Question about Fisher and Paykel IWL12 Top Load Washer
Taking longer and longer to wash
I am not sure what is going on. My wash cycles are taking longer and longer to wash. It is going through extra wash and rinse cycles. My clothes are not any dirtier or any heavier loads. I have cleaned the filter on the bottom. Is there something else I can check?
  • Anonymous Dec 21, 2008
    1. IWL12 Takes along time to wash a load of clothes
  • coairtpa Feb 16, 2009
    washes seem to be taking an hour or more ... what is up with this ... NO error code either
  • 126 Answers
MAKE SURE THAT YOU ARE USING A COLD CYCLE AND NOT A HOT ONE ALSO MAKE SURE THE MACHINE IS NOT PROGRAMED TO DO EXTRA RINSES.IF ALL THATS OK IF THE MACHINE HAS A ELECTRONIC BOARD THAT CAN ALSO CAUSE IT IN THAT CASE YOU NEED THE ASSISTANCE OF A TECHNICIAN.GOODLUCK.MOHAMED
Posted on Sep 18, 2008
Zanussi progress 1200
check the filter for blockages
May 01, 2014 | Washing Machines
Manua beko 5kg aa class 1000 rpm
most washers on a full wash cycle take about 60 minutes. It will take longer if you use a soak cycle with extra minutes because if you have a soak cycle and you set it for 30 minutes the total wash time will be around 1 hour and 30 minutes.
Jun 22, 2013 | Washing Machines
The washing machine is taking longer time
You can check that pump filter which is behind the base plinth, also check that the water entering the machine is at a reasonable pressure. If the machine is taking a longer time to wash and both inlet and the outlet of water is ok, it is more than likely a wash side heater fault. Basically, you set, for example. a 40 degree cycle, the heater does not operate and the water never reaches the required temp, the machine ventually times out on the heat phase and then moves on to the rinses or aborts to the end of the cycle.
Nov 26, 2011 | Bosch Washing Machines
Towell cycle taking longer than before
The washer only uses a tiny amount of water to do them clothes. If you use more than a teaspoon of HE low sudsing detergent that washer will detect suds and take extra steps to rid the suds. This causes motor problems.
Jun 11, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
WHY IS CYCLE TAKIN LONGER THAN IT SHOULD? 55MINS CYCLE IS TAKING AN EXTRA 40 MINS.
Could be due too one of several reasons.
The time is subject to various factors including, low water pressure, thus taking lomger to fill, poor drainage, temp of incoming water, temp of programme selected.
The time is based upon premium operating conditions.
Hope this helps.
Mar 09, 2010 | Bosch Washing Machines
Which is better a top loader or front loader washing machine?
Front Loading Washing Machine: Fully automatic.
1. Better washing than toploading as technologically proofed.
2. No extra effort except putting cloths and detergent inside.
3. No need to observe in between while washing. Start and forgot. You can go market and come back.
4. No issue if electricity or water went out during washing.
4. Take more water compare to toploading semi-automatic.
5. You can not open it once it started.
Top Loading Washing Machine: Semi
1. Save water and detergent.
2. Need extra effort to put the cloth from one box to another.
Oct 10, 2009 | Washing Machines
Washer has timing issue, says it will wash for 45 minutes and wash for 1 hour and 15 minutes. The cycle says 50 minutes but it ends up taking 75 minutes.
This is really not uncommon. The more and more sophistocated the machines become, the more small decisions they make on their own. I have seen a one hour load take up to 2.5 hours.
If a load is off balanced, it will change the time. If the spin cycle doesn't spin enough water out, it will increase the time, and may still be too wet. (In that case you need to clean out the lint/drain trap.)
If you really want more control and quicker washes, there will be a setting like "Quick wash " or "Fast wash." Theis setting is quite basic and does exactly what you tell it to do, and you can always add and extra rinse, or higher speed cycles.
Kenmores and GEs are the highest reported rate of longer times. Relax. The more you add, ie, delicate, two rinses, light spin, medium dry, the longer it will take. It's just trying to do its job! :)
Sirwriter
May 29, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Vulcan dishlex 750 eco taking alot longer to complete wash cycle.
How is the water flow into the machine. Are all your inline filters clean?
Apr 05, 2017 | Dishwashers
Sounds like water....dx doesnt work
2H means the machine is taking longer than 99 minutes to run a cycle. Start the cycle and wait 5 minutes, then open the door. If water doesn't look like it is spraying out the wash arms or slowly coming out the wash arms, then check to make sure the filter at the bottom is clean. If clean, then sounds like your circulation pump isn't running or impeller has came apart.
Dec 16, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Fisher and Paykel IWL12 Top Load Washer Logo
152 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
