provide feedback on the questions above I will help guide through the troubleshooting steps.
You will need the Service Manual to troubleshoot.
The FAV6800AW/FAV9800AW Service Manual for reference. Sears Parts Direct for reference.
Rich
Our washer wont spin fast and shuts off saying ND code. what does that mean
ND means that it is Not Draining. Does it make the same water-pump sounds that it used to make at that point in the cycle? In my machine, it sounds like a low-pitched loud hum when it's working.
It might be that your water pump needs replacing. If there is any strange sound (such as grinding) then there might be a coin or something stuck in the pump.
Sep 29, 2009 | Samsung WF337AA Front Load Washer
Stops mid-cycle, does not drain, displays nd error code?
Hello.
That code is telling you that the unit is draining to slow. After 15 minutes it is not below the low water level and will not spin out. The best repair for this is to replaced the pump on your unit.
Jul 15, 2009 | Maytag Neptune MAH9700 Front Load Washer
Samsung WF317 Front Load Washer code nd
Check the drain pump itself. But at the same time if your clothes are still sudsy it sounds like it is not going through all the cycles. Almost like it is skipping a cycle
Feb 12, 2009 | Samsung WF337AA Front Load Washer
Washer will not spin; displays nd error
(nd) stands for no drain check the pump,and drain hose
for clogs
Dec 24, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
