Question about Panasonic DVD-LS55 Portable DVD Player with Screen
Error H03 I got the H03 error message. The motor makes a high pitch noise like it's trying to work. I think I need to replace the motor, but I can't get it off the green board to put in a new one. Any thoughts? Motor part #BKL2EO3KA
  • 3 more comments
  • Anonymous Mar 02, 2008
    When I try to start my DVD player, I get H03 and it won't play.
  • varsky May 21, 2008
    when i try to play the dvd player a code h03 comes up on the screen .
  • Anonymous Jun 10, 2008
    DVD won't play, error code H03 appears, motor doesn't spin.
  • TeoDang Jul 16, 2008
    Where can I buy the panasonic dvd-lx97 motor- Motor part #BKL2EO3KA?
    Thank you.
  • Anonymous Oct 14, 2008
    I will be low panasonil Lx 110
I have had this problem for 2 years, mech.is hanging up. mine was replaced.... 3 weeks later same problem. I take out the disc and very GENTLY press one direction or the other to free it up. works great for a whole movie or several movies in a row. A small amount of electronic lube helps, just make sure you don't get it near the laser head or it will mess things up. Just clean it off real well if you get some on it.
Posted on Aug 20, 2008
    Problem Solver:
  • 29 Answers
H03 indicates a traverse servo problem. This may be a problem with the kicker mecha which moves the pickup back and forth in the sled path of the traverse assembly. The kicker may not be moving the pickup back to home position to read the disc TOC when you reloaded the disc to try to get it to play again. It may be something as simple as dried lubrication on the mechanical parts, which can happen especially in smokey or dusty environments. It can also be due to a failure in the kicker motor or breaks on the connection to this motor. Whatever it may be, the player does require repair and an examination for an estimate will help to nail down what's going on to cause a traverse error H03 code
Posted on Jan 10, 2006
SOURCE:
I have just replaced the carbon brushes on my Bosch classic 6 washing machine and wasn't convinced that I put one of them the right way round. The motor is now working ok but it is making a highish pitched...
I would not think putting the brush in the wrong way round would make a high pitched noise. I would look for something rubbing against the drum or check the bearings of the drum or armature of the motor.
Jan 14, 2015 | Bosch Washing Machines
Whate causes Error H03 on a PANASONIC DVD-LS5?
the is not able to read the disk that's why you get that error message.the cause of error reading disk are busted dvd lens and the spindle motor it is the motor that holding the disk and spins .first try to replace the motor you can buy that in an electronics supply store next is try to replace the lens
Jul 17, 2010 | Panasonic DVD-LS5 Portable DVD Player with...
I have an Intel PC that has suddenly picked up lots of static
Forget the magnet. Noises like the ones you describe are usually because of a few things: 1) the hard drive is going bad, 2) a fan going bad, or 3) the CD drive is making noise. I'd like to know what the error message reads. And yes, you are correct that restarting the computer with the power button will sooner or later harm your computer.
Feb 19, 2009 | Computers & Internet
Kenmore 110.86874100 Motor (?) Squealing
I don't think they can be, but, also take a look at the fan bearing assembly too. You should be able to isolate if the noise is from the motor bearings or blower bearings.
Jan 26, 2009 | Dryers
LE code on lg washmachine
The LE error code means that you have a motor problem.  The high pitched noise means that the motor sensor has failed and needs to be replaced.  You will need to call a qualified LG technician to replace the sensor.
Jun 06, 2008 | LG WM1814CW Front Load Washer
Panasonic DVD ls 850 H03 Code error, how to solve this problem
H03 is a mech problem if I remember you need to take the bottom cover off and remove the mechanical assy (laser chassis) then you need to clean the worm gear (this is the gear that moves the laser back and forth) even the littlest amount of dirt will jame this gear and make the unit go into H03 Mode
Jun 02, 2008 | Panasonic DVD-LS850
Pls help
H03 error means Traverse servo error. The spindle motor may be defective.
Mar 28, 2008 | Panasonic DVD-LS50 Portable DVD Player
Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Feb 23, 2008 | Dishwashers
High pitch noise
Most likely it is coming from the motor bearings, you will have to replace the motor.
May 23, 2007 | Bissell 1697-7 Powersteamer Pro Deluxe...
Panasonic DVD-LS55 Portable DVD Player with Screen Logo
1,099 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
