Question about Panasonic PT-40LC12 40" Rear Projection HDTV
Television shuts down as if thermal problem, but cool
Television powers up, lamp lights, picture and sound. After 30 seconds (give or take), set shuts down. Both the exhaust and intake fans shut down; however, an internal fan blowing on a PCB beneath the lamp area continues to run. The lamp indicator light flashes 4 times every five seconds after this occurs. Unplugging the unit and plugging it back in twelve hours later results in the same problem. In fact, the internal fan I mentioned above comes on as soon as the unit is plugged in. Thank you for any help that you can provide. I was recently laid off and am on a bit of a shoe-string budget.
  • Chris Lieber Feb 13, 2008
    I am having the same issue. Picture is fine when it is up but shuts off and lamp indicator flashes. Did this fix work?
    Champion:
  • 277 Answers
Shorted red driver trans shorted red pic tube defective focus/screen block any or all of these stk's on convergence module check the solder joints on convergence module
Posted on Jan 31, 2006
SOURCE:
Samsung HLS5087WX/XAA DPL shuts down after 30 - 60 seconds, 3 blinking lights
I beleive from what you have told me that most likely it is just a lamp issue, there are a lot of so called original equipment lamps and counterfit lamps on the market that will barely give you 1000 hours run time. When it comes to Television lamps cheeper is not better. Make certain to buy an original Samsung lamp, you should get about 3500 to 4000 hours from it. If you need further assistance or have questions please reply to continue.
Jul 27, 2012 | Samsung Televison & Video
AKAI PT50DL14X\SMS - LAMP INDICATOR (GREEN)
AKAI PT50DL14XSMS - LAMP INDICATOR (GREEN) FLASHES ABOUT 20 TIMES - CAN HEAR FAN RUNNING AND LOOKING THRU LAMP GRILLES CAN SEE BRIGHT BULB LITE - NO PICTURE COMES ON - AFTER ABOUT 30 SECONDS EVRYTHING SHUTS DOWN
Nov 02, 2009 | Akai PT50DL24 Television
Temp light flashes tried unplugging it for a few minutes turned it on tries to power up but then power , lamp , temp lights flash for a few seconds then it shuts down and temp light stays on
It sounds like you have a thermal issue. The TV is getting too hot or the Thermal Fuse is bad. The thermal fuse detects the temperature in the TV and tells the TV to shut down if it thinks it is too hot. Most likely caused by poor ventilation or clogged fans from household dust. Try moving TV away from wall or cabinet first, if this does not fix the problem, clean ALL the fans in the TV. If problem still persists, replace the thermal fuse.
Oct 04, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Lamp goes off and tv shuts down after lamp replacement
CK FAN on LAMP,or you could have problem with Ballast.
Aug 11, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
SOUND AND PIC GOES OUT FOR 30 SECONDS, THEN PIC COMES BACK THEN SOUND. IS THIS THE LAMP OR THERMAL FUSE OR WHAT.
The lamp is going bad. If it was the thermal fuse it would not be intermittent. It is very common for some Sony sets like yours to do exactly what you describe when the lamp is going bad.
May 17, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
I replaced the burnt out lamp,not working !!!
This may sound crazy. If you still have the old lamp. Put new lamp in old housing, and try that.
Mar 18, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
JVC AV56WP74
Replace the lamp, also the shut down time is correct the unit must allow plenty of time proper lamp cooling. otherwise the lamp life will be greatly shortend. normal lamp life is 3000 hrs.
lamp replacement may require an internal limp timer reset have a qualified tech replace the lamp.
Oct 06, 2007 | JVC HD-52G886 52" Rear Projection HDTV
Panasonic PT-40LC12 40" Rear Projection HDTV Logo
193 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
