Use the above diagram to set the HDD in the required mode.
For more details on Master and Slave modes please use the below link
http://www.ehow.com/how_6031_change-master-slave-designation.html
The Hitachi WEB site provides the jumper details for setting their hard drives as a Master and Slave drives. Select your model hard drive for these details.
Go to this link for your information.
https://www1.hitachigst.com/hdd/support/jumpers.htm
SOURCE: Maxtor 52049U4 20GB hard drive jumper settings
There should be a diagram showing how you should set the jumper. Set it according to what you want it to be and it should begin to should up. You can set it as Master, Slave, or Cable Select.
SOURCE: Looking for the jumper pin settings to designate
on the right hand side put the jumper to make primary master
SOURCE: maxtor hard drive jumper setting for model 6v200e0
Serial ATA drives don't need master/slave jumpers. You can choose "computer select". In fact, you should be a ble to run an ATA drive with no jumper. When you enter set up, it should automatically be recognized with the right bios version.
SOURCE: Do you have the jumper setting for hard driveWD800
Good day!Google the settings of that brand..usually I put the jumper in the middle for both master and slave present will occur..
regards,
mastergani
SOURCE: jumper settings
check this official web of western digital...
http://www.wdc.com/en/products/legacy/Legacy.asp?Model=WD400EB
