Monitor stops display
My ViewSonic TFT monitor stops to display anything after 2-5 seconds starting the monitor. When it restart it show display for 2-5 seconds and then screen become black. What to do. Viewsonic Optiquest VS11201 19" LCD Monitor has worked for 17 months. Last week it started to faintly "buzz". Now the power comes on and after 2-3 seconds the screen goes dark. Power light stays on.
  • Enrico Bignotti Sep 08, 2008
    Thanks. I'll try to find out where to get one. Suggestions appreciated. I've replaced a backlight inverter on a Dell LCD, there seems to be a lot more information available on Dell replacement parts on the web.
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 7 Answers
Sounds like classic symptoms of capacitor failure.
Old thread, but in case anyone else is still looking for an answer, the problem is probably bad capacitors on the power board. There was a world-wide problem with capacitors in the early 2000's that affected all kinds of electronics. For a good summary/review see https://en.wikipedia.org/wiki/Capacitor_plague .
Make sure the replacement capacitors are the proper size, specs (volts (v) & micro-farads (mf)) and temperature rated for 105°C. Make sure to install them in the proper orientation, they have a positive (+) and negative (-) terminal. I had 3 bad ones but replaced them all. It's actually quite simple and cheap if you have basic soldering skills. If you're not sure, research soldering technique and safety. Be Safe Out There.
Posted on Jan 07, 2016
    Champion:
  • 293 Answers
Hi...there,
It's seems your LCD Monitor backlight inverter it burnt out. Need a new inverter. Have a nice day!
Posted on Sep 08, 2008
Get my display to 1920 x 1080
When you are in display options and can see monitor 1 and 2... when you select 2 you should be able to adjust the display resolution there.
If you cannot do that for some reason, try the video card software that is specific to your video card as there might be better options in there for managing monitor 2.
Jan 20, 2014 | ViewSonic Computers & Internet
Its not showing anything but it has power
please check whether the VGA cable is properly connected to your monitor and CPU and check. it should work. if not try with another cable.VGA cable and Pin will be blue in colour
Feb 13, 2011 | ViewSonic VA703B LCD Monitor
I have vertical lines on my monitor and cannot make them disappear through any settings ? can anyone help
When does it appear on windows or before
If in Windows then uninstall the drivers of Display Adapter
Steps :-
Right Click my computer -> Manage -> Device Manager -> Display -> Uninstall -> Restart the Computer
Still Nogo
Update the Drivers of Video or display from Internet
Check if u can see same lines in BIOS Mode
Steps to go into BIOS
Restart Computer -> Keeping tapping F10 Key its a single Key on First Row of Kayboard
Check in that mode if u can see same lines over there contact View Sonic Hardware Problem
Jun 01, 2010 | ViewSonic Monitor Lcd 22in Wide Va2216w...
Tft problem
your monitor might not recieving incoming signal thats why it turns off try to examin your cpu this might be the problem your system is no booting...replace your videocard..
May 20, 2010 | ViewSonic VX2235wm LCD Monitor
Viewsonic monitor lcd to laptop problem
Remove the second monitor entry in Device Manager, and let the machine try to find the driver. I swear, sometimes, computers have minds of their own! ??
Apr 04, 2017 | Computers & Internet
Display on mac mini only shows no signal and turns black
his step-by-step guide describers how to obtain and install ViewSonic VA720 drivers for Mac.
1. Define your ViewSonic Monitor device model.
2. Define your operating system to install your ViewSonic Monitor device. Note: Update Drivers in Mac
3. Browse Monitor Drivers.
4. Find ViewSonic Monitor Drivers.
5. Select ViewSonic VA720.
6. Download ViewSonic VA720. Note: you can update all Drivers automatically with RadarSync (Freeware) or Driver Detective (Shareware).
7. Install ViewSonic VA720.
8. Restart or reboot your computer to finish your driver installation. Note: you can backup your computer drivers before updating.
May 03, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Viewsonic vx2245wm
You need to chk graphics settings in NVidia control center and change resolution until it looks right
Mar 06, 2017 | ViewSonic VX2235wm LCD Monitor
Monitor displays properly then screen goes blank
it seems tht the monitor has gone bad & needs to be replaced....try running a monitor self test by unplugging the monitor cable frm the back of the cmputer & make sure the monitor is receving power frm the wall outlet....chk if the monitor displays anything......let me knw if it wrks
Jul 11, 2008 | Dell 1703FPs 17" TFT LCD Flat Panel...
most likley the monitor has an internal power supply failure, generally the cost of repair could be higher than buying a new one.If your monitor is still in its warranty period contact the manufacturer,if not do you know of a local tv repair shop that provides free estimates to confirm cost of repair vs. replacement?
Dec 14, 2007 | ViewSonic VA1703wb Monitor
Computers & Internet Logo
1,639 people viewed this question
David Payne
David Payne
